Old 08-19-2012, 02:10 PM   #1
jm1681
Drives: MKVI VW GTI
Noise coming from the rear end...
This happens to me EVERY time I pull up my driveway, but only from one side. Basically, I need to slow down a LOT to pull up without scraping my front end. In doing so, when I go to pull up the driveway (VERY cautiously, with a bit of slip and VERY light throttle) the rear tires spin for a fraction of a second (Hardly a chirp), and a pretty horrid noise comes from the rear.
Not sure if it's the diff, or something related to the traction control, or both, but I was just wondering if anyone else has experienced anything similar. For all I know, it could be totally normal, I just want to be sure I'm not cooking my diff.
jm1681 is offline   Reply With Quote
The Following User Says Thank You to jm1681 For This Useful Post:
AteMyShorts (08-03-2016)
Old 08-19-2012, 02:36 PM   #2
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Is it a shuddering noise?
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 08-19-2012, 03:01 PM   #3
WTF
WTF's Avatar
Drives: FT86, BMW 5, JZA80, Porsche 986S
It'll be your VSC or trac control kicking in.
Mine does it every time going into my driveway cos it lifts a wheel front and rear.
Next time you go in, have your foot on the brake a bit and you'll feel it pulse as if its ABS'ing. your car is applying brakes to the wheels, thinking you have lost control, and trying to straighten the car up etc.
600hp Built FA20 Widebody Toyota 86/FRS.. build thread
WTF is offline   Reply With Quote
Old 08-19-2012, 05:22 PM   #4
jm1681
Drives: MKVI VW GTI
This is what I thought as well, but I tried disabling everything (Not sure I did that right I held the traction control for a few seconds until the "Trac off" and VSC lights came on) and it still did it. Did I maybe [most likely] not turn the Traction control off correctly?
I will try what you suggested though, if I can XD I'm gonna need a third foot.
Old 08-19-2012, 08:26 PM   #5
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
I have all nannies in mine off most of the time, and if I pull into my driveway at the wrong angle it will lift a wheel. If I give it gas, the light in the gauge cluster will flash.
Im wondering if tcs & vsa can't be turned off completely.
Parting out HERE
Old 08-19-2012, 09:02 PM   #6
mxsled
mxsled's Avatar
Drives: Audi A3 2012
my frs does the same thing...
mxsled is offline   Reply With Quote
Old 08-19-2012, 09:47 PM   #7
jm1681
Drives: MKVI VW GTI
Originally Posted by civicdrivr View Post
I have all nannies in mine off most of the time, and if I pull into my driveway at the wrong angle it will lift a wheel. If I give it gas, the light in the gauge cluster will flash...
Makes me feel better to know it's not just me, but...
I'm starting to feel that way as well...
Old 08-20-2012, 12:06 AM   #8
WTF
WTF's Avatar
watching the drift videos, im sure the systems can be disabled completely, otherwise that defeats the major purpose of the car
Old 08-20-2012, 05:57 AM   #9
jm1681
Drives: MKVI VW GTI
Fair enough, but then why all the noise XD
Old 08-20-2012, 06:00 AM   #10
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
mine makes a lot of noise too, mostly wheels chirping :/
lol but on topic - not really sure what we're discussing .. did you check the other threads regarding the rear noises?
I personally go in at an angle but I don't get that ..
but then again i dont get a wheel in the air
Old 08-20-2012, 10:48 AM   #11
jm1681
Drives: MKVI VW GTI
Originally Posted by Bonburner View Post
...I personally go in at an angle but I don't get that ..
Therein lies the difference. When I'm pulling in, I've got one tire clear off the ground.
Old 08-20-2012, 10:54 AM   #12
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Same here. I've started to go at my driveway from a different angle. I don't scrape and I don't lift a wheel, so obviously no shuddering.
Sent from my Nexus S using Tapatalk 2
Parting out HERE
Old 08-20-2012, 12:19 PM   #13
jm1681
Drives: MKVI VW GTI
Same here. I've started to go at my driveway from a different angle. I don't scrape and I don't lift a wheel, so obviously no shuddering...
This is probably going to become necessary for me as well. Sucks to need to turn around at the end of the street, but if it keeps that horrid noise from occuring, so be it XD
Old 08-21-2012, 02:30 AM   #14
WTF
WTF's Avatar
I actually just tried my driveway, with the trac and vsc off, and there is still an amount of chattering that comes from the rear end when it lifts the wheel!
I took a video, It coincides with the VSC/Trac light flashing on and off, Surely the car can have all the aids switched off? :S
Rear Deck "popping/clicking/tapping/ticking" noise. Sigh-on-Rice Issues | Warranty | Recalls / TSB 637 04-28-2020 04:55 AM
Fixed flapping, clanking sound coming from rear Cornerman Issues | Warranty | Recalls / TSB 2 08-16-2012 09:27 PM
Fan noise? djliquidsteele Scion FR-S / Toyota 86 GT86 General Forum 3 07-30-2012 05:22 PM
LSD noise wheeladdict CANADA 2 07-09-2012 03:21 PM
Rumble coming from rear end? No Quarter Scion FR-S / Toyota 86 GT86 General Forum 34 06-27-2012 02:14 PM
