#57 |
thanks for the writeup!
#58 |
Drives: 128i, Z3 Coupe, Fiero GT
So, I just had my car in service and had them check out why my power mirrors stopped working... Apparently, if you disconnect the DRL resistor - as described in this thread - you will also lose your power mirrors. I will live with it until my new ECM arrives that can program the DRL's to be turned off.
-Anthony
Former '13 Whiteout FR-S, BMW 128i, BMW Z3 Coupe, Pontiac Fiero GT 2017 Pirelli World Challenge TC Rookie of the Year 2012 NASA SpecE30 National Champion www.DriveFasterNow.com Last edited by FRSpdDmn; 07-25-2012 at 12:10 AM. |
#59 |
Drives: '13 Ultramarine
I think your dealer may be feeding you a load of poo... I did the DRL delete as instructed about 3 weeks ago. When I went out to the car this morning, first thing I did was check to see if the mirrors were still working. They work fine.
#60 | |
Drives: Scion FRS
Removing the Relay is not the way to go. Remove the Resistor as instructed in the first post. Ishii |
#61 |
I misread. I thought FRSpdDmn meant the resistor. I did not remove a relay.
#62 |
Sorry, I did mean RESISTOR. I will fix my post. Unplugging the resistor will kill your power mirrors (according to my dealer, that's why my power mirrors are not working).
-Anthony
Former '13 Whiteout FR-S, BMW 128i, BMW Z3 Coupe, Pontiac Fiero GT 2017 Pirelli World Challenge TC Rookie of the Year 2012 NASA SpecE30 National Champion www.DriveFasterNow.com |
#63 |
Out of curiosity, is your car one of the early ones that is eligible for the DRL ECM replacement?
-Anthony
#64 |
I'm not sure... It is # 2955, built in April. Manufacturers have been required to have DRLs on their cars here since 1990 or so. even if I could get the updated ECM, I doubt my dealer would shut them off. Since removing the resistor, I drive with my running (parking) lights on so there is some sort of light showing at the front. I think this looks much better than DRLs, and many other sporty cars use the marker lights as DRLs anyway.
#65 |
For those who hate it, but MUST have it for legal reasons.. Maybe this is a better way to disable the DRL? Could you make a foglight-type switch and hook it up to the E-brake wire that runs to the DRL? That way, when you flip the switch to ON, the DRL is enabled.. Flip the switch OFF to disabled it. I'm not an electronics expert, but I'd be interested to see if this is possible.
#66 |
This might be a dumb question, but why not just remove the bulb? At least then you wouldn't get that yellow reflection.
#67 |
Drives: Ae86,X2 , Scion FRS
Take your car to the dealer they can turn them off permenatly through the techstream at no cost to you took 2 minutes to do and they also changed my alarm sound and stuff and a/c around to better suit my elevation. IF they cannot turn them off they will have to order a new ecm for your car wich again will be no cost to you and toyota is more than happy to do it just tell them to turn them off there is a TSB out for them
#69 | |
The body ecu for the car has many customizable features which is a free service!!! Just roll through and request what you want. A recent TSB came out saying that toyota will replace your Body ecu so that the DRL function can be turned off at customer request and switched back on upon request. Any Toyota dealer can preform scion warranty work. |
#70 |
Napa relay part # AR6034. Replace relay with this one. No drl, no trips to dealer. Not free but works.
