Old 08-16-2012, 11:32 AM   #15
fatoni
Originally Posted by gwascopter View Post
dont know why people compare these 2cars cuz they are completely diff class
they dont see a different class considering how similar their times were
Originally Posted by switchlanez View Post
Amazing how the BRZ is 100 lbs. lighter. One conventional advantage of FWD is its shorter drive shaft is supposed to translate to lighter curb weight. The BRZ flips that idea on its head.
or maybe its just because the brz is so much smaller. fwd is lighter than rwd
Old 08-16-2012, 11:33 AM   #16
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
18'' wheels
Sunroof
Bigger body
Steel hood
If they was the same size and the options was base then it would be closer.
SUB-FT86 is offline   Reply With Quote
Old 08-16-2012, 11:36 AM   #17
Giccin
Giccin's Avatar
Why the hell do people make such a damn big deal on the prius tires?
You'd LEAVE the car because of the stock tires? Jeez.
I am the Ice Queen.
Logic > Emotion
┬──┬◡ノ(° -°ノ)
TOYOTA FT-86
Old 08-16-2012, 11:51 AM   #18
SupraLove
Drives: 2007 Toyota Camry LE, 5AT i4
Originally Posted by 86'd View Post
Despite it being an econobox after all of these years, the SI is still a very very good car.
Turn it into a sedan and it's a WAY better DD than the BRZ.
The reasons why I didn't buy a Civic this time around, is 1. I've owned 2 already (2000, 2002), 2. I think it needs a bit more power, 3. It's a Civic; I wanted something a bit more adult.
Ironically the BRZ, despite being a bit more impractical and driver focused, seems more adult to me.
It's funny how defensive you guys get when a car like the Civic "competes," don't be, because it doesn't. You buy the BRZ/FRS partly for the feeling and that's something the Civic will never have, or in my case regain.
But... BUT IT'S GOT VTAK!
SupraLove is offline   Reply With Quote
Old 08-16-2012, 11:57 AM   #19
empower-auto
Kouki-Monster
empower-auto's Avatar
lol .. these garbage tires are the achilles-heel of this car - always.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 08-16-2012, 12:12 PM   #20
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Anyone notice how much the Civic leans into the curves vs the BRZ at higher speeds ?
As far as I'm concerned the only car her that deserves a bow is the one that's not giving one in the curves
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 08-16-2012, 12:16 PM   #21
fatoni
swap tires and see which one is bowing
Old 08-16-2012, 12:43 PM   #22
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
On the BRZ or Civic ? If your referring to the BRZ, my comment was meant as a compliment to the BRZ which already has not so great of tires
2URGSE
Old 08-16-2012, 12:45 PM   #23
fatoni
i was just referring to the amount of lean evident in both cars. the more tire you have, the more the car will lean
Old 08-16-2012, 12:51 PM   #24
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Ahh, yeah I just felt there was less bodyroll from the BRZ than the civic in the curves, at least from what I could see from the video
2URGSE
Old 08-16-2012, 12:54 PM   #25
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Every track test is meaningless unless the most important thing on the cars is equal. As long as the cars have different tires.... overall lap time tests are a waste of time.
Put the Piloti Sports on the BRZ, retest. Also I hate seeing FWD drive cars on road courses with what is a factory suspension. The reason is that all OEM suspension setups on FWD cars are designed for safety which = Massive Understeer. Transversely, with most RWD setups, even those that are understeery like the BRZ, can still utilize the throttle to overcome it. So take the Civic and stiffen the rear, adjust the front toe and retest.
I understand the need to test "stock for stock" but the OEM's often make REALLY stupid decisions about street-going cars; AKA: understeery-setups for safety, Prius tires on a sports car etc etc etc. So these tests don't really compare the "platform" all that well.
Old 08-16-2012, 01:10 PM   #26
fatoni
i know. im saying that it is largely due to the civic having stickier tires. well that and overall design...but largely the tires
thats a totally arbitrary mindset. i could just as easily say that track tests are meaningless unless power is the same or weight is the same. throwing in those tires at that price is an advantage for the civic, plain and simple. the only thing that i think should be used to level the playing field is dollars.
Old 08-16-2012, 01:14 PM   #27
Chauntalei
Drives: Non-BRZ
Is it just me or did they completely leave out the fact that the BRZ has an LSD as well? They make such a big deal of it in the Si, like it's some huge advantage that it has over the BRZ.
Chauntalei is offline   Reply With Quote
Old 08-16-2012, 01:27 PM   #28
MRZ415
Drives: 2015 Subaru WRX
I personally think the Stock tires are a plus since it does have LESS grip,
so its easier to SLIDE around a corner compare to super sticky tires which
will improve lap times but make me possibly smile a bit less.
MRZ415 is offline   Reply With Quote
Honda Civic Type R 1.6 Turbo Symbiont Other Vehicles & General Automotive Discussions 5 07-31-2012 11:57 PM
ATD Detailed - 2010 Honda Civic boredstudent3 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 07-10-2012 02:26 PM
AutoExpressUK: Honda Civic Type R is back quik1987 Other Vehicles & General Automotive Discussions 36 10-18-2011 01:15 PM
2012 Honda civic VenomRush Other Vehicles & General Automotive Discussions 38 05-17-2011 04:26 PM
1995 Honda Civic DX - Brake Lights Siriusly.Andrew Other Vehicles & General Automotive Discussions 7 02-18-2011 07:14 PM
