Old 08-16-2012, 03:49 PM   #1
FRSowner
Drives: Hot Lava A/T
audio varies
Hi all,
I've had my car a couple months but I've just noticed something the past couple weeks. When I turn on the stereo and select what station to listen to, the volume level is kinda low, then after about 5 seconds, it increases significantly. After the initial increase, it does not vary.
This has caught me off guard a few times as I manually increase the volume and then it gets too loud a few seconds later and I have to lower it manually.
Anyone else notice this or has my stereo become haunted?
FRSowner is offline   Reply With Quote
Old 08-16-2012, 03:56 PM   #2
elbachatero1
elbachatero1's Avatar
Drives: 2013 Subaru BRZ 6MT Limited WRB
Originally Posted by FRSowner View Post
Hi all,
Could it be when it converts it to HD? When I'm listening to the radio it changes how loud it is and when it goes back and forth from HD
elbachatero1 is offline   Reply With Quote
Old 08-16-2012, 04:26 PM   #3
Yruyur
Yruyur's Avatar
Most likely hd, just watch the display when it happens. The stereo also has auto sound leveling based on noise which you can adjust for , its in the stereo manual.
Sent from my PH44100 using Tapatalk 2
Old 08-16-2012, 06:24 PM   #4
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
It's the HD radio. Picks up the non-HD station first then once the HD signal is detected it transitions and poof, there's your difference. You didn't notice it sounds significantly better after that happens right?
Old 08-16-2012, 06:40 PM   #5
FRSowner
You guys are correct - it was the HD setting. I tried it both ways and it only does this when HD is 'on'.
Thanks.
My audio build - Pic Heavy rmjjensen Electronics | Audio | NAV | Infotainment 41 10-10-2016 10:03 AM
Looking for an FRS/BRZ in the SE For Audio SpeakBeck Southeast 8 02-17-2013 12:57 PM
BRZ Audio Question poudre Electronics | Audio | NAV | Infotainment 4 07-11-2012 08:48 AM
New Audio system going in Jordan6908 Electronics | Audio | NAV | Infotainment 20 06-25-2012 02:12 PM
Audio Options? SpeakBeck Electronics | Audio | NAV | Infotainment 13 06-04-2012 01:06 AM
