Old 08-20-2012, 08:49 AM   #15
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
NA is expensive per hp gained. Much more than going FI. 300whp could be had on FI for relatively cheap, and upgrades from there give even more bang for the buck once the hard parts are purchased.
I can see cams costing a good chunk. Probably $800-$1000 for perhaps 20-30whp gains, mostly on the top end. Even after that and full bolt-ons, you'd be hard pressed to be anywhere near 300whp. It's a hard mark to hit with a 2.0.
Coheed is offline   Reply With Quote
Old 08-20-2012, 10:44 AM   #16
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
Maybe per HP gained but id rather have a 260 whp NA monster than a 340whp force induction monster. I like linear power delivery and throttle response which is great in a NA!
Originally Posted by d1ck View Post
Why don't you stop by Honda-Tech and tell them that everyone running a 9k RPM engine is a "race" engine? There are plenty of B series, D series, F Series, and H series engines running this high and doing it reliably every day.
To the OP:
I agree that this could be a great rev happy engine with cams, valve springs & retainers, and maybe a port job depending on how good the stock heads flow.
I agree, Cams, Valve Springs & Retainers, port job, headers, exhaust, pulley, intake, larger Throttle body should be giving us around 250-260 WHP with a good tune and 9k rpms easy.
Anybody wonder if ITB'S are possible in a flat 4? I wonder how it would sound
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
The Following 2 Users Say Thank You to track_warrior For This Useful Post:
Akired86 (08-21-2012), soulever (10-12-2013)
Old 08-20-2012, 10:56 AM   #17
rusty959
Drives: DGM BRZ limited
ITB's are possible in a flat 4 (racing team I am on had ITB's on a flat 4 for awhile)
However, I don't know specifically to the FA20. Im sure you can setup something customish. Would open up your injector possibilities.
rusty959 is offline   Reply With Quote
Old 08-20-2012, 11:12 AM   #18
FT-86GOD
Senior Rocket Bunny
FT-86GOD's Avatar
Drives: 1982 XX KE70
That monster would be working a lot harder than FI though pcasso i would think... Dont get me wrong its just my guess....
When i was considering squeezing my LS2 6 litre ute for 500hp i looked into cams, higher comp, valve springs blah blah blah and it worked out much more easier ON PAPER to just run a big single snail especially $$$ wise.... Plus i already had spent a lot on exhaust, headers, OTR intake etc which would have all needed to be replaced...
Gladly this was around the time rumours were getting around about the FT-86 so i backed out...
I think a near 300hp N/A 86 would be epic no doubt but at what cost we will soon know.
Thumbs up to everyone having a go
BOSOZOKU STYLE BITCH........
FT-86GOD is offline   Reply With Quote
Old 08-20-2012, 11:18 AM   #19
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
When i was considering squeezing my 6 litre ute for 500hp i looked into cams, higher comp, valve springs blah blah blah and it worked out much more ON PAPER easier to just run a turbo especially $$$ wise....
I agree! Money does add up when compared to a Turbo bolt on kit. Everyone has their own taste and I already did the high compression N/A thing. It is a beauty, but its hard on the engine and pricey! As soon as I saw AVO kit, I started leaning towards turbo. Thinking back at memories of my Civic Frankenstein, I'm definitely going Turbo for this car.
With that said, I am looking forward to the N/A monster builds this forum provides!
Old 08-20-2012, 11:22 AM   #20
whitejdm
Drives: BRZ prem.
I'm sticking NA as well no question. After owning high power, low power (no power sometimes lol) NA and FI engines I've decided to keep my cars NA from now on.
Of course this is not an NA vs FI thread so I'll just add I'd like 240ish crank hp and a redline around 8500 and I would be a happy camper.
whitejdm is offline   Reply With Quote
The Following User Says Thank You to whitejdm For This Useful Post:
Sportsguy83 (08-20-2012)
Old 08-20-2012, 11:38 AM   #21
pyro530
Drives: Ultramarine FR-S 6MT
I think I'm going to be sticking with NA power and weight reduction with this car.
If I want turbo power I would rather pick up a used 2005-2007 WRX, STi or 2004-2005 SRT-4 Neon.
Current: FR-S Ultramarine 6MT - Took delivery 05/30/2012 - Now for sale here
1995 M3 Coupe MT - the "Bavarian Bumblebee"
Past: 1994 Integra - Sold | 2005 Dodge SRT-4 - Totaled by Hail | 1997 Acura 2.2 CL slowmobile - Sold | 1991 BMW E30 - Sold | 1991 Acura Integra GS - Wrecked | 1971 Chevy C-10 shortbed stepside - Sold | 1973 Camaro Z-28 Clone - Stolen
pyro530 is offline   Reply With Quote
Old 08-20-2012, 11:39 AM   #22
MattR
Running in the 90s
MattR's Avatar
Drives: 2014 Scion FR-S Monogram
I am also wanting to keep the engine N/A!
While definitely not the end-all factor, Rod/Stroke will also play into high-revving plans. Consider what seems to be a short rod length @ 130-131mm*. This will put your R/S ratio at 1.51-1.52. Not exactly the best starting point for a 9k engine.
A higher R/S ratio will lessen the side-load on your cylinder walls which is nice when wanting to rev to the moon
A few mentions of Honda engines. Hondas are already at an advantage for increased revs due to this factor. K20A engines were in the neighborhood of 1.62, iirc. B16A() screamers were at 1.74.
The mentioned S2000 F20C engines were at 1.82, but note that when Honda introduced the F22C for the S2000, they increased the stroke which lessened the R/S ratio to 1.65. No coincidence that they also decreased the redline.
One of many factors to consider when revving high. Looking forward to fellow all-motor builds!
*If someone knows the actual rod length measurement of the FA20 please educate me. I've been looking all over the damn place and can't seem to locate it.
:happy0180:
藤原とうふ店(自家用)
MattR's Tofu Runner
MattR is offline   Reply With Quote
Old 08-20-2012, 12:03 PM   #23
Dimman
Kuruma Otaku
Dimman's Avatar
Will have to wait much longer for suitable parts, as well.
So far we haven't heard any news about cams afaik.
Because titanium.
Old 08-20-2012, 12:11 PM   #24
Sideways?
Drives: Toyota GT86 - Blue - Leather - Nav
I'd love to go for a bit of NA tuning, not because I can get mega power for the least outlay, but because of the feel...
In the end, that is what this car comes down to IMHO - it doesn't matter how much power / grip / stickers you've got, it only matters how much you enjoy the car...
To the people who say "it would be easier to get xyz power with a turbo and less expensive" good for you, but maybe I WANT to go down the NA tuning route... If it was easy, everyone would be doing it and it would be boring, much like hearing people bang on about how underpowered the car is and how it really needs a turbo - find some narrower roads and it'll feel like you're doing 10 times the speed and then the car won't seem underpowered............
Sideways? is offline   Reply With Quote
Old 08-20-2012, 12:18 PM   #25
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
There is something wonderful and challenging about pushing a high performance N/A to its limits. Where as FI cars I found were just completely enjoyable and pretty easy to maintain boost during HPDE when you get use to your own setup. I could never get use to retaining powerband in a N/A during HPDE but that's what made it more fun.
Ill be shooting for 250whp for my n/a build. which is going to be horribly challenging to gain that extra 100whp while retaining good reliable performance. The engine needs to comfortably make 250whp rather than straining at 250whp, so moving the powerband up on the RPM scale might be necessary to achieve that.
I want to guess the limit of this particular engine in N/A form fully built for HPDE is 300whp-350whp. While peakers might achieve 350-400.
WingsofWar is offline   Reply With Quote
Old 08-20-2012, 12:35 PM   #26
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
260 whp is a pretty awesome goal, I myself am shooting for 200WHP for now with a NA build and will probably keep it at that level for quite some time. I have never modified a cars suspension or breaking systems, so once I am around 200whp, that would be my next step (also will be the only time I consider up sizing my rims diameter and width, so suspension upgrades will be essential to keeping a nice and balanced setup)
With my current list of parts, I think a header and a personalized tune on a dyno would be all I need for my car to hit 200WHP. Or just switching to E85 and getting a personalized tune with my Airaid intake, SRT header back exhaust and my Perrin Pulley..that could do it too.
I am excited! N/A will be this cars forte I think. Boost is great, but I hope that in10-15 years this car is still being featured in car publications with unique NA builds just like honda's and nissans of yore are today.
Old 08-20-2012, 12:36 PM   #27
whtchocla7e
Drives: 2013 FR-S Hot Lava
I would prefer a good NA tune to a FI setup myself.
Live to drive another day
whtchocla7e is offline   Reply With Quote
Old 08-20-2012, 12:38 PM   #28
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
I think what they're doing with the STI BRZ is perfect. 250hp, 8500rpm, and lighter weight. In a few years if that car doesn't materialize I'll try to reach those numbers with my BRZ. I think the key to making this car fast is going to be weight reduction and not big power.
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
9000rpm, aspirated, high, naturally, revv
Let's see your computer setup! Hanakuso Off-Topic Lounge [WARNING: NO POLITICS] 79 11-06-2022 11:43 AM
AutoX Parts Setup NYC BRZ Tracking / Autocross / HPDE / Drifting 38 08-17-2012 05:42 PM
Audio setup 315FR-S Electronics | Audio | NAV | Infotainment 20 05-17-2012 06:23 PM
2 car setup...feasible? mankarn86 CANADA 3 03-30-2012 02:00 AM
