#799 | |
Drives: Cayman R 6MT
Does that not seem like an anomaly to you? LMAO outer space is science fiction filmed in a Hollywood basement. Just ask the Red Hot Chili Peppers; they love to mock all of you science fiction fans. |
#800 | |
Meow
Drives: Focus ST mk4
#801 | |
Outer space is not fiction. Even in a flat earth world, outer space exists. Hey, but you do you.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#802 |
#803 | |
Nothing gets through the Aether, let alone the firmament. The only thing that's been to outer space is your imagination. |
#804 | |
GoFast's engines burned for about 13 seconds or so, reaching about mach 5. At that point it was at 49,000ft. It then used its speed to continue to 379,900 ft slowly decelerating along the way not having any further thrust. At the peak gravity had slowed it to zero, at which point it began it's fall back to Earth. So, basically, it acted like any other object that uses some form of limited propulsion to leave the surface of the Earth, returning once its velocity is overcome by gravity. No different than me attempting a launch to dunk a basketball and coming up about 2 feet short. Lack of further propulsion.
#805 | |
#806 | |
The rocket hits MECO, which means it stops accelerating. That causes a reduction in the spin rate, which is induced by a combination of the thrust and the design of the fins. It's a loss of acceleration, not speed, although the speed does fall off (again, gravity). The audible "impact" are the mechanics of stage separation and deceleration being transported through the ship structure to the mic (or its added later given they are in space and there is no air to transmit sound) Or, it hit the dome, whichever you prefer.
#807 | |
Now if I could just get a comparably logical explanation for why the "astronauts" in this video are not showing up in the cell phone cameras... |
#808 | |
Likely the cause of this is the normal "camera filming a camera" issues that happen in videos. You should look into HDR Ghosting and Merge Artifacts, Rolling Shutter Artifacts, Exposure Compensation Washout issues amongst some others. Bottom line, it is very possible for bright objects (the orange suits) to disappear in a recording of a recording, which is what this is. It's the same thing that makes LED lights blink and causes wheels or propellers to seemingly switch direction in videos.
#809 |
Drives: '13 FRS - STX
wtf is happening here
#810 |
Just a quick side conversation regarding Flat Earth without trying to be too judgy.
We now return you to your regularly scheduled conversations on Space stuff. Looking forward to seeing Starship 14 and its orbital flight next week, assuming it isn't delayed again. It really needs to be successful to keep things on track.
#811 | |
Drives: 2013 frs base
#812 |
Of course, but I enjoy the discourse.
| Which Space Saver will fit? | Andrew666 | AUSTRALIA | 25 | 06-18-2020 09:07 AM |
| Cockpit Space | Chad86 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 03-15-2014 03:24 PM |
| First run 86's (Space Saver question) | DriftEightSix | AUSTRALIA | 11 | 01-10-2013 07:25 AM |
| FR-S space saver | sierra | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 11-29-2012 12:18 AM |
| Trunk space? | tranzformer | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 04-13-2011 12:29 PM |
