Old 08-17-2012, 07:23 AM   #15
vtmike
vtmike's Avatar
Drives: Scion FR-S
I believe it was car and driver that found lighter and wider 18's added more grip and cornering speed but ran slower lap times due to it changing the overall gearing because of the larger radius of the tires and wheels. Also unless you plan on doing a big brake kit, 18's dwarf the stock rotors making the package as a whole look off.
Sent from my Nexus 7 using Tapatalk 2
vtmike is offline   Reply With Quote
Old 08-17-2012, 09:28 AM   #16
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
On thing to consider, at least today, is top notch performance tires are cheaper in 17" sizes. Regular summer tires and most all seasons are fairly close in the widths most 86ers would use though. I do agree 18" wheel fit the curves of the car well but I'll like use 17s so I can share tires between the BRZ and the WRX.
TomR
ABQautoxer is offline   Reply With Quote
Old 08-18-2012, 02:12 AM   #17
phoenix2150
Drives: 2000 TJ Magna 3.5L V6
The GTS version in Oz has larger brake discs (I've ordered the GTS). With 215 tyres on 18x8 wheels the gearing should stay just about the same see link, http://www.willtheyfit.com/index.php...&Submit=Submit
r17 tyres are cheaper but that is why you keep your OEM 17 wheels if you going to track or burn though your rubber quick .
phoenix2150 is offline   Reply With Quote
Old 08-18-2012, 01:29 PM   #18
Wolfking
Wolfking's Avatar
Drives: Asphalt FRS
Originally Posted by newkid185 View Post
Hi guyz!! im about to get 4 OZ Alleggerita HLT in 17x7.5. The recommended tires that tirerack advises is 225/45-17 which i found its kinda thick (45 of 225 is about 101.25 ) Which other tires that i should go with which its not too thick and still perform well?? and how about if i get the 17x8??
225/45-17 is my favorite set up! I ran this on my '98 240SX. This along with a front STB and an almost 2 inch drop, allowed me to drift only when intended...highly predictable! If you're not really planning to drift your FRS/BRZ, yet want a car capable of doing so, (as I do) this may work well for you. Also bear in mind a 50 series tire will give you a smoother ride than 45's that you may appreciate if you're a little older (also like me). Good luck!
Wolfking is offline   Reply With Quote
Old 08-18-2012, 02:10 PM   #19
ZDan
ZDan's Avatar
Drives: '23 BRZ
17x8 w/ 235/40-17s is what I'd go with. 18s = waste of money, and lookswise the brakes already look lost in 17s, would look even scrawnier inside 18s.
Old 08-18-2012, 02:26 PM   #20
vtmike
vtmike's Avatar
Drives: Scion FR-S
Agreed. 17x8 rpf01's with 235 40 17 tires is my choice for this car. Can't go wrong with that tire wheel combo.
Sent from my Galaxy Nexus using Tapatalk 2
Old 08-19-2012, 12:36 AM   #21
newkid185
Drives: 2013 Scion FR-S Whiteout-M
Thanks guy!!! I really appriciate your help!!! I will go with the 17x8 with 235/40/17 tires Michelin Pilot Sport PS2. Also my eibach Prokit is on the way so hopefully I ll upload some pics when everything done!! Thanks again!!
newkid185 is offline   Reply With Quote
Wheel Directory: Effect Sengen 17x7.5 +40 Leonardo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 11-14-2013 02:18 PM
need suggestions for lightweight forged 17x7 wheels hankster Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 11-15-2012 01:40 PM
Delete driver01 Wheels and Tires 6 08-17-2012 11:47 AM
Better tires and wheels = less fun? ngabdala Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 08-05-2012 02:56 PM
Help please. Will these wheels/tires fit? Suiris Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-03-2012 08:50 PM
