Old 08-14-2012, 02:11 PM   #1
Memphis
Memphis's Avatar
Drives: Scion FantasticRoad-Sex
Improper spring installation warning
Moderator Update: Please read further along in this thread as the initial information was incorrect. The damage caused to this vehicle's dampers is believed to be installation related, and NOT related to the springs that were installed.
My friend Chris has around 4000 miles on his FRS and he installed Eibach Sportlines on his car and as of today his shocks are busted.
Going 1.4 inches lower on stock shocks is a no go.
Memphis is offline   Reply With Quote
The Following 5 Users Say Thank You to Memphis For This Useful Post:
BRZranger (08-14-2012), NeedsmoreCowbell (08-14-2012), tnt (08-14-2012), Wes (08-19-2012), Wolfking (08-14-2012)
Old 08-14-2012, 02:14 PM   #2
tnt
Drives: argento frs at
good to know
tnt is offline   Reply With Quote
The Following User Says Thank You to tnt For This Useful Post:
Spartan65 (08-14-2012)
Old 08-14-2012, 02:16 PM   #3
Memphis
Memphis's Avatar
Im guessing that the TEIN springs would have the same outcome.
Old 08-14-2012, 02:17 PM   #4
mechaghost
mechaghost's Avatar
Drives: Silver AT Limited
I wonder if that will affect the RCE Yellows
mechaghost is offline   Reply With Quote
Old 08-14-2012, 02:18 PM   #5
CBR600RR
Drives: Raven Black
Hmmmm I wonder how much the TRD springs will lower the stock shocks.
(I really don't see how the shock operating 1.4 inchers further into its travel can detrimentally affect its life span??)
Old 08-14-2012, 02:20 PM   #6
Memphis
Memphis's Avatar
Me and Luchessi told him it was riding way to rough. Car had no give at all. All I know is that if you want to lower this car and use springs then you are going to need new shocks that are adjusted to the proper size or whatever you call it to compensate.
Old 08-14-2012, 02:20 PM   #7
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
The Eibachs come with modded bump stops. Did the guy in the OP install them? Do they know exactly why the OEM shocks failed?
I'd be surprised if the RCE Yellows would blow shocks given the R&D they've pit in and the Yellows come with modded bump stops too in order to preserve stroke.
Also, the Eibachs are one of the mildest aftermarket springs so IF this is true (I.e. We know for a fact that the spring were at fault) then I'd worry about pretty much any spring, including the TRD ones.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 08-14-2012, 02:23 PM   #8
CBR600RR
Drives: Raven Black
I think this case is likely an anomaly. Both Tien and Eibach have tested and designed certain models of their lowering springs to work specifically with the stock shocks...
Also the stock shocks are apparently over damped, meaning they will actually be better suited with a spring that has a mild drop and a mild increase in spring rate.
Old 08-14-2012, 02:25 PM   #9
20valvewynn83
20valvewynn83's Avatar
Drives: 2013 FRS/01 Tacoma
Yeah I'm sure its not the springs due to them being longer I bet the shocks are just seeping and not leaking
20valvewynn83 is offline   Reply With Quote
Old 08-14-2012, 02:25 PM   #10
Memphis
Memphis's Avatar
Tein has not released their super low springs yet have they? Heck, I think that there are only MAYBE 2 people on this forum with the Eibach Sportlines.
It also could have to do with how stiff the springs are. I dunno.
Old 08-14-2012, 02:32 PM   #11
CBR600RR
Drives: Raven Black
^ it is definitely shitty to hear that your buddies shocks and done. I guess it is time to put those stock springs back on and get the shocked replaced under factory warranty.
Old 08-14-2012, 02:34 PM   #12
Memphis
Memphis's Avatar
Heh he works for a Toyota dealership in sales. They know what he has done to his car. Depends on how much they like him I guess.
Old 08-14-2012, 02:46 PM   #13
Racecomp Engineering
The Sportline's 1.4 inch drop is cutting your available bump travel down to approx 44% of what it started with up front. That's including the bumpstop in the travel too.
Our RCE springs are a mild 0.75 inch drop (20mm).
(I really don't see how the shock operating 1.4 inches further into its travel can detrimentally affect its life span??)
EDIT: but more details should be provided and it sounds like these are improperly installed Prokits anyway.
- Andrew
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
chulooz (08-14-2012), mechaghost (08-14-2012), ultra (08-14-2012)
Old 08-14-2012, 02:47 PM   #14
camelflage
Drives: pinto power
were the bump-stops cut to allow more travel?
camelflage is offline   Reply With Quote
Actual Spring difference BRZ vs FRS Motopythons Suspension | Chassis | Brakes -- Sponsored by 949 Racing 66 05-13-2015 10:12 PM
Lowest quality spring? Synack Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 07-26-2012 12:00 PM
Suspension Installation Warning!!!! Don@Accelerated Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 07-20-2012 06:44 PM
Weird GT 86 factory spring rates in GT5? Spec-Al Suspension | Chassis | Brakes -- Sponsored by 949 Racing 36 03-27-2012 02:30 PM
FR-S to be priced at $22k and coming in Spring of 2012? vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 92 10-25-2011 09:06 PM
