Old 08-13-2012, 06:19 PM   #85
sho220
sho220's Avatar
Drives: FR-S MT & FJ Cruiser
Originally Posted by hotaka View Post
you should just try it. try to go through a corner as fast as possible without heel-toe. enter a corner at a high speed, brake, but don't heel toe or rev match and downshift like most of the population do.
You'll find yourself in a very awkward position. you're steering sharp, you feel the lateral G's, and yet you have to let go of the clutch very slowly
Even if its a corner that doesn't require acceleration for quite a while, its frikkin awkward
Your sarcasm meter is broken...you too karma003...
sho220 is offline   Reply With Quote
Old 08-13-2012, 06:24 PM   #86
sho220
sho220's Avatar
Originally Posted by robo_robb View Post
Too bad our car didn't come with pedals like that. It would certainly make it easier to blip the throttle with that little extra protuberance at the bottom left...better tires would have been nice since I'm complaining...
Old 08-13-2012, 06:59 PM   #87
hotaka
Drives: na
im not being sarcastic at all.
hotaka is offline   Reply With Quote
Old 08-13-2012, 07:01 PM   #88
sho220
sho220's Avatar
Ay carumba...I was being sarcas....never mind.................
The Following User Says Thank You to sho220 For This Useful Post:
nix (08-29-2012)
Old 08-14-2012, 09:23 AM   #89
Texas BRZ
Imperfect
Texas BRZ's Avatar
Drives: 2025 C8 Z06s and more!
Originally Posted by Texas FR-S View Post
^ I agree with your specific explanation, and I'm continuing to practice this exact technique within this car... It has been working out more positively, and also has been more assuring to me.
On second thought, I wanted to correct myself... I'm actually having trouble rotating my entire ankle in order for my heel to catch the gas pedal... I guess I have long legs (combined with how the pedals and spacing are set-up from the factory), my knee hits the steering wheel when I'm performing the entire rotation (Note that I've raised the steering column up as much as I prefer).
So you could just say that I do a semi-rotation. And without losing the firm contact of the brake pedal, I proceed to blip the gas while performing the most rotation as best as I can... In other words, the mid-side of my foot blips the gas as accurately as my abilities allow.
Not exactly the perfect definition or art of heel-and-toe, but it works, so what can I say...
Texas BRZ is offline   Reply With Quote
Old 08-14-2012, 11:37 AM   #90
camelflage
Drives: pinto power
aside from this being a brakecelerateornering technique, i have seen people talk about proper form in regards to foot position, and how the traditional toes on brake heel blips throttle is no longer in vogue? whats considered the proper foot position now?
camelflage is offline   Reply With Quote
Old 08-14-2012, 12:09 PM   #91
Slartibartfast
Klaatu barada nikto
Slartibartfast's Avatar
Drives: Raven FR-S MT
Senna Heel-Toeing at suzuka in an NSX (This is how I do it, I guess I should call it toe-toeing lol)
[ame="http://www.youtube.com/watch?v=8By2AEsGAhU"]Ayrton Senna's Heel-and-toe - YouTube[/ame]
The "true" heel-toe.
[ame="http://www.youtube.com/watch?v=IuoZeuSgEj4"]Heel Toe Driving Technique - YouTube[/ame]
Is one way right and one wrong? I don't think so. I say personal preference. As long as you have your foot securely planted on the brake, I don't see anything wrong with "toe-toeing". Actually, having my foot rotate when trying the "true" heel-toe way seems less secure.
What are you guys doing?
ill86, how do you teach it when instructing novice drivers?
I vow to do no harm.
2013 Raven FR-S Manual "Lenore"
1985 Silver RX-7 GSL-SE (Gone and missed)
Slartibartfast is offline   Reply With Quote
The Following 2 Users Say Thank You to Slartibartfast For This Useful Post:
camelflage (08-14-2012), ill86 (08-14-2012)
Old 08-14-2012, 01:15 PM   #92
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
On the Senna video you could call that: Toe - 5th Metatarsal. This is very common as well.
Old 08-14-2012, 01:36 PM   #93
camelflage
Drives: pinto power
played around on my way to the store to pick up lunch, in my '95 corolla (dont laugh) the pedals are too far apart to confidently brake and reach over to blip the throttle with my little toe.. and rotating my foot is not happening because either the top goes way up under the dash or the bottom hits the floorboard..
first world problems...
Old 08-14-2012, 01:50 PM   #94
SupraLove
Drives: 2007 Toyota Camry LE, 5AT i4
I whipped up a quick reference on how I do it in my dad's TSX (Footwork only):
Step 1: You're driving...
Step 2: Brake as you approach the corner.
Step 3: Clutch in, downshift, blip the throttle with the side of your foot:
Step 4: Clutch out, continue braking.
Step 5: Corner and add gas, continue driving.
That's how I do it. Sometimes the right way is too uncomfortable for my ankle (I'm a size 9), so I slip in technique and end up using half my foot to brake and half to blip:
Dangerous. Don't do this. Your foot could slip off the brake and you could lose control. I do it sometimes, but that's because I'm an idiot.
Sometimes, my slip isn't too bad, but still doesn't retain proper technique:
Hopefully this clears up any questions on how to heel-toe. I've sat in the FR-S and tried to heel toe with the car turned off, and it's pretty easy the way I do it, but the TSX is definitely easier, and the gas pedal in the FR-S is a bit higher than I'd like, so I can see how it would be difficult for someone with smaller feet to heel toe. Cheers everyone.
SupraLove is offline   Reply With Quote
The Following User Says Thank You to SupraLove For This Useful Post:
yormaX (08-29-2012)
Old 08-14-2012, 02:19 PM   #95
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Thanks for asking-
I teach as in the above video. Side to side with as much rotation as comfortable and necessary due to pedal placement and driver ability.
Yes, your foot can slip, but as with anything practice makes perfect.
Taller, longer legged people, or folks with skinny feet are generally less comfortable.
Note this can be practiced in day to day driving. You only need say 20% pedal pressure when practicing the placement.
Hope this helps.
ill86 is offline   Reply With Quote
The Following User Says Thank You to ill86 For This Useful Post:
Slartibartfast (08-14-2012)
Old 08-14-2012, 02:21 PM   #96
ill86
ill86's Avatar
Drives: iG FR-S
Also, you should be using small muscle groups. ie the muscles in your foot and toes. Small muscles for small inputs. Large muscles for large inputs.
Old 08-15-2012, 02:49 PM   #97
JohnATL
JohnATL's Avatar
Drives: 2013 Scion FR-S MT Raven
When you have big feet, like me, it's not heel-toe. It's more like little toe-big toe. If I put my heel on the gas my toes will almost be on the clutch. My feet aren't even that big, I only wear size 13.
JohnATL is offline   Reply With Quote
Old 08-29-2012, 07:39 PM   #98
NoVtec
NoVtec's Avatar
http://www.ft86club.com/forums/showthread.php?t=15798
I love driving slow cars fast!
NoVtec is offline   Reply With Quote
Debadging - How difficult will it be? Dadhawk Scion FR-S / Toyota 86 GT86 General Forum 86 06-24-2014 10:49 PM
Heel toe #87 Other Vehicles & General Automotive Discussions 21 08-25-2012 05:39 AM
Difficult to purchase one this year? Pake1 BRZ First-Gen (2012+) — General Topics 12 05-22-2012 11:27 AM
Realistically, how difficult will it be to get one this year? eifer Scion FR-S / Toyota 86 GT86 General Forum 15 05-21-2012 05:46 PM
Heel and Toe ichitaka05 Other Vehicles & General Automotive Discussions 13 04-02-2010 02:28 AM
