View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 08-14-2012, 02:10 AM   #687
Tanuki
Turtle Factory
Tanuki's Avatar
Drives: Mint M3
I am not really concerned with the sound. My only worry is if there is a long term negative affect from whatever is causing the the chirp?
Tanuki is offline   Reply With Quote
The Following 2 Users Say Thank You to Tanuki For This Useful Post:
alrashwa (08-14-2012), Marrk (08-14-2012)
Old 08-14-2012, 05:12 AM   #688
sierra
Drives: Skoda Yeti DSG diesel 4x4
Originally Posted by alrashwa View Post
It's already been pretty well documented that even a little 2-cycle engine oil can help reduce the noise.
It doesn't help reduce it, it shuts it up totally even at 1000:1
sierra is offline   Reply With Quote
The Following User Says Thank You to sierra For This Useful Post:
Old 08-14-2012, 12:11 PM   #689
alrashwa
alrashwa's Avatar
Drives: '12 370Z Monterey Blue
Sierra, I'd be interested to know how you are getting it in there. I assume you mixed it into a small fuel canister. What volume of 2-cycle are you using per fill-up?
alrashwa is offline   Reply With Quote
Old 08-14-2012, 05:44 PM   #690
brianbot5000
brianbot5000's Avatar
Drives: White WRX Hatchback, Toyota Pickup
Interested in this as well. And though it may have been posted 10 pages ago, can you also list what brand/kind of oil you're using? Thanks!
2013 Subaru BRZ, SSM Limited
vin: 6007xx
build: 3/2012
brianbot5000 is offline   Reply With Quote
Old 08-14-2012, 05:50 PM   #691
Reason
Reason's Avatar
Drives: Whiteout 6MT FR-S; E30 BMW's
Originally Posted by empower-auto View Post
My car just starting doing this at 1500 miles. It's never had ethanol in it.
This is interesting
Where do you fill up with gas? Can you confirm they don't use Ethanol?
Reason is offline   Reply With Quote
Old 08-14-2012, 05:55 PM   #692
empower-auto
Kouki-Monster
empower-auto's Avatar
Originally Posted by Reason View Post
This is interesting
Shell. 91 V-Power always. There's supposed to be 0 Ethanol in 91 Shell here. The only V-Power I have ever known to have Ethanol is the 93 stuff and they indicate it.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 08-14-2012, 06:21 PM   #693
alrashwa
alrashwa's Avatar
Originally Posted by roddy View Post
Agreed.
However, in my case, Ethanol free gas is available, and that stopped the chirping for me. I didn't hear a peep out of it today. Until Toyota/Scion/Subaru come up with a solution, getting gas without ethanol, or adding something like this http://www.lucasoil.ca/products/prod...&cat=HeavyDuty should do the trick. Adding 4-5 ounces per tank of good 2-stroke oil may also work. I was a little concerned about this option at first, but after reading in the owner's manual that burning 1.1 liters of engine oil for 600 miles of driving is not considered excessive, 4-5 ounces per tank is peanuts.
IF they ever give me my car back, I'll have to try this vs. paying the premium for 92 octane boat engine gas.
Old 08-14-2012, 06:22 PM   #694
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
So, I've been having the chirping noise for the last 4000 miles, and it's pretty annoying.
I was down at Autozone the other day to pick up some other things, and bought some of this on a whim: http://www.stp.com/products/fuel-add...ctane-booster/
Added it with a full tank of 91 at Chevron, where I always fill up. An hour later the crickets were gone. Hot engine, cold starts, at night (65 degrees F) and during the day (95 degrees F). I heard it all the time before and now it's just... not there.
I am very excited, even if it means buying a 4.50USD bottle of this stuff every fill up. That noise was driving me to distraction, even if I still loved my car.
I wouldn't use that in my car even if it quiets the chirp. Most "octane boosters", including the one you're using, contains a bunch of kerosene and a little bit of MMT (Methylcyclopentadienyl Manganese Tricarbonyl) to raise the octane, which is bad news for any car with a catalytic converter. During combustion, the manganese is liberated from the compound. This manganese vapor is then deposited on your spark plugs and in the fine mesh structure of your catalytic converter. The deposits in the catalytic converter can significantly obstruct exhaust flow and impede the ability of the cat to do its job with regards to NOx emissions.
MMT will not make your octane nearly as high as high as the feel of it in your engine would seem to lead you to believe. This is because MMT makes your fuel denser and burn slightly longer giving you additional torque than simply higher octane couldn't achieve. This process also can have the unfortunate result of contributing to gunk build up in the injectors and valves, especially if used in excess of .8 oz per gallon.
The Following User Says Thank You to ATL BRZ For This Useful Post:
Marrk (08-14-2012)
Old 08-14-2012, 06:46 PM   #695
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Octane booster did not change anything for me. 2oz of 2-cycle oil has done the trick though. No noticeable side-effects. Super low ash formula.
cobrabyte is offline   Reply With Quote
The Following 2 Users Say Thank You to cobrabyte For This Useful Post:
ill86 (08-15-2012), sierra (08-14-2012)
Old 08-14-2012, 11:02 PM   #696
sierra
Currently my GTS 86 is on order and I drive a Mitsubishi Triton with a 2.5 common rail T diesel that uses very high fuel pressure. I always add 2T to it when I fill up at 200:1
It's been proven to shut the chirp up at 1000:1 in the 86.
I use it in my diesel because it's quieter, gets better mpg and compensates for the low lubricity of recent very low sulphur diesel to ensure it lasts like they used to.
When I fill up I glance at the trip odometer which I always zero at the pump because i'm fuel consumption obsessive and keep a log. It's easy with metric to work it out and I know since I average 8L/100km that 600km means 48L which is 240ml of 2T at 200:1. The 1L container has a measure window so I just tip about 250ml into the tank and then fill up, it doesn't need to be exact.
I'll translate that into US figures for the 50L 86/BRZ tank.
13.2USG = 1690oz
So for the first fill up add 1690 divided by 1000 = 1.7oz
Using 30mpg we get about 400miles to a tank.
That's 0.1oz for every 25miles at each fill up after that. So for 280miles add 1.1oz. That's easy enough to do in your head like I do at the pump.
Use a high quality 2 stroke oil with very low ash content which will clean, lubricate and combust completely.
Can someone please check my figures?
The Following 2 Users Say Thank You to sierra For This Useful Post:
alrashwa (08-14-2012), ill86 (08-15-2012)
Old 08-14-2012, 11:15 PM   #697
roddy
roddy's Avatar
Drives: '13 Ultramarine
That post you quoted is from a while ago and I have had time to experiment a bit more since then. I have found that as little as 1-2 oz of good quality 2-stroke oil will do the trick. I just add a small amount directly to the tank, then fill it with gas. From what I have seen and done, sierra's comments are pretty much spot-on (I didn't check his math though...).
The Following 2 Users Say Thank You to roddy For This Useful Post:
alrashwa (08-14-2012), sierra (08-14-2012)
Old 08-14-2012, 11:30 PM   #698
alrashwa
alrashwa's Avatar
Thanks a ton guys. My friend at Toyota Japan even recommended this method, so I'd say it's a solid one.
The Following User Says Thank You to alrashwa For This Useful Post:
ill86 (08-15-2012)
Old 08-14-2012, 11:45 PM   #699
Marrk
Drives: Honda Fit
13.2USG = 1690oz
With all due respect, you have given an awful lot of advice regarding what other people should put in their cars, and you have spoken with abundant authority on the subject, and yet you do not even own one of these cars, nor do you have any firsthand experience with one. I wish you would disclose this before posting each and all of your future statements. Just begin by saying, "I don't have a car, but here's what you guys should do with your cars." 'Kay?
Marrk is offline   Reply With Quote
Old 08-14-2012, 11:47 PM   #700
sierra
That is good to hear! Thanks for that.
It's been used in car engines for many reasons for years without any negative reports that I've ever seen, only positive results.
I know that some worry about warranty but it's being used in tiny quantities to solve a problem until they can engineer a fix, if they actually bother? Until then it compensates for the negative effect of the ethanol.
I only harp on about it because I feel it's a good thing that's very easy and cheap to do until it gets fixed. You can also be pretty confident it wont deteriorate.
ill86 (08-15-2012)
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 10:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
