Old 08-06-2012, 04:10 PM   #1
pr086
Drives: fast
how bad is it for the e-brake to use it to start a drift...
will it wear it out quickly?
pr086 is offline   Reply With Quote
Old 08-06-2012, 04:42 PM   #2
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
Ur just wearing ur tires and rear breaks. Other then that it's just normal stress of spirited driving on ur car.
FRSfan111 is offline   Reply With Quote
The Following User Says Thank You to FRSfan111 For This Useful Post:
AJUSA.com (08-06-2012)
Old 08-06-2012, 04:48 PM   #3
kanundrum
Drives: 2013 Whiteout FR-S
You should Only Use your Ebrake if you have your Hand Duct tapped to the steering wheel and drive an EG6
The Following 13 Users Say Thank You to kanundrum For This Useful Post:
8R6 (05-08-2015), baldolera (08-18-2012), DarthNads (08-06-2012), Ddreder (04-20-2015), JoeHK (01-07-2016), karbon (08-06-2012), PERRIN_Chris (08-06-2012), soulreapersteve (08-01-2015), soundman98 (02-11-2017), tahdizzle (05-06-2015), ThierryIsAble (04-19-2015), Username (08-17-2012), ydooby (08-17-2012)
Old 08-06-2012, 04:50 PM   #4
Shagaliscious
Drives: Firestorm FR-S (MT)
I would think you could stretch out the cable. I know I did in my 92 Corolla back in the day. It was cheap to replace though.
Old 08-06-2012, 04:54 PM   #5
FRiSson
Drives: FR-S MT
I called Toyota to ask about a clunking noise I hear from the e-brake when I engage it while the car is moving. I like to test the e-brake every once in a while to see if it is working and will slow the car.
Their answer was "Toyota does not recommend that the brake be used when the car is moving." So I asked about emergency use, and the guy reluctantly conceded that it could be used in an emergency. So then I asked about the Toyota-sponsored video of Ken Gushi using it in a drift video. That got the guy's attention and he urgently replied "that was for professional track use only." and he warned that they do not recommend drifting the vehicle.
So Toyota's "official" position is that it is a parking brake only, with possible use only in a dire emergency.
FRiSson is offline   Reply With Quote
The Following User Says Thank You to FRiSson For This Useful Post:
Bonburner (04-19-2015)
Old 08-06-2012, 04:57 PM   #6
FT-86GOD
Senior Rocket Bunny
FT-86GOD's Avatar
Drives: 1982 XX KE70
My hand brake will see many dire situations.....
BOSOZOKU STYLE BITCH........
FT-86GOD is offline   Reply With Quote
The Following 13 Users Say Thank You to FT-86GOD For This Useful Post:
bestwheelbase (08-19-2012), chris x sway (11-26-2013), dabocx (08-18-2012), DavidBob (04-23-2015), Fang (04-21-2015), Guff (08-18-2012), immortal_suby (08-19-2012), Marco_86 (05-08-2015), neutral (08-17-2012), PERRIN_Chris (08-06-2012), Sideways? (08-18-2012), ThierryIsAble (04-19-2015), WatchmaN (08-06-2012)
Old 08-06-2012, 04:57 PM   #7
HunterGreene
Hail Magnet
HunterGreene's Avatar
Not to start an argument...
Calling it an "e-brake" is a misnomer. It really shouldn't be used as a way of stopping the car, just to keep it from moving. It doesn't apply the brakes the same way as pressing the pedal, so the pressure isn't nearly as good.
Or to lock up the rear wheels to initiate a drift. But I'm willing to agree with those above, you will likely stretch out your cable if its overused.
The Following 3 Users Say Thank You to HunterGreene For This Useful Post:
fatoni (08-17-2012), Frishkorn (05-06-2015), stevesnj (05-06-2015)
Old 08-06-2012, 06:12 PM   #8
Skyhound
Drives: Jaguar X-Type
That's because you spoke to them with the 86 being a road car. Talk to TRD or just tell them it's a track-only car. If they were to say anything else, it could easily be twisted that they said it was perfectly safe to drift the car with the e-brake.
To answer the question, it really shouldn't be that much of a problem to use the e-brake to initiate a drift. Worst that happens is stretching it out, as others have said.
Skyhound is offline   Reply With Quote
Old 08-06-2012, 06:27 PM   #9
SkitterSkotter
SkitterSkotter's Avatar
Drives: 2013 Scion FR-S (Hot Lava)
while the ebrake does work well, you can also downshift and let the clutch out pretty hard to kind of 'kick' the back end out. It doesn't lock it up but is slows the rear tires enough destabilize the chassis so you can get some rear out turn in. A well executed Scandinavian flick also does wonders.
SkitterSkotter is offline   Reply With Quote
Old 08-06-2012, 06:29 PM   #10
fistpoint
Drives: Supercharged Golf Cart
Sounds about right. Ford went through this with one of their Baja models bending in half when customers used them for ramp jumping like in the commercials...Ford said it wasn't designed for that.
Or the service manager at one of my local Hondas that said I should never take my 2000 Civic Si over 6000rpm despite the fact that VTEC doesn't even start until 5800rpm and has an 8000rpm redline. Yes, he was saying VTEC should only be used for 150rpm total.
The moral of the story is that manufactures don't want you to use their cars as intended, and the people working for them don't know HOW to use them.
fistpoint is offline   Reply With Quote
Old 08-06-2012, 06:47 PM   #11
driver01
Drives: brz 13
The E-brake is a drum style of brake, while the service brakes are disc brakes. Both the E-brake and service brakes are housed in the rear using the same rotor. The raised center portion of the rear disc holds the E-brake which is mechanically activated, designed to work even if you get a hydraulic failure with the service brakes.
The clunking noise is from the shoes locking up against the drum. They kind of wedge against the drum once applied creating the clunk noise.
On the first picture you can see the larger center section of the rear
rotor that houses the parking brake components.
The second picture is an exploded view of all the parking brake components.
The shoes have brake material on them, once this wears out you will get
metal to metal contact and ruin the rotors. In order to check the shoes the rear rotor has to be removed, I do not believe this check is part of regular service.
driver01 is offline   Reply With Quote
The Following 18 Users Say Thank You to driver01 For This Useful Post:
86868686 (05-06-2015), AJUSA.com (08-06-2012), baldolera (08-18-2012), bestwheelbase (08-19-2012), Bonburner (05-08-2015), danthedirt (08-21-2012), Frishkorn (05-06-2015), Guff (08-18-2012), gzpermadi (05-06-2015), ill86 (08-18-2012), joe strummer (04-21-2015), LXXXV1 (04-21-2015), Rosticles (06-24-2015), sastexan (08-21-2012), soundman98 (02-11-2017), theredtape (08-17-2012), tripjammer (08-18-2012), winter (08-17-2012)
Old 08-06-2012, 06:54 PM   #12
pr086
Drives: fast
i've heard of that method before too, but wouldn't it be bad for the clutch?
i know driving the car aggressively and sliding it is going to cause wear, but i don't want to do something that is going to wear that part out really fast. i would imagine down shifting and taking your foot right off the clutch would be bad on the tranny/clutch. i always blip the throttle in my fwd when downshifting otherwise it throws your head forward.
Old 08-06-2012, 07:00 PM   #13
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
It is often overlooked that any car will suffer worn or broken parts much faster when used beyond just spirited driving. All the hype surrounding the car I think leads the more naive and less experienced drivers into a false sense of security.
They might think "the car is made to be driven hard and not pussified."
(I nearly peed a little when I saw someone post that)
Well, of course, sure.
But at a price. This has never changed, and never will.
CircuitJerk is offline   Reply With Quote
The Following 3 Users Say Thank You to CircuitJerk For This Useful Post:
FRiSson (08-07-2012), HotLeopardMama (05-06-2015), whataboutbob (08-17-2012)
Old 08-17-2012, 06:18 PM   #14
theredtape
Drives: civic,vfr,BRZ
The first picture is an exploded viewm from an IS rear brakes, same style as the FR-S.
On the second picture you can see the larger center section of the rear
rotor that houses the ebrake components.
Thanks for explaining that. I was driving today and for no reason whatsoever lifted the brake a tiny bit and heard the clunk. I was so confused as to why it would make this noise. My old cars had cable actuated disks or cable actuated drums not both. I didn't even know this style existed.
Anyway a little search goes a long way on the forums!
Because Racecar.
theredtape is offline   Reply With Quote
Ken Gushi Teaches Joey Logano How To Drift FR-S and GReddy Racing Drift FR-S Hachiroku FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 13 07-05-2012 03:06 PM
Honey, do...? (start over now) ToxicSneakers Off-Topic Lounge [WARNING: NO POLITICS] 0 06-14-2012 05:01 PM
Car won't start, no spark? #87 Other Vehicles & General Automotive Discussions 5 12-19-2011 12:29 PM
Start up troubleshooting. Gost Other Vehicles & General Automotive Discussions 12 01-09-2011 05:45 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
