Old 08-15-2012, 10:30 PM   #1
NickFRS
Drives: 2013 Asphalt FRS
Wheel Directory: Enkei PF01 17x8.0 +45
Enkei PF01's, 17x8-45 offset, 10mm ebachi rear spacer, Hankook 235/45/17 evo12.
(Deleted chrome center cap) (Plasti dip)
NickFRS is offline   Reply With Quote
The Following User Says Thank You to NickFRS For This Useful Post:
Anthonytpt (03-06-2013)
Old 08-15-2012, 10:31 PM   #2
NickFRS
BC BR coil overs will be installed next friday at 10am! I'll post pictures of it lowered.
Stock Tire:
Tire Michelin Primacy HP 215/45/17 = 80 pounds
Weight 20lb, tread width 7.5in, Max Inflation 51 PSI, UTQG 240 a a.
http://www.tirerack.com/tires/tires....S&autoModClar=
Stock Wheel:
Stock: Size 17x7-48 Offset = 81.6
Weight 20.4lb.
Total Stock Weight = 161.6LB
AM Tire:
Hankook Ventus V12 evo K110 = 96LB
Weight 24lb, Tread Width 8in, Max Inflation 50 PSI, UTQG 280AA A.
http://www.tirerack.com/tires/tires....=yes&tab=Specs
AM Wheel:
Enkei PF01: Size 17x8 45 Offset, = 69.2lb
Weight 17.3lb.
http://www.tirerack.com/wheels/Wheel...All&sort=Brand
Total AM Weight = 165.2LB
Stronger Wheel + Wider Tire + Longer Tire Life = Extra 4.4 Pounds with a flush look of a 10mm spacer in the rear. Extra 1.1LB per wheel.
Car Grips loads better and looks sharp!!
Total Cost is roughly 1.8k. :happy0180:
After coils 2.8k.
-NickFRS
BRZranger (08-16-2012)
Old 08-16-2012, 03:47 AM   #3
BRZranger
Nice setup, similar to the look I'm going for.
I got V12s in the mail, what do you think about them so far? They are rated high in reviews and they are really cheap. I spent $560 out the door for 4.
I was also seriously considering the PF01's in 18 but I ended up getting TSW Nurburgrings in gun metal.
BRZranger is offline   Reply With Quote
Old 08-16-2012, 05:07 AM   #4
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Looks good, Nick! Added to the Wheel Directory:
http://www.ft86club.com/forums/showthread.php?t=7535
Old 08-16-2012, 05:59 AM   #5
Wusaa
Newbie
Wusaa's Avatar
Drives: 2013 BRZ ;2004 RX8 GT (SOLD)
all u need now is slam ur ride =)
Wusaa is offline   Reply With Quote
Old 08-16-2012, 07:25 AM   #6
fluffy-reindeer-slayer
Drives: fr-s and tc2
nice ride thanks for the info
fluffy-reindeer-slayer is offline   Reply With Quote
Old 08-16-2012, 09:48 AM   #7
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, Miata
Just curious, are you using the stock lug nuts for your Enkeis? I thought the stock lugs have a ball/radius seat while the Enkeis require conical seat lugs.
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'95 Miata (Montego Blue)
ft86Fan is offline   Reply With Quote
Old 08-16-2012, 11:13 AM   #8
DarrenDriven
NW Region Moderator
No, he isn't using his stock lugnuts because his stocks are in a bag in my garage.
The Following User Says Thank You to DarrenDriven For This Useful Post:
ft86Fan (08-16-2012)
Old 08-16-2012, 04:08 PM   #9
NickFRS
Indeed Darren does. I'm using am lugs that are really cheap... Buying some rays lug nuts or something soon. With this set up I wanted to stay close to stock weight with slightly more width in the tire. With our cars unless you slap a turbo on it wider tires don't improve the performance of the car. So this is my simple wheel fix!! Also there is only a extra 2.2 pounds and 1 inch more rubber in width in total on the power wheels... Car still burns em off... Chirps 2nd.... Just hugs the road better now! And yea these tres are cheap but feel more expensive then what they actually are.
P.s 18in wheels look better on our cars but simply kill performance I believe.
Old 08-16-2012, 04:29 PM   #10
BRZranger
Yes and no, a light 18 with sticky tires will be better than oem on stock tires.
Even the Road and Track wheel and tires comparison highlights this.
I do agree that a comparable 17 will be better for performance. I also noticed Moto-P is running very light 18s and doing well on the track.
For me, I have a light 18 with sticky tires. I kept the new size near oem sizing too. I'll add a review after install and some miles
Old 08-16-2012, 04:44 PM   #11
NickFRS
Indeed it all depends how much contact point and weight you are adding. In my case it's not much. But with most 18in set up people are running its killing their cars performance.
Old 11-20-2012, 06:53 PM   #12
ShoShin
ShoShin's Avatar
Drives: WRB Premium
Nick, can I get a shot of the entire car from the side under daylight?
Thankss
ShoShin is offline   Reply With Quote
The Following User Says Thank You to ShoShin For This Useful Post:
stout90 (11-21-2012)
Old 11-26-2012, 07:18 PM   #13
fender9530
fender9530's Avatar
Drives: Asphalt FR-S
Did you use hubcentric rings? If so, where did you find them?
fender9530 is offline   Reply With Quote
Old 11-26-2012, 10:37 PM   #14
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Amazon has a good price on them, i got Gorilla ones for $9.
Wheel Directory: Enkei RPF1 17x8.0 +45 track_warrior Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 163 03-17-2022 03:00 AM
Wheel Directory: Enkei PF01 17x7.5 +38 FRSFirestorm Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 06-19-2017 11:36 PM
Wheel Directory: Enkei RS+M 17x8.0 +35 FT-86 SpeedFactory Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 37 02-12-2014 05:26 PM
Wheel Directory: Enkei Kojin 17x8 +45 abutterman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-29-2013 05:24 PM
Wheel Directory: Enkei GP5 17x8 +45 Books Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 07-09-2013 04:46 PM
