Old 08-17-2012, 06:22 PM   #15
empower-auto
Kouki-Monster
empower-auto's Avatar
You should Only Use your Ebrake if you have your Hand Duct tapped to the steering wheel and drive an EG6
I lol'd
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 08-17-2012, 09:54 PM   #16
YinYang1980
Drives: Jeep Patriot 2011
i hate this kind of e-brake. i dont know why they just dont use the service brake to e-brake like the mazda protege5 2003.
YinYang1980 is offline   Reply With Quote
Old 08-17-2012, 10:01 PM   #17
Pscylo
Pscylo's Avatar
Drives: Raven FR-S
And if you do start to wear and notice the "swing that ass" brake not being as functional and needs to be adjusted, the plug in the hole on the drum portion of the rotor can be removed and there is a gear there to adjust with a flat head. Or at least, thats where I have seen the ebrake adjust on other vehicles.
Pscylo is offline   Reply With Quote
The Following User Says Thank You to Pscylo For This Useful Post:
bryanttttttta (12-04-2014)
Old 08-18-2012, 12:45 AM   #18
driver01
Drives: brz 13
Thats correct. Basically remove the plug on the front face of the rotor. turn the rotor until the opening lines up with the adjuster and then using a flat screwdriver turn the adjuster until it locks up. then back it up around 6 clicks.
after this check your parking brake lever anywhere between 8 - 10 clicks to lock it should be all right.
driver01 is offline   Reply With Quote
The Following 4 Users Say Thank You to driver01 For This Useful Post:
bestwheelbase (08-19-2012), bryanttttttta (12-04-2014), dori. (11-15-2014), ill86 (08-18-2012)
Old 08-18-2012, 01:15 AM   #19
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Better methods should be used to initiate imo... The OEM "e-brake" setup should not be used other than it's intended purpose. Most, if not all ,OEM hand brakes will stretch and lose adjustment after so many pulls.. You can keep readjusting, but it is what it is.
I teach a variety of vehicle dynamics. Including forward 180s for evasive work, drifting and rally x. We would find that adjustments had to be made frequently.
There are aftermarket brake solutions for competition use. That being said, using the OEM hand brake isn't the end of the world, but don't expect it not to lose adjustment or fail entirely.
ill86 is offline   Reply With Quote
Old 08-18-2012, 04:25 AM   #20
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
Why do you need an ebrake to initiate a drift, its easier in this car with a scandinavian flick so you can carry momentum.
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
The Following User Says Thank You to track_warrior For This Useful Post:
Guff (08-18-2012)
Old 08-18-2012, 08:08 AM   #21
Moto-P
Moto-P's Avatar
Drives: Many types of cars in R&D.
Side Brake (parking or E brake) does wear faster with use while in motion, as it is designed to sustain a load while being parked. Chief Engineer knew this will be one of the necessary ingredients for a modern RWD sports car too but cost constraints for something as minor as this against trying to keep the main dynamics of the car, as well as $20,000+ price point didn't allow for a significant upgrade here.... But they did make it so that there is only increased wear, and not in terms of any harm done to the brakes themselves.
Keep in mind though, that ANY form of drifting is much more abusive on a ANY car, and that things do tend to break or wear quickly when used without care or much experience. Its the nature of any machine. And, this is why a dedicated Pro Drift car has many modifications costing thousands more to make it more effective and much more costly. But like any dedicated track machine, that is the nature of how things are done and made.
I would say for the FRS, the biggest risk is more in clutch kicks, as that tends to shock the driveline like the transmission, propeller and drive shafts, hubs and differntial gears. None of which are cheap at all to fix! For example, kicking the clutch by simple side stepping off it at dead stop, with engine at 4000rpm... will put in millisecond instance of driveline shock 18 times more than when gently engaging and powering a 500hp engine with the same flywheel. With stickier tires, on a grippy asphalt, this can even be greater. The same reason drag racing cars blow up gears and shafts all the time due to sticky drive tires, and really grippy VHT coated start line.
So it's in the driver, again, to use the clutch with enough skills to not load the system so much, and do it with diligent ears and eyes to monitor what's going on, and just as importantly, to gain the skills to maintain it accordingly.
This is why most guys who WANT to really cut the cost and increase driving time behind the wheel, do so in the beginning, on a cheap used car that can be disposed or repaired with ease and with less costs. There are no if and buts to this rule of thumb. The Scion FRS is a brand new car, and as such, there will not be any replacement parts sitting in a Junk Yard for a long time to come.
Moto Miwa
R&D Driving Engineer, Product Designs
Consulting for Cusco, OEM+, RS-R, Toyota Japan, and Unplugged Performance.
Moto-P is offline   Reply With Quote
The Following 13 Users Say Thank You to Moto-P For This Useful Post:
bestwheelbase (08-19-2012), Bonburner (08-18-2012), bryanttttttta (12-04-2014), BRZranger (08-18-2012), Dadhawk (04-20-2015), Guff (08-18-2012), HotLeopardMama (05-06-2015), richardM (04-20-2015), RUNAMUK (04-24-2015), SkAsphalt (07-05-2014), soundman98 (02-11-2017), Subie (08-18-2012), tripjammer (08-18-2012)
Old 08-18-2012, 08:20 AM   #22
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Moto San nailed it.
And as a few other people have said, get that flick going! I feel much more satisfied coming in with momentum and tossing that wheel around! It's not hard to get loose with the nannies off on those Primacies!
On a closed course, obviously. No street drifting! We don't need any more victims of the curse!
- The Ancient BRZ Sacrament
by Zaku
The Following 2 Users Say Thank You to Guff For This Useful Post:
bryanttttttta (12-04-2014), tripjammer (08-18-2012)
Old 08-18-2012, 03:49 PM   #23
Cabz-FT86
Drives: 2013 FR-S Raven-MT
Why use the e-brake.... This car is so easy to throw side ways. Take a corner in high revs in third gear as you start slowing into the corner, slam it in 2nd and the ass end will fly out faster than a hooker on a Saturday night!
Have I mentioned I love this car yet?
Cabz-FT86 is offline   Reply With Quote
Old 08-19-2012, 12:21 PM   #24
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
Scandinavian flick was working wonderfully for me today. Trick is to carry enough entry speed into the corner so you can just flick it in with the steering (and a brief throttle lift to shift the weight forward a bit).
I didn't even need to 'feint' much. Just cruise along in 2nd, dip the throttle & turn in aggressively and apply power & counter steer on the way out.
I'll admit that I did use the e brake a couple of times on some tighter corners but I did it pretty sparingly and in combination with the Scandinavian flick technique, just because a) I as experimenting and b) for the tighter corners & 180s I was entering a little slower & wanted to make sure that the rear broke loose.
I wouldn't bother clutch kicking this car under any circumstance for much the same reasons Moto-P pointed out. It's just not necessary (or worth the wear & tear) unless you're in a competition or something.
TL;DR - You totally don't need to go around ripping the e brake on this thing to drift it. The secret is sufficient entry speed, steering input & conserving momentum.
And of course, a safe place to practice.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 08-19-2012, 12:31 PM   #25
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Lol at this thread hahahaha
TouchMyHonda is offline   Reply With Quote
Old 08-19-2012, 12:39 PM   #26
ebphoto
Drives: FR-S, NA8, S13
e brake is generally used in higher speed drifting or to "correct angle" while drifting.
i generally feint or clutch kick... havent shift locked in this car yet.
i figured it wouldnt be as clutch kick inclined as the ae86... but i was wrong.
ebphoto is offline   Reply With Quote
Old 04-19-2015, 02:09 PM   #27
bryanttttttta
Drives:
Ebrake game is strong. This is after 7 drifting sessions at the track.
Co-Founder of SlideFactoryInc Grip/Drift Events
www.slidefactory.org
bryanttttttta is offline   Reply With Quote
Old 04-19-2015, 03:23 PM   #28
fitcious
that's why i have an automatic..no kicking of the clutch to worry about.
fitcious is offline   Reply With Quote
Ken Gushi Teaches Joey Logano How To Drift FR-S and GReddy Racing Drift FR-S Hachiroku FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 13 07-05-2012 03:06 PM
Honey, do...? (start over now) ToxicSneakers Off-Topic Lounge [WARNING: NO POLITICS] 0 06-14-2012 05:01 PM
Car won't start, no spark? #87 Other Vehicles & General Automotive Discussions 5 12-19-2011 12:29 PM
Start up troubleshooting. Gost Other Vehicles & General Automotive Discussions 12 01-09-2011 05:45 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
