Old 08-22-2012, 12:03 PM   #1
TheCoach
Drives: Fast n Blue
Launching your FT-86
I've been trying to find out which is the best RPM to launch your FT-86 (FR-S, BRZ, Toyota FT86) from a standing point, I've read a few articles but some go to 5000RPM +/- but they call some wheelspin , but then claim that once the traction hit you are in the higher RPM range so you compensate the wheelspin from the power of the engine...
I've done a few test myself and so far the best i've found was 3500-4000RPM to minimize the wheelspin with some light feathering.
Mine is a manual so i just drop the clutch, a friend of mine as a auto and he wants to launch it too.
Dont know much about the autos... can you drop from Neutral to 1st ? as a jump ? or you have to double pedal it ? (brake and push the REV-up ?
Thanks for your time
TheCoach is offline   Reply With Quote
Old 08-22-2012, 12:04 PM   #2
Justin.b
Drives: 13 Hot Lava, 01 Miata, 09 Outback
I am not FT-86!
Justin.b is offline   Reply With Quote
The Following 11 Users Say Thank You to Justin.b For This Useful Post:
CrazyWookiee (08-22-2012), FBaxteR-S (08-22-2012), kappaknight (08-22-2012), neutral (08-22-2012), nibor33 (08-22-2012), Ochtó-Sé (08-22-2012), oso_25 (08-22-2012), pyro530 (08-22-2012), quik1987 (08-22-2012), sho220 (08-22-2012), Sigh-on-Rice (08-22-2012)
Old 08-22-2012, 12:06 PM   #3
neutral
Drifter-Wannabe
Drives: Firestorm MT FR-S
Send a message via AIM to neutral
More important matter at hand here:
"You're" != "Your"
Auto should not be dropped into drive from neutral while revving. That would be bad for the transmission if the car even allowed it. Break + gas is probably the best option there.
Can't help you on the launching MT issue as I haven't found a need to. I'm sure someone else will have some good advice on that.
neutral is offline   Reply With Quote
The Following 3 Users Say Thank You to neutral For This Useful Post:
clevrname (08-23-2012), pyro530 (08-22-2012), TuxedoCartman (08-22-2012)
Old 08-22-2012, 12:07 PM   #4
MVJ1975
Automatic Hooligan
MVJ1975's Avatar
AT launch requires a brake stand, but it's tricky due to the fact that some emergency system (blame the unintended acceleration fiasco) restricts the RPM to 2.5k if the brake is depressed. You can get around it, but it takes a little practice.
Basically, depress the brake completely, then let off just a little bit. You should be able to rev the car all the way up at that point.
MVJ1975 is offline   Reply With Quote
Old 08-22-2012, 12:11 PM   #5
pyro530
Drives: Ultramarine FR-S 6MT
No, You're a towel!
Current: FR-S Ultramarine 6MT - Took delivery 05/30/2012 - Now for sale here
1995 M3 Coupe MT - the "Bavarian Bumblebee"
Past: 1994 Integra - Sold | 2005 Dodge SRT-4 - Totaled by Hail | 1997 Acura 2.2 CL slowmobile - Sold | 1991 BMW E30 - Sold | 1991 Acura Integra GS - Wrecked | 1971 Chevy C-10 shortbed stepside - Sold | 1973 Camaro Z-28 Clone - Stolen
pyro530 is offline   Reply With Quote
Old 08-22-2012, 12:20 PM   #6
TheCoach
Drives: Fast n Blue
sorry i aint a gramma nazi :P LOL just trying to find out the best launch RPM :P lol
Old 08-22-2012, 12:25 PM   #7
TheCoach
Drives: Fast n Blue
Thanks
Old 08-22-2012, 12:47 PM   #8
TheCoach
Drives: Fast n Blue
What about the "Sport" mode?
Old 08-22-2012, 12:48 PM   #9
FBaxteR-S
Drives: 2013 Whiteout FR-S MT
What about it?
FBaxteR-S is offline   Reply With Quote
Old 08-22-2012, 12:49 PM   #10
kappaknight
Drives: Honda Fit
If you don't know the difference between your and you're, just use ur cause you're a dolt.
Knowing proper grammar doesn't make one a nazi, it just means they can comprehend proper grammar.
kappaknight is offline   Reply With Quote
The Following 4 Users Say Thank You to kappaknight For This Useful Post:
FBaxteR-S (08-22-2012), FRiSson (08-22-2012), jstans84 (08-26-2012), TuxedoCartman (08-22-2012)
Old 08-22-2012, 12:50 PM   #11
YourFearlessLeader
Team ScioNRG President
YourFearlessLeader's Avatar
Drives: 2017 WRB BRZ
The reason for launching at 5k is to not bog the motor. Slip the clutch as fast as possible without causing the car to bog or cause wheelspin. Best way i can put it in words.
2017 Subaru WRB Limited BRZ w/ PP
YourFearlessLeader is offline   Reply With Quote
The Following User Says Thank You to YourFearlessLeader For This Useful Post:
Kwaziekeller (08-28-2012)
Old 08-22-2012, 12:55 PM   #12
sho220
sho220's Avatar
Drives: FR-S MT & FJ Cruiser
Bring it up to about 7000rpm's and slooooowly let out the clutch....
sho220 is offline   Reply With Quote
Old 08-22-2012, 12:59 PM   #13
blkwrxwag
Drives: DS FRS
"You're" != "Your"
What do you break before you give gas?
In summation, if you're going to give someone crap, make sure you don't make an almost as bad mistake while doing it!
blkwrxwag is offline   Reply With Quote
The Following 5 Users Say Thank You to blkwrxwag For This Useful Post:
czar07 (08-22-2012), HunterGreene (08-22-2012), kappaknight (08-22-2012), Propaganda (08-22-2012), TheRipler (08-27-2012)
Old 08-22-2012, 01:02 PM   #14
neutral
Drifter-Wannabe
Touche. I do that all the time. I will proofread my shit before I poop in another's shoes next time.
launching your 86 in second gear whyreeto AUSTRALIA 16 08-21-2012 01:10 AM
