Old 08-08-2012, 01:38 PM   #155
white86
Drives: Whiteout FRS
the idle problem you guys are having is because of the defroster setting on your heat controls. take it off the defroster setting and the A/C wont kick on and off to remove the moisture from the air and your idle wont be affected by this...
white86 is offline   Reply With Quote
Old 08-08-2012, 02:57 PM   #156
mike2100
mike2100's Avatar
Drives: 23 BRZ
So what you're saying is the A/C compressor being engaged is causing the idle problem. I think there are people having the idle problem even without the A/C compressor engaged. I have not tested it myself because it's been too hot to drive around without A/C!
mike2100 is offline   Reply With Quote
Old 08-08-2012, 04:04 PM   #157
wu_dot_com
Drives: accord
Originally Posted by mike2100 View Post
I got a check engine light too, but I assumed it was because I forgot to plug the MAF back in before I started the car. So I shut it down and plugged it back in and after 3 drive cycles the light turned off.
Did you happen to forget to plug your MAF back in before starting the car?
my MAF was on, but my CEL was probablly becuause i have a light flywheel aswell.
wu_dot_com is offline   Reply With Quote
Old 08-08-2012, 05:50 PM   #158
Style
LXXXVI
Style's Avatar
Drives: Dahlia (Raven FR-S)
i will be buying this and trying it out on the AT.
Style is offline   Reply With Quote
Old 08-08-2012, 05:55 PM   #159
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
I would love to hear how it feels for the AT.
blackfireball5 is offline   Reply With Quote
Old 08-09-2012, 01:10 PM   #160
white86
it engages on and off for about 1 second out of every 8 seconds or so if youre using the defroster, which causes the idle to jump around.
Old 08-09-2012, 01:32 PM   #161
Benzy
Drives: 2001 Camaro
Can somebody post a video of the car's tachometer while driving, showing an example of what it drives like with the pulley on?
I've searched around but I cant seem to find a video anywhere for this vehicle.
Benzy is offline   Reply With Quote
Old 08-09-2012, 04:05 PM   #162
wu_dot_com
Drives: accord
Sure thing. But I must say I have both pulley and flywheel. I'll probably post sometime tonight or tomorrow.
Old 08-09-2012, 04:47 PM   #163
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
I've already got it in my AT. It isn't a huge change but it is noticable and I'm glad I did it.
A note for anyone thinking about changing the pully on an AT. Beacuse you can't put it in gear you will need a tool of some sort to hold the pull while you loosen/tighten the nut. Grimmspeed makes a took that isn't made speciffically for our cars, but I was able to get it to work on both the stock, and Perrin pully.
Old 08-09-2012, 04:59 PM   #164
zoomzoomers
zoomzoomers's Avatar
I've seen the pictures/instructions on how to do it, but how difficult was it in your opinion? I've never had a Subaru and don't know any shops that work on them, yet, so I have to consider stuff like this when thinking upgrades.
Old 08-09-2012, 05:55 PM   #165
neutron256
neutron256's Avatar
If you have the right tools:
1/2" socket set
1/2" Breaker bar (x2 for the AT)
1/2" torque Wrench
Pulley Tool (Helpful on an MT, a must on the AT)
Screwdrivers
Its an easy job as long as you have some level of comfort. The instructions in the DIY area are very good and easy to follow.
I've never changed a crank pulley before but I've changed accessory belts on lots of cars and this is much easier then most.
It took me about 20 minutes, if I had to do it again it would be a 10 minute job.
Old 08-09-2012, 06:00 PM   #166
zoomzoomers
Thanks for the info. Seeng as I live in a condo w/o a garage I won't be doing this any time soon. I would if I had a garage again.
Old 08-09-2012, 06:39 PM   #167
eriktherod
Drives: 2013 Scion FR-S Firestorm Red MT
Honestly, something this simple could be done with the tools in a driveway/parking lot in a matter of minutes.
eriktherod is offline   Reply With Quote
Old 08-09-2012, 06:48 PM   #168
zoomzoomers
I would still need the tools...
Perrin Crank Pulley now available milenko11 Engine, Exhaust, Transmission 96 12-10-2017 07:45 PM
pulley installed issue Sall Issues | Warranty | Recalls / TSB 31 08-15-2012 12:36 AM
Crank Pulley and the warranty Brimford Scion FR-S / Toyota 86 GT86 General Forum 4 07-08-2012 04:47 PM
Perrin Lightweight Crank Pulley for the BRZ/FRS at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 2 07-07-2012 11:24 PM
