Old 08-14-2012, 10:07 PM   #43
Subie
Seρor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
The cabin cools VERY quickly, and stays cool thanks to both a well-designed A/C system and the window film I had installed not long after purchase. I'm very satisfied with it.
Subie is offline   Reply With Quote
Old 08-15-2012, 12:11 AM   #44
vubaru
Now with Boost!
vubaru's Avatar
Drives: 2013 SWP BRZ Ltd.
I actually haven't had any problems with the auto or manual setting on the Limited's climate control system.
The climate control in the BRZ is the best I've had in a Subaru so far in my experience. No complaints whatsoever about the climate control and the car heats and cools extremely efficiently. Overall, I'm quite pleased with it.
vubaru is offline   Reply With Quote
Old 08-15-2012, 07:10 PM   #45
Turbowned
Turbowned's Avatar
Does it work as well as your Mercedes? If it does, than I'm sure I'll be pleased with it, too. The auto climate in my mom's '00 E320 works well, pick a temp and it sets it, done.
Old 08-15-2012, 11:58 PM   #46
WRXcellent
Drives: 2013 BRZ Limited WRB & 2002 WRX WRB
I use Full Auto all the time and it works properly for me, colder AC when it needs to and warmer when it doesn't.
WRXcellent is offline   Reply With Quote
Old 08-16-2012, 06:18 PM   #47
JAG
Drives: 2013 Subaru BRZ Limited (Red 6MT)
Is it hot in here?
Nah, it's a perfect 86!!
JAG is offline   Reply With Quote
The Following 2 Users Say Thank You to JAG For This Useful Post:
SuperDave (08-17-2012), Z3D (02-21-2013)
Old 08-16-2012, 09:35 PM   #48
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
My climate control works great and the duel zone also.
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 08-17-2012, 01:11 AM   #49
bryan
bryan's Avatar
Drives: Lots of Toyotas
Originally Posted by Jayde View Post
Also, curious, but does anyone notice that if you turn the controls on, the AC comes on as well? I'd be nice if it didn't do that, since I have to turn it off right after if I'm not going to use it. I have a feeling it'll put more wear on it in the future.
I've noticed the same thing and I hate it. The AC as well as the "recycle" air comes on ever time I turn the HVAC on. I keep having to turn both off constantly.
My toyota's HVAC remembered the last setting it had before it was turned off. I would prefer it that way.
I've tried playing with the HVAC controls - setting the temperature to the eighties hoping that the AC would not turn on when the fan was turned on... still didn't work. The AC turns on EVERY SINGLE TIME!
They definitely got the car's driving dynamics right. But it's the little things like this and the poor signal quality of the nav system that are bothersome.
bryan is offline   Reply With Quote
Old 02-21-2013, 09:41 PM   #50
Brzetto
Drives: 4 wheels
I'd like to be able to turn on the air system without the A/C coming on.....
Brzetto is offline   Reply With Quote
Old 02-21-2013, 09:58 PM   #51
Z3D
Mine sucks, weird bugs after I went to a massDOT inspection station.
Z3D is offline   Reply With Quote
Old 02-21-2013, 10:24 PM   #52
RAWR BRZ
Drives: 2010 BMW M3, 2013 Subaru BRZ
Mines never on I have it set so air just flows in. It is only on when it is hot as hell and im starting to sweat or when it is cold as hell and i need heat. Otherwise sometimes I want it to flow cold air in but it flows hot air... so i have to turn it on and as i expected it will be set to heat because of the auto climate (i keep it at 72 all the time) and I have to set it to around 65-68 then then it off for it to flow cold air in.
RAWR BRZ is offline   Reply With Quote
Old 02-21-2013, 10:31 PM   #53
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
When I set all my air controls to OFF, I still feel air recirculating in the cabin at whatever temperature the climate control was set to. So if it was set to 65 before I shut it off, I still feel cold air in the cabin long after shutting it off. Or if it was at 85, I feel warm air circulating long after it's off. I feel this regardless of the cabin recirculation button being lit (outside air vent is closed) or not and regardless of temperature outside.
Anyone else experience this?
Old 02-21-2013, 10:39 PM   #54
OrbitalEllipses
Drives: Attitude
I have seen this in this car and other cars. Still blows VERY slightly when OFF.
switchlanez (02-21-2013)
Old 02-21-2013, 10:44 PM   #55
switchlanez
Ok so I'm not the only one. Whew -_-
Old 02-21-2013, 11:07 PM   #56
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
The thing with the Limited's climate control is that you're setting cabin temp, not incoming air temp. Set it to something comfortable and let it do its thing. I have mine set to 72 and it keeps the cabin temp very comfortable. I'm happy with how the system works is both Summer and Winter.
Easy. Just hit Auto then the A/C button. It'll still change temp, fan speed, and vent direction automatically.
I just close the vents on the dash and let the HVAC take care of the rest.
BRZ -> FRS Climate Controls Retrofit? kndonlee Cosmetic Modification (Interior/Exterior/Lighting) 21 05-26-2015 02:34 AM
Ground Control is working on some stuff for us :) D1cker Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 07-24-2012 06:21 PM
Traffic Nav Not working on my BRZ Indestruct Electronics | Audio | NAV | Infotainment 9 06-19-2012 09:38 PM
Auto climate control Daemione Electronics | Audio | NAV | Infotainment 37 06-05-2012 09:19 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 11:20 AM
