Old 08-15-2012, 03:38 PM   #1
pr086
Drives: fast
don't lift
does this apply in the FRS? i know some cars are susceptable to lift off oversteer but the frs doesn't seem to be one of them. what would be a situation you wouldn't want to lift in the frs?
pr086 is offline   Reply With Quote
Old 08-15-2012, 03:58 PM   #2
robo_robb
robo_robb's Avatar
Drives: Whiteout FR-S
When you are approaching the limits of traction in a corner, do not lift. Lifting at the limits of grip will upset the balance enough to induce oversteer. Unless you are trying to drift on purpose, don't do it.
robo_robb is offline   Reply With Quote
The Following 3 Users Say Thank You to robo_robb For This Useful Post:
mines13 (08-15-2012), Propaganda (08-15-2012), Username (08-15-2012)
Old 08-15-2012, 04:03 PM   #3
pr086
Drives: fast
what if you're at the limits of grip in a long corner, 50% throttle, and the rear starts coming out? what do you do in that situation?
Old 08-15-2012, 04:03 PM   #4
alyon
It doesn't snap like an s2000 but like any car you will get the back end out if you lift... which is usually undesirable.
Worst time to lift would be when you crest a hill during a turn. Any time you already have weight trying to shift off the rear.
alyon is offline   Reply With Quote
The Following User Says Thank You to alyon For This Useful Post:
Old 08-15-2012, 04:06 PM   #5
KevinR
Drives: 1993 Turbo Miata, 2013 Asphalt FR-S
I'd maintain throttle and countersteer and hold until the rear end comes back
Sent from my ADR6300 using Tapatalk 2
KevinR is offline   Reply With Quote
The Following User Says Thank You to KevinR For This Useful Post:
Old 08-15-2012, 04:06 PM   #6
alyon
Either slowly reduce throttle or ride it out at 50% letting it correct itself. First would be safer.
Old 08-15-2012, 04:09 PM   #7
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
Kudos for all the intelligent responses. This thread could have gone south pretty easily. It is very refreshing. As mentioned, you can ease out of it or ride it out. Can't recommend the latter unless you don't mind getting dirty and there is nothing to hit when/if you yard sale.
mines13 is offline   Reply With Quote
Old 08-15-2012, 04:26 PM   #8
pr086
Drives: fast
but thats the thing, in a FWD car you could lift any time any place and its not going to make a difference. at least in my car.
Old 08-15-2012, 04:29 PM   #9
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Low power RWD, dont lift.
But get some alone time with the car so you can figure out how to react in the aftermath of a sloppy corner.
chulooz is offline   Reply With Quote
Old 08-15-2012, 04:30 PM   #10
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
When in doubt, throttle out
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 08-15-2012, 04:33 PM   #11
FakeWhiteMan
Back From The Dead
Drives: Hot Lava FR-S
Send a message via AIM to FakeWhiteMan
Nah, in my Cobalt SS I could lift oversteer with ease. Same with my friends MINI Cooper S...
FakeWhiteMan is offline   Reply With Quote
Old 08-15-2012, 04:34 PM   #12
DarkSunrise
DarkSunrise's Avatar
It's not a FWD vs. RWD issue, it's a chassis balance issue. On my RSX (read: FWD) with thicker rear sway bar and coilovers, you could get the back end to rotate at will if you lifted mid-corner. Just the way the car was setup.
Old 08-15-2012, 04:45 PM   #13
Hotlava86
Hotlava86's Avatar
Drives: 2013 Hot lava Fr-s, 2007 Mazda 3
I've found lifting RIGHT when your on that "limit" with this car is the quickest way to fudge things up UNLESS you want to get sideways. (not saying i wrecked the car or even came close). But right as you lift out of fear of getting sideway the engine and trans shift enough to just hose the balance and the rear will whip out a bit ....if not alot depending on how over that limit you were.
Raising the bar one step at a time!
Kansas City FR-S/BRZ Facebook group. https://www.facebook.com/groups/452909128083343/
Hotlava86's Build thread!http://www.ft86club.com/forums/showthread.php?t=14152
Hotlava86 is offline   Reply With Quote
Old 08-15-2012, 04:49 PM   #14
Pekingduck
Drives: 4 wheels
Always look where you want to go also tend to help.
Pekingduck is offline   Reply With Quote
The Following User Says Thank You to Pekingduck For This Useful Post:
DjDATZ (08-16-2012)
RedLine Tuning Hood Quick Lift tonystewart Cosmetic Modification (Interior/Exterior/Lighting) 4 12-15-2012 12:28 PM
Home Car Lift SEC Other Vehicles & General Automotive Discussions 10 08-20-2012 10:17 AM
New Official WRB Subaru BRZ Video from Geneva "Lift" gt86mods BRZ Photos, Videos, Wallpapers, Gallery Forum 13 03-06-2012 10:25 PM
