Old 05-31-2026, 11:02 PM   #799
Unplugem
Drives: Cayman R 6MT
Sorry, totally fake and obviously a conspiracy. I mean, I'm not the only one that saw the strings on the aliens, right? So many video anomalies, complete AI generated.
I bet you think the Nutella floating by was a coincidence, huh? With the label rotating into view for that "perfect shot."
Does that not seem like an anomaly to you? LMAO outer space is science fiction filmed in a Hollywood basement. Just ask the Red Hot Chili Peppers; they love to mock all of you science fiction fans.
Unplugem is offline   Reply With Quote
Old 06-29-2026, 04:14 AM   #800
alex87f
Meow
alex87f's Avatar
Drives: Focus ST mk4
Yea, I get that. I'm a private pilot and I understand how an airplane flies (Newton's 3rd law and all), but I don't understand why.
If you have the time and enjoy that sort of thing, try to play KSP. It's only a game and a cartoony one at that, but it really helps understand rocket building and orbital mechanisms:
alex87f is offline   Reply With Quote
Old 06-29-2026, 10:09 AM   #801
Honestly, didn't notice it, and frankly don't care. If Nutella paid for an ad, then that's just more funding. Astronauts could dress like NASCAR drivers for all it matters to me.
Outer space is not fiction. Even in a flat earth world, outer space exists. Hey, but you do you.
Old 07-04-2026, 11:20 PM   #802
Unplugem
Old 07-04-2026, 11:29 PM   #803
Unplugem
The 2014 CSXT GoFast rocket holds the record for the highest and fastest amateur rocket. At 73.1 miles it suddenly stops. Rockets don't have brakes, so what brought it to an immediate halt?
Nothing gets through the Aether, let alone the firmament.
The only thing that's been to outer space is your imagination.
Old 07-05-2026, 10:31 AM   #804
Gravity.
GoFast's engines burned for about 13 seconds or so, reaching about mach 5. At that point it was at 49,000ft. It then used its speed to continue to 379,900 ft slowly decelerating along the way not having any further thrust. At the peak gravity had slowed it to zero, at which point it began it's fall back to Earth.
So, basically, it acted like any other object that uses some form of limited propulsion to leave the surface of the Earth, returning once its velocity is overcome by gravity.
No different than me attempting a launch to dunk a basketball and coming up about 2 feet short. Lack of further propulsion.
Old 09-15-2026, 10:09 PM   #805
Unplugem
Gravity.
This video shows footage from two different angles, and you can clearly see that the change in velocity happens suddenly and it's not only its upward velocity, but also its rotation suddenly slows at the exact same moment. For both of these forces to suddenly change, in addition to the audible impact, there is clear evidence that the rocket made physical contact with something.
Old 09-16-2026, 10:16 AM   #806
It hits physics.
The rocket hits MECO, which means it stops accelerating. That causes a reduction in the spin rate, which is induced by a combination of the thrust and the design of the fins. It's a loss of acceleration, not speed, although the speed does fall off (again, gravity).
The audible "impact" are the mechanics of stage separation and deceleration being transported through the ship structure to the mic (or its added later given they are in space and there is no air to transmit sound)
Or, it hit the dome, whichever you prefer.
Old 09-17-2026, 08:53 PM   #807
Unplugem
It hits physics.
I did some research and I came across something called a "yo-yo despin" device, which is capable of drastically slowing the spin of the rocket. It's definitely an interesting device and I was completely unaware of its existence.
Now if I could just get a comparably logical explanation for why the "astronauts" in this video are not showing up in the cell phone cameras...
Old 09-18-2026, 10:27 AM   #808
I will admit it looks odd, and can be interpreted as "they aren't really there" but in the end that is way more complicated than the truth. I can't think of a reasonable reason they wouldn't just walk out the door and wave at the crowd.
Likely the cause of this is the normal "camera filming a camera" issues that happen in videos.
You should look into HDR Ghosting and Merge Artifacts, Rolling Shutter Artifacts, Exposure Compensation Washout issues amongst some others.
Bottom line, it is very possible for bright objects (the orange suits) to disappear in a recording of a recording, which is what this is. It's the same thing that makes LED lights blink and causes wheels or propellers to seemingly switch direction in videos.
Old 09-20-2026, 07:38 PM   #809
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
wtf is happening here
ineedyourdiddly
Old 09-21-2026, 10:31 AM   #810
Just a quick side conversation regarding Flat Earth without trying to be too judgy.
We now return you to your regularly scheduled conversations on Space stuff.
Looking forward to seeing Starship 14 and its orbital flight next week, assuming it isn't delayed again. It really needs to be successful to keep things on track.
Old 09-23-2026, 10:16 AM   #811
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
You, of course, know that no amount of data with change the mind of a hardcore "believer". Data contrary to their own will only reinforce their belief. Still, it can be entertaining.
Old 09-23-2026, 11:44 AM   #812
Of course, but I enjoy the discourse.
Which Space Saver will fit? Andrew666 AUSTRALIA 25 06-18-2020 09:07 AM
Cockpit Space Chad86 Scion FR-S / Toyota 86 GT86 General Forum 7 03-15-2014 03:24 PM
First run 86's (Space Saver question) DriftEightSix AUSTRALIA 11 01-10-2013 07:25 AM
FR-S space saver sierra Scion FR-S / Toyota 86 GT86 General Forum 2 11-29-2012 12:18 AM
Trunk space? tranzformer Scion FR-S / Toyota 86 GT86 General Forum 34 04-13-2011 12:29 PM
