Old 08-20-2012, 12:01 AM   #183
Enigmus
Enigmus's Avatar
Drives: 1996 Integra LS 4DR, 2013 Scion FRS
Originally Posted by -max- View Post
3/4" rake? Any reason for that?
the front was already preset at the 2 1/4" drop but the rear was like 1/4" So I was in a rush before the shop needed their lift back to close. I was under the impression adjusting the height was like 1:2 (someone told me that) so I turned it an inch or so thinking it'll drop 2. I'll readjust it when I get the lift free this week
i had it on 22/30 stiff all around and the ride was bouncy. it feels close to stock when I turned them full soft all around. I haven't taken any hard turns with the crappy weather and constant wet rides yet so i can't really judge the performance. Eyeballed the wheels and it doesn't look like there's any camber but I'll get it aligned something this week. No rubbing at all either.
Enigmus is offline   Reply With Quote
Old 08-20-2012, 12:35 AM   #184
-max-
Drives: Firestorm FRS
Originally Posted by Mitch View Post
Yeah, rwd in the wet, without aids especially, is both hairy and fun. I was looking forward to it. I should have an alignment, airaid intake, Perrin pulley, and Visconti tune done in time for the delta double header. Don't know when I'll have time again to rip out the rear suspension to put the whiteline camber adjustment in.
No aids for me! That don't sound right.
The rear control arms a royal pita! If I had to do it over, I would have sprung for the lower arm. The bolts that hold it on are TIGHT! And there is no room to get anything on them. I had to soak them in wd40 and let them sit for an hour. Then when you get them off, one bushing is a 2 piece that is pressed on from both sides. I got this off with a hammer and chisel and a lot of beating. The other side is one piece and pressed in and will need to be pressed out. Had to take them to a local shop to get done. Then when you get them on, no small task, each side of the control arm has to be adjusted exactly the same. Which there is no way to tell how they are adjusted when on the car. And I'm not real sure they can be gotten to without taking off the wheel. As in on an alignment rack, I'm not sure you could get to all the bolts. My suggestion is to adjust them to maximum camber and instal them and try to not move them while tightening them up.
-max- is offline   Reply With Quote
Old 08-20-2012, 12:51 AM   #185
-max-
The only measurement that we can compare to each other is center of the hub to fender, as its the only one that does not change with tire changes. Stock mine was at 14 1/2" and now I'm at 13 1/4".
Adjusting mine has been 1:1. The KWs have been the easiest coilover I've ever had to adjust.
Been riding around on 2 clicks of 18 on compression and rebound front and rear for daily and the ride is good. I've hit the bumpstops a few times in the front and have been meaning to up the compression to 3-4, see how that feels. For racing I will start in the middle for bother setting on the front and 2 compression 6 rebound in the rear. For single adjustable, I would probably start out twice as hard front as rear.
Before I put the camber busbings on, I had 1.8 left and 2.5 rear camber. Don't know why. I got it set at 2.2 rear and 2.8 front right now with 3mm total toe in on the rear. Going to see how this feels at the next event.
Old 08-20-2012, 12:52 AM   #186
Mitch
form follows function
Drives: RIP '13 BRZ
Bloody hell.
Mitch is offline   Reply With Quote
Old 08-20-2012, 11:04 AM   #187
Enigmus
Enigmus's Avatar
damn it i should have measured hub center to fender before i dropped it. makes sense now. i was thinking ground to fender and the 2.5" drop didn't make sense at all. thanks!
Old 08-20-2012, 04:27 PM   #188
-max-
Mine was right at 14 1/2" all around stock.
Old 08-20-2012, 04:43 PM   #189
NickD
Drives: '05 Corvette
Didn't realize the tail light moisture problem was this bad, never noticed this. Fffff
NickD is offline   Reply With Quote
Old 08-20-2012, 05:18 PM   #190
Mitch
Drives: RIP '13 BRZ
Well, my car got broken into last night. Just parked in my driveway. They smashed the driver window and grabbed some cash. Insurance will cover everything, so I'm not out any money. The big issue is that the there aren't any replacement windows in the US. ETA is late September, at which point I'm 8th in line for one. So the BRZ is garaged for the next month or so.
Old 08-20-2012, 05:55 PM   #191
Enigmus
Enigmus's Avatar
WTF is that a pool of water ?? I'm caulking mine tonight!
Old 08-20-2012, 06:05 PM   #192
-max-
Wow! That effin blows. I would have no choice but to drive it or get a rental.
That's one thing I'm scared of at work. My stock radio looks like an aftermarket navigation unit and even says pioneer on it. I work In a shitty place and every once and a while some crackhead will go on a breaking in spree. Its always cars with aftermarket radios that get hit. But ill have a single din removable face this weekend.
Old 08-20-2012, 06:08 PM   #193
Mitch
Drives: RIP '13 BRZ
Yeah, fortunately I still have the M3 and the Si. Thing is, they didn't touch anything else in the car. I had a gopro and a digital camera. They just broke the window to grab the cash and run. Hopefully we don't see stock headunit thefts at a higher rate than any other car.
Old 08-20-2012, 07:04 PM   #194
-max-
Obvious question-wtf is cash doing sitting in your car!
Old 08-20-2012, 07:41 PM   #195
Mitch
Drives: RIP '13 BRZ
Specifically, I had left my wallet in the car, and they only took the cash out of it. I had a bunch of stuff in my car from the autocross that got rained out. It was raining when I got home, so I just left everything in it and said I'd get it later. Of course I forgot and actually spent five minutes looking for my wallet this morning before I remembered I'd left it in the car.
Old 08-20-2012, 08:01 PM   #196
NickD
Yeah
Guess I have to wait for it to evaporate
Miami-Dade, Broward, Palm Beach Counties Sportsguy83 Southeast 1150 07-11-2014 05:07 PM
South Coast Subaru and Irvine Subaru SPCorBUST Southern California 63 04-06-2012 10:43 AM
Are there any south Africans on this forum?? Didierm BRZ First-Gen (2012+) — General Topics 6 11-29-2011 01:39 AM
