Old 08-15-2012, 12:41 AM   #15
vubaru
Now with Boost!
vubaru's Avatar
Drives: 2013 SWP BRZ Ltd.
Unleashed is 100% right. If I recall correctly, they may have indicated they won't even support the FR-S/BRZ at all.
The RaceROM launch control and other features are going to be a free update for the Visconti/Ecutek package so it's not like you have to pay extra for it as far as I understand, just a cool feature.
vubaru is offline   Reply With Quote
Old 08-15-2012, 12:43 AM   #16
Unleashed
Unleashed's Avatar
Drives: 13' WRX
Thanks and you are 100% right as well. EcuTek has really grabbed a hold of the FR-S/BRZ and John is doing amazing work.
Unleashed is offline   Reply With Quote
Old 08-15-2012, 01:26 AM   #17
Lytheum
Drives: 2013 BRZ Premium 6MT
Originally Posted by pcasso87 View Post
Apparently Cobb and direct injection dont mix very well. A lot of MS3 owners with blown engines.
not many blown engines lately with the mzr disi. there were a lot in the early days due to lack of tune with lots of mods. the ap is the way to go with that motor.
2013 Subaru BRZ Premium 6MT -STOCK!
Lytheum is offline   Reply With Quote
Old 08-15-2012, 01:42 AM   #18
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Originally Posted by CBR600RR View Post
What are the other benefits?
Use it to spool the turbo before launch
Consistent drag launches. And it hints at a boost-by-gear function, of sorts. Limit throttle opening for lower gears for better traction. keeps the revs from getting away from you.
I'm guessing there is a ton of stuff we'll be able to do with the factory computer.
Coheed is offline   Reply With Quote
Old 08-15-2012, 02:50 AM   #19
Entropy
Oversteer > Understeer
Entropy's Avatar
Drives: GT86
Entropy is offline   Reply With Quote
Old 08-15-2012, 03:05 AM   #20
chuy21
Drives: 2009 Cobalt SS 373 FWHP 431 Lb-Ft
I thought turbos couldn't make boost untill under load? When I use launch control on my cobalt it just takes me out of vacuum and hold it at 0 psi.
chuy21 is offline   Reply With Quote
Old 08-15-2012, 03:28 AM   #21
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
The difference, versus just holding the revs using the throttle, is with launch control you are at WOT.
uspspro is offline   Reply With Quote
Old 08-15-2012, 03:40 AM   #22
GenkiElite
GenkiElite's Avatar
Drives: 91 Corolla (dd) S14 (daily drifter)
Originally Posted by Memphis View Post
Anyone ever notice that you could play snake while the you tube video is loading???
Just press an arrow key and the circle dots start moving in that direction and there is a random dot on the screen that you can get....
Hahaha! No. It loads too fast lol. First world problem
GenkiElite is offline   Reply With Quote
Old 08-15-2012, 03:53 AM   #23
Coheed
Coheed's Avatar
You can build boost by loading the engine with the timing tables in the tune. Retarded timing and extra fuel can spool lots of boost. 1 bar isn't uncommon when tuned for anti-lag.
Old 08-15-2012, 05:25 AM   #24
Calum
That Guy
Drives: 2013 asphalt FRS MT
I can't wait to try this!!
Old 08-15-2012, 10:25 AM   #25
Memphis
Memphis's Avatar
Drives: Scion FantasticRoad-Sex
Happens when too many people are on the interwebz here at the same time.
Memphis is offline   Reply With Quote
Old 08-15-2012, 10:33 AM   #26
TheRipler
Reap the BReeZe
Drives: 04 LandShark STi
Surprised no one has complained yet about bouncing off the rev limiter.
TheRipler is offline   Reply With Quote
Old 08-15-2012, 11:18 AM   #27
sandman126
Slide Ways
sandman126's Avatar
Drives: 2013 SWP BRZ, 85 VW Golf
Exactly, i had launch control on my 05 legacy gt and i would build about 12.5 psi. Improved my 0-60 times dramatically...plus it sounded dope
sandman126 is offline   Reply With Quote
Old 08-15-2012, 05:57 PM   #28
d1ck
Drives: Black 2013 FRS
You're right - almost. Anti lag works by cheating a little. It retards the ignition timing to like 20 deg after top dead centre so that you get combustion in the exhaust port and manifold. By doing this less of the combustion energy is used by the engine, and instead it spins the turbine. This is known to be hard on manifolds (hope it's cast!) as well as turbines (Hard on the bearings).
d1ck is offline   Reply With Quote
EcuTek Tuning in Australia 86drift AUSTRALIA 46 09-01-2012 06:48 AM
EcuTeK tuning available *BRZ & FR-S* Cotnoir Engine, Exhaust, Transmission 29 07-11-2012 07:15 PM
Launch control with auto trans Dbringer Scion FR-S / Toyota 86 GT86 General Forum 3 06-12-2012 04:54 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 11:20 AM
Launch Control on Auto? devinclfalcons Engine, Exhaust, Transmission 28 03-01-2012 07:14 PM
