Old 12-19-2023, 03:44 PM   #15
gpvecchi
gpvecchi's Avatar
Regarding the Subaru/Toyota configuration for A/C, you need even the matching A/C panel, different part numbers with different software.
Anyway, the only difference is the display; Subaru Full Auto=Toyota Auto, Subaru Auto=Toyota manual, the behaviour is exactly the same.
The Following User Says Thank You to gpvecchi For This Useful Post:
Trap63 (11-21-2024)
Old 12-25-2023, 10:54 PM   #16
Compelica
Compelica's Avatar
Drives: 86 GT
IIRC I can change to the Subaru/Toyota behavior without needing a panel change... or did I understand you correctly?
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
Old 12-27-2023, 12:50 AM   #17
gpvecchi
gpvecchi's Avatar
No, you need to change the A/C panel too, or it will not work correctly.
Old 04-03-2026, 06:15 PM   #18
ft86tr
Drives: Zenki WRB BRZ
Originally Posted by ojuniour View Post
Regarding the "REmote starter" functionality. I actually believe you can get a compatible toyota's RES Ecu and try to install it. Probably gonna be the one with either the 31 or 35 pin connector.
Looking at other toyota's oem vehicles the installation basically require removing one of those (31 or 25) connector from the ecu, that plugged into the RES Ecu, and then the other connector plugs back into the ecu from the RES.
Then you just have to program the vehicle from techstream after.
The ecu is missing in our car hence why you try to query the 'Remote Starter' function (in techstream at least).. it returns an indication signifying no response. well because no shit it's missing.
I believe it is for the OEM subaru option in Japan. Part number is H0017CA000
ft86tr is offline   Reply With Quote
Old 04-10-2026, 02:03 AM   #19
ojuniour
ojuniour's Avatar
Drives: Subaru BRZ 2017
Pretty interesting.. the jap versions have that as an option?
Actually the US version is H001SSG800.
I think i can get a hold of that connect it to the unused pin and see what i get from ecu..
Wish em good luck> fi this works..this can basically complete eliminate any bypass module, extra keys,...
ojuniour is offline   Reply With Quote
Old 04-10-2026, 02:56 PM   #20
gpvecchi
gpvecchi's Avatar
The genuine kit is just for AT. I found an aftermarket kit for manuals in Japan, but it's pretty expensive.
Compelica (04-11-2026)
Old 04-13-2026, 05:16 AM   #21
ojuniour
ojuniour's Avatar
My car is auto.. Don't come at me please 🫣
The Following User Says Thank You to ojuniour For This Useful Post:
gpvecchi (04-13-2026)
Old 04-14-2026, 06:03 PM   #22
ojuniour
ojuniour's Avatar
Ok I take it back, the correct part is actually H001SCA801 for the US (postfacelist firstgen)
BishamontenZC6 (04-17-2026)
Toyota Techstream xjohnx Engine, Exhaust, Transmission 206 08-20-2023 04:01 PM
Toyota Techstream Confusion geruta Engine, Exhaust, Transmission 12 04-06-2016 10:36 AM
Toyota Techstream OBD-II USB Cable FRSBRZGT86FAN Engine, Exhaust, Bolt-Ons 1 02-24-2016 11:06 PM
Toyota TIS techstream V10.10.018 kiki2015 Scion FR-S / Toyota 86 GT86 General Forum 0 07-17-2015 10:11 PM
Toyota Techstream on BRZ? pinoy_dorifto Engine, Exhaust, Transmission 6 05-15-2013 11:56 AM
