Old 08-04-2012, 04:41 AM   #15
Arnie_1
Drives: Peugeot 106 XSi
Curious why the Whiteline endlinks were contacting the control arm? Does the Cusco mount the endlink any differently than OEM? Any chance of posting up a pic of it contacting?
Arnie_1 is offline   Reply With Quote
Old 08-04-2012, 12:25 PM   #16
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
Originally Posted by pdreams View Post
Am I interpreting it wrong or is the overall F/R or L/R weight distribution suppose to change? Doesn't match up unless weight was removed before and after cross weighting. Seemed to have lost a few pounds here and there or is the equipment suppose to have some accuracy tolerance?
No idea
Yeah the cusco has a wall that reinforces the brace so the screw and bracket hit it, i highly recommend the perrin much better quality IMO.
Here is a pic i took of both the stock and cusco arm i actually had to cut and shorten the screws that came with the white line kit.
And here is a pic of the bracket that the whiteline kit comes with, the perrin mounts right on there ill try to get a pic later. Do you see the angle of the whiteline end links? The perrin mounts just like stock.
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
The Following User Says Thank You to track_warrior For This Useful Post:
carbonBLUE (08-06-2012)
Old 08-06-2012, 04:06 AM   #17
der_rainman
Drives: Subaru BRZ
Thanks for the extra pics as I'm interested in these arms as well.
How easy is it to adjust the lower arm? Do you have to unbolt the one, interior end and spin the pillow ball then bolt it back up? Or can you adjust it "on car"?
In regards to your corner weighting, I've noticed on a few corner weighted cars that there is a good 40-50lbs more weight on the left rear of the car (without spare/jack and minimal fuel). Have you seen anything under there that could account for that?
der_rainman is offline   Reply With Quote
Old 08-06-2012, 07:54 AM   #18
ZDan
ZDan's Avatar
Drives: '23 BRZ
When you corner-balance the car, you are setting the coilovers to give you front left + right rear = front right + left rear. If the car has 100 lb. more weight on the left, it's going to show up on both the front left and right left tires after balancing, whether the extra weight is at the front, back, middle, or evenly distributed.
Often on Japanese performance cars they'll design them so that with a driver on the *right* side of the car, they get even left/right weight distribution. So with a driver on the *left* side, there is left-side weight bias.
On my FD, there's 130 lb. more weight on the left side than on the right with a left-side driver and 1/2 tank of fuel, because of the designed-in left weight bias. Same thing here. Doh.
Old 08-06-2012, 09:05 AM   #19
MattR
Running in the 90s
MattR's Avatar
Drives: 2014 Scion FR-S Monogram
Originally Posted by pcasso87 View Post
In a car if you fart the alignment changes just a bit.
I knew I shouldn't have had the chili before qualifiers
Car looks good man!
藤原とうふ店(自家用)
MattR's Tofu Runner
MattR is offline   Reply With Quote
Old 08-06-2012, 01:27 PM   #20
jeebus
holy crap your toe was SOOOO off before alignment!
jeebus is offline   Reply With Quote
Old 08-06-2012, 02:04 PM   #21
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Its such a small difference its almost undetectable. In a car if you fart the alignment changes just a bit.
Uh... I would definitely try to hold those in.
Old 08-06-2012, 02:46 PM   #22
Matt Andrews
Matt Andrews's Avatar
Drives: race cars
Did you check on how much the percentage changed on your cross wieghts with and without the driver? I was pretty surprised, mine changed .1% . that is nothing compared to other cars. pretty cool...
11/19/12 - Just back from Redline TimeAttack's demo event. Video and write up in link below.
http://fecompetition.wordpress.com/
https://www.facebook.com/FECompetition
Matt Andrews is offline   Reply With Quote
Old 08-06-2012, 02:46 PM   #23
der_rainman
Drives: Subaru BRZ
Thanks Dan! Yeah, I figured as much, but I'm curious now as to what exactly is on the left hand side of the car that contributes to the weight? Is it the exhaust plumbing? Wiring looms? fuel tank deeper on the left? I'm really wondering if there are components that we can change or eliminate that would help reduce this built in bias?
Old 08-10-2012, 06:43 AM   #24
karma003
auto-crosser/drifter
karma003's Avatar
Drives: 2013 scion FR-S black M/T
Originally Posted by Asphaltfrs1 View Post
Question. On the alignment sheet, the front camber, caster and toe are different on the left side from the right. Wouldn't it be better to have the same numbers on both sides? I've always wondered why techs wouldn't just have then equal the same (ex: RF -.01 camber RL
-.02 camber. Why not just -.02 on both sides, instead of being unequal)
I'm not very experienced with alignment, so it's just a question that might receive a good answer thus making me more savvy in this area. Thanks
As an ex Toyota technician, I think ill answer this one lol. It's really difficult to get the numbers EXACTLY spot on cuz when u tighten the nuts, the numbers tend to move. Not only that, but also sometimes u want then off. Not to the left thou, its usually to the right (in the u.s. anyways). Becuz for the most part u have to take into consideration that w the driver sitting on the left (added weight) the car will tend to pull to the left. Therefore, majority of the times, if the person is heavy, I usually would try to slightly set it to pull to the right. To accommodate for the drivers weight... Being an EX tech sucks thou, just becuz I miss having the alignment machine handy when I needed it. Just yesterday, it was my first attempt to try getting the wheels to lose grip & drift this car for the first time (surprisingly hard for 215tires) & anyways... Im ashamed to say I it lost control & I flew into the inside of a corner & threw off my alignment when I got back on the road. (It was a backroad in the country) sucks.
karma003 is offline   Reply With Quote
Old 08-10-2012, 06:46 AM   #25
karma003
karma003's Avatar
Ok guys i just got done corner balancing and aligning the car with soul speed on wednesday. They align and corner balance right at the race track so its nice i got to test and tune my setup. Thought i would share my specs with the community. I didnt drive it with my track tires nor did i push it too much since i only had a chance to drive it a couple of laps and slowly since they were mowing grass around the track but i can say it felt great so well balanced even with the staggered setup. Tomorrow i will be lapping around the track with my track setup ( 17x8 RPF1'S on 245/40/17 RS3'S ) I will chime in on how it goes. This alignment will be my starting point and i will be adjusting specs as needed.
Notes:
-The weigh of the car posted in the corner balance sheet reads 2918 pounds but that is with the weight of the driver (me) which i am 200 pounds alignment guy made a mistake on the sheet but corrected it.
-I did the alignment and corner balance with my heavy street wheels as well 18 inch staggered kiwamis.
-Gas Tank was Full to the top as the gas station was right out side the track.
-Interior was empty no backpacks etc
-No tools or spare tire
-Total weight of just the car taking away my 200 pounds is = to 2718 pounds full of gas.
-Asked for a good an Aggressive Street / Track Setup
Suspension & Chassis Setup:
-KW V3'S
-Cusco Thicker Rear Sway Bar
-White Line Sway bar end links
-Vorshlag Front Camber Plates
-Cusco Rear Adjustable Arms
-Cusco Front Member Brace
-Cusco Rear side Member Braces
Visit: www.soulspeed.com
Below are the specs.
This may be a stupid question, but ill ask anyways. How did u get ur car aligned to begin w? Called a local Toyota dealer about doing my alignment & they don't even have the update out yet.
Old 08-10-2012, 12:35 PM   #26
track_warrior
Track Junkie
Used custom specs and camber plates & arms since the car has no stock adjustment.
karma003 (08-11-2012)
Plastic protection strip on bottom corner of door sill robo_robb Scion FR-S / Toyota 86 GT86 General Forum 38 12-12-2015 12:11 PM
Potential unclaimed BRZ in Tysons Corner, VA ap5512 BRZ First-Gen (2012+) — General Topics 1 07-09-2012 08:53 AM
I'm hoping my BRZ is around the corner Evil86 BRZ First-Gen (2012+) — General Topics 4 05-24-2012 07:58 PM
BRZ Premium @ Stohlman Subaru (Tysons Corner, VA) blueBRZ Mid-Atlantic 15 04-07-2012 05:32 PM
