Old 03-09-2026, 04:54 PM   #1
aegisranger
Better brakes without spending a fortune...
Hi, this question has probably been asked before... but here goes.
I'm looking for a brake kit with better calipers and rotors. I have a 2013 BRZ and the stock brakes really didn't like stopping the car from 130mph. Now that I have done my LS swap and I'm not even topped out at 155 and the stock brakes are scary. I don't do track days or drifting, just generally fast street driving with an occasional high speed run. Not looking to put another $4k into the car just for brakes, so is there a decently priced upgrade?
Thanks!
aegisranger is offline   Reply With Quote
Old 03-09-2026, 07:14 PM   #2
Ohio Enthusiast
Drives: 2018 BRZ
Hybrid pads on stock calipers are probably the way to go in your case - more initial bite and better heat tolerance, without a ton of dust, noise and expense of track pads. Ferodo DS2500 (probably most suitable for you), EBC Yellow, Hawk HPS, etc.
The Following User Says Thank You to Ohio Enthusiast For This Useful Post:
Spuds (03-09-2026)
Old 03-10-2026, 07:38 AM   #3
N234
N234's Avatar
Drives:
Just get some improved pads. I have great experience with the stoptech street/sport performance, which have a really steady friction vs temperature curve and a really high fade temperature.
Tires are important. Good performance summers will have great grip at all temperatures. Not track tires which have extremely good grip after they've warmed up but can be unexpectedly bad when cold.
If you want a super nice communicative brake pedal, consider a brake master cylinder brace.
Sent from my Pixel 6 using Tapatalk
N234 is offline   Reply With Quote
Old 03-10-2026, 08:34 AM   #4
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I was not a fan of the hawk HPS 5.0. They're also quite hard on rotors.
Out of various street upgrade pads I've tried I like the endless MX72 plus.
Make sure to flush out fluid for fresh dot 3/4, and consider new OEM brake lines to the caliper.
The Following User Says Thank You to RToyo86 For This Useful Post:
N234 (03-10-2026)
Old 03-10-2026, 12:12 PM   #5
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
I second the suggestion of Stoptech Sport pads.
I run them in my hybrid BBK for both street and track lapping.
There pedal feel is much like stock pads however they can handle more heat.
You will want to warm them a bit when first hitting the road. Otherwise you may be shocked the first time you expect to slow for traffic. ��
If you’re interested in my hybrid Brembo set-up send a PM. Much less expensive than commercially available BBK’s.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
Old 03-10-2026, 01:22 PM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
For budget brake upgrade for daily driven car, better fluid, hybrid pads & brake airducts.
Also if you can trigger ABS when fully emergency braking, i don't see brakes being any bottleneck, rather tire's grip.
Higher end brakes don't "brake better"/don't stop faster. They just last longer without overheating with repetitious heavy braking, due having larger thermal capacity and improved cooling.
The Following 5 Users Say Thank You to churchx For This Useful Post:
Compelica (03-11-2026), DarkPira7e (03-10-2026), N234 (03-10-2026), Ohio Enthusiast (03-10-2026), Spuds (03-10-2026)
Old 03-10-2026, 06:17 PM   #7
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I suppose the question we should ask is why the brakes are scary. Does the pedal go to the floor without triggering ABS? Do they stop working after some amount of time on them? Does the ABS trigger on deceleration and you want to decelerate faster? Is the car unstable when decelerating? Is OP ever coming back or was this just an attempt to validate a unnecessary expense?
Also: "Build Thread"
The Following 4 Users Say Thank You to Spuds For This Useful Post:
DarkPira7e (03-11-2026), N234 (03-11-2026), Ohio Enthusiast (03-10-2026), smackrel (03-11-2026)
Old 03-11-2026, 11:23 AM   #8
smackrel
Full Throttle!
Drives: 17 CBSP Limited PP
Asking the real questions.
smackrel is offline   Reply With Quote
The Following 2 Users Say Thank You to smackrel For This Useful Post:
N234 (03-11-2026), RT-BRZ (03-11-2026)
Old 03-11-2026, 01:53 PM   #9
RT-BRZ
RT-BRZ's Avatar
Drives: 2013 Subaru BRZ
Thanks!
Well, in case you ever come back; RR Racing has a decent kit for our cars that's probably ~$2500. It comes with everything and they will be happy to consult with you.
As others said, what's happening in detail when you are braking hard? Have you moved to DOT4 fluid? What pads are you running? Etc.
RT-BRZ is offline   Reply With Quote
Old 03-11-2026, 03:32 PM   #10
Spuds
The Dictater
Spuds's Avatar
Lol it gets me in trouble someti- ... A lot.
The Following User Says Thank You to Spuds For This Useful Post:
smackrel (03-12-2026)
Brakes, Brakes, and more Brakes Fish Eagle AFRICA 282 06-18-2019 04:36 PM
NASA TT - Lets talk about spending points! JustDoItMikey Tracking / Autocross / HPDE / Drifting 152 06-19-2017 10:23 AM
Will spending only $200-250 on speaker upgrades be worth it? tracerit Electronics | Audio | NAV | Infotainment 30 04-29-2013 05:44 PM
Spending my money on Perrin Catback or Tune jflogerzi Engine, Exhaust, Transmission 27 01-07-2013 10:32 PM
This day is getting better and better and better :-) SeattleBoy21 Scion FR-S / Toyota 86 GT86 General Forum 5 04-05-2012 10:57 PM
