Drives: fast
don't lift
does this apply in the FRS? i know some cars are susceptable to lift off oversteer but the frs doesn't seem to be one of them. what would be a situation you wouldn't want to lift in the frs?
#2 |
Drives: Whiteout FR-S
When you are approaching the limits of traction in a corner, do not lift. Lifting at the limits of grip will upset the balance enough to induce oversteer. Unless you are trying to drift on purpose, don't do it.
| The Following 3 Users Say Thank You to robo_robb For This Useful Post: |
#3 |
Drives: fast
what if you're at the limits of grip in a long corner, 50% throttle, and the rear starts coming out? what do you do in that situation?
#4 |
It doesn't snap like an s2000 but like any car you will get the back end out if you lift... which is usually undesirable.
Worst time to lift would be when you crest a hill during a turn. Any time you already have weight trying to shift off the rear. |
| The Following User Says Thank You to alyon For This Useful Post: | mines13 (08-15-2012) |
#7 |
Kudos for all the intelligent responses. This thread could have gone south pretty easily. It is very refreshing. As mentioned, you can ease out of it or ride it out. Can't recommend the latter unless you don't mind getting dirty and there is nothing to hit when/if you yard sale.
#8 |
Drives: fast
#9 |
Registered you sir
Drives: 99 impreza coupe
Low power RWD, dont lift.
But get some alone time with the car so you can figure out how to react in the aftermath of a sloppy corner. |
#10 |
ZC6A2B82KC7J
Drives: 2002 WRX
When in doubt, throttle out
#11 |
Back From The Dead
#12 |
It's not a FWD vs. RWD issue, it's a chassis balance issue. On my RSX (read: FWD) with thicker rear sway bar and coilovers, you could get the back end to rotate at will if you lifted mid-corner. Just the way the car was setup.
#13 |
Drives: 2013 Hot lava Fr-s, 2007 Mazda 3
I've found lifting RIGHT when your on that "limit" with this car is the quickest way to fudge things up UNLESS you want to get sideways. (not saying i wrecked the car or even came close). But right as you lift out of fear of getting sideway the engine and trans shift enough to just hose the balance and the rear will whip out a bit ....if not alot depending on how over that limit you were.
Raising the bar one step at a time!
Kansas City FR-S/BRZ Facebook group. https://www.facebook.com/groups/452909128083343/ Hotlava86's Build thread!http://www.ft86club.com/forums/showthread.php?t=14152 |
#14 |
Drives: 4 wheels
Always look where you want to go also tend to help.
| The Following User Says Thank You to Pekingduck For This Useful Post: | DjDATZ (08-16-2012) |
| RedLine Tuning Hood Quick Lift | tonystewart | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 12-15-2012 12:28 PM |
| Home Car Lift | SEC | Other Vehicles & General Automotive Discussions | 10 | 08-20-2012 10:17 AM |
| New Official WRB Subaru BRZ Video from Geneva "Lift" | gt86mods | BRZ Photos, Videos, Wallpapers, Gallery Forum | 13 | 03-06-2012 10:25 PM |
