Old 08-08-2012, 11:50 AM   #1
wootwoot
Drives: FRS
Oil Cooler
Anyone running an oil cooler around here? I was wondering what was involved with putting in a universal aftermarket unit? Wouldn't mind the Greddy one but who knows when it will be available.
Old 08-08-2012, 11:51 AM   #2
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
Perrin wrote about one in their exhaust post yesterday.
TomR
ABQautoxer is offline   Reply With Quote
Old 08-08-2012, 11:55 AM   #3
Memphis
Memphis's Avatar
Drives: Scion FantasticRoad-Sex
^This.
Perrin was almost 100% certain it would help eliminate the discrepancy of HP numbers being shown on dynos as the engine runs way to hot most of the time.
Memphis is offline   Reply With Quote
Old 08-08-2012, 01:11 PM   #4
jpit
Drives: Subaru BRZ
They're not to difficult to install. Thermostat is installed where the oil filter goes and the filter sits on top of it. You normally install the cooler in front of radiator and on the BRZ it looks as if it will be on the passenger side. Two lines are then connected between the two. The most important aspect is picking the right size cooler. Too small and it doesn't do the job and too large the oil temp can stay too low. Needs to be above 180 degrees and below 220 degrees during normal operations.
jpit is offline   Reply With Quote
Old 08-08-2012, 01:17 PM   #5
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
The oil cooler I have on the race car is not T-stat'd. I really like the Perrin option for a street car with a T-Stat so you're not driving to and from worth with overly cooled oil.
This might be a something I consider so I can just run the 0w-20 oil at the track without worrying.
Old 08-08-2012, 02:41 PM   #6
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
I wonder if this kit will fit for people going turbo with intercooler
Silverdub is offline   Reply With Quote
Old 08-08-2012, 03:53 PM   #7
wootwoot
Drives: FRS
Didn't think about the thermostat.... How about a link to a high quality universal unit that will do the job?
Also, is "over cooling the oil" that big of a deal considering we are running 0W-20 in our cars? Seems like it would function fine at low temperatures given the weight. Please educate me if I am mistaken.
Old 08-08-2012, 04:51 PM   #8
d1ck
Drives: Black 2013 FRS
Oil is designed to work in a certain temperature range, and the viscosity rating system reflects this. the first number represents the viscosity at lower temps, while the second number represents the viscosity at 100 Deg C. These numbers simply compare the rated oil to an SAE standard.
Therefore if you were to run your oil at 70 Deg C(over cooling it) it would be "thicker" than was designed for the engine, and your oil pressure would be higher.
d1ck is offline   Reply With Quote
Old 08-12-2012, 09:22 PM   #9
thermobox
Drives: 16 Impreza 5dr CWP
Doesn't it look like the STi concept has an oil cooler?
thermobox is offline   Reply With Quote
Old 08-12-2012, 09:24 PM   #10
mashal
DADA
mashal's Avatar
Drives: 2013
Why use an oil cooler if you ain't got no boost?
mashal is offline   Reply With Quote
Old 08-12-2012, 09:34 PM   #11
wootwoot
Drives: FRS
^Check out the Perrin thread about their exhaust. Oil temps were running high. Maybe a reason for dyno result variance.
Old 08-12-2012, 09:38 PM   #12
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Because oil gets hot even in an NA app..
Worse if you track your vehicle.
This car needs an oil cooler imo for any track work.
ill86 is offline   Reply With Quote
Old 08-12-2012, 09:41 PM   #13
mediumbrown
mediumbrown's Avatar
Drives: 2013 Argento Scion FR-S
heat is the enemy of anything mechanical, so keeping the oil temp in check could theoretically prolong engine life in the long-term
mediumbrown is offline   Reply With Quote
Old 08-12-2012, 09:44 PM   #14
wootwoot
Drives: FRS
Greddy oil cooler coming soon DIG1992 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 08-20-2012 12:02 AM
Tomzilla's "That feeling when your car is far cooler than you" BRZ thread. Tomzilla Member's Car Journals 1 06-19-2012 12:10 PM
Greddy Oil and Diff Cooler pdreams Engine, Exhaust, Transmission 3 06-13-2012 08:41 PM
Cooler than drifting! Rampage Other Vehicles & General Automotive Discussions 8 04-03-2012 12:55 AM
