| AUSTRALIA Australia and New Zealand |
#29 | |
Drives: Slowly
#30 | |
Because compromise ®
Drives: Red Herring
Sorry,I am pedantic and my friends get amused and annoyed with me in equal measure. |
#31 |
Drives: RA23
Real questions seems to be - whats the best fuel for the 86?
#32 |
Drives: Red Herring
Fuel? I thought we discussing engine oil. |
#33 |
Drives: RA23
Yep, but apparently using wrong kind of fuel on this car causes pinging.
#34 |
Drives: Altezza RS200-Z 6MT
Use 98 & you shouldn't have a problem. (although after reading this post maybe not http://www.ft86club.com/forums/showthread.php?t=13827 )
Back on topic, I'd stick with 0w-20 or 5w-30 to avoid any warranty issues. If you want extra protection use Amsoil, Redline or Motul. http://www.ft86club.com/forums/showt...213#post392213 Last edited by SXE10; 03-17-2013 at 04:23 PM. |
#35 |
Australian and Proud !!!!
Drives: 2012 Toyota 86 GTS Aero Kit
Ive used the HKS 0-25w oil and my car likes it, I have seen very little in the way of Oil usage and im upto 8000km already 2nd oil change just finished and used about 0.25 litre in that time
BONKRS for life
#36 |
Drives: BRZ WRB
warmed to 90C , OW20 shows only 0,9-1,0 bar pressure idling
kinda scares me, I 've never used such waterish oils but still, if it's prescribed in the service manual, should be fine |
#37 |
Oil with a low viscosity reduces frictional losses. However, oil is also responsible to seal the combustion chamber properly:
The oil film between the piston ring and the cylinder wall can tear off if the oil film has a low viscosity. This reduces the combustion pressure and with it power. Racing engines usually run thus on an oil with a high viscosity. http://pitstopusa.com/i-8583247-motu...ase-of-12.html In short: Using an engine oil with a low viscosity may actually result in less power despite the fact that the frictional losses are reduced. |
#39 |
Drives: 2012 86GTS Race Car #86
We are going to run the Royal Purple XPR 5w 30 at Bathurst (Easter). We have the HKS oil cooler... Once we are done we will have the oil tested..
Practice, Qualifying, 2 x 30 minute sprints and a 1 hour enduro... it will be interesting to see the change in pressures and temps from the genuine oil it has at present.. still only have 530k's on the clock. We will take some heavier weight in case the conditions get very warm.. I suspect not though given the weather in NSW lately. |
#40 |
Have you thought about using Motul 300V 5w30? It doesn't get much better than that off the self. Be worth while getting a UOA done on the RP to see how its holding up
rx3 put some 20w60 in your BRZ & let us know how you get on Your whole statement is incorrect. Most race engines will run a thinner oil in qualifying to gain more HP. Do some reading on HT/HS. BITOG is a great place to learn from http://www.bobistheoilguy.com/motor-oil-101/ Last edited by SXE10; 03-17-2013 at 08:22 PM. |
#41 |
Drives: Red Herring
#42 |
If you'd read 000 Racing post you'd see he is using is car for racing...
| The JZ engine? | speedy07 | Engine, Exhaust, Transmission | 35 | 04-12-2012 01:18 PM |
| What will the engine need to go FI? | suprachica79 | Engine, Exhaust, Transmission | 90 | 11-29-2011 11:46 PM |
| STI engine | Aldo the Apache | Engine, Exhaust, Transmission | 49 | 11-03-2011 09:36 PM |
| FT 86 Engine | jayjayjayjay | Engine, Exhaust, Transmission | 15 | 01-18-2011 02:22 PM |
