Old 09-06-2025, 08:12 AM   #5013
colHolm
Default User Title
colHolm's Avatar
I received the wiring diagram from edelbrock. Posting here in case it’s useful for anyone.
colHolm is offline   Reply With Quote
The Following 6 Users Say Thank You to colHolm For This Useful Post:
autoracer86 (09-06-2025), B T (09-08-2025), Brewster (09-16-2025), Dadhawk (09-06-2025), menikmati (09-08-2025), whataboutbob (09-10-2025)
Old 09-08-2025, 09:48 AM   #5014
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
Very Nice! Good move on getting away from the the D-Box as well, it was the reason my first engine blew. Won't be buying anything from Delicious again.
B T is offline   Reply With Quote
Old 09-10-2025, 01:30 AM   #5015
Mr_Eyo
Drives: 2017 Toyota 86
Originally Posted by Mr_Eyo View Post
I'm having trouble finding it, but I thought I read in this thread somewhere that someone hooked up the bypass valve to an alternate source that never sees boost? If so, will this work with an A/T? I'm at 25k miles boosted and the 1st Gen bypass valve actuator has failed me. It can barely hold 5 psi vacuum. Symptoms are bad idle, hesitation at low rpms when tipping in, -30 to -40% fuel trims and p0172. Everything is fine at higher rpms in boost.
Found the post here:
https://www.ft86club.com/forums/show...postcount=4505
Today I installed the remote MAP box (I know, like 3 years late...) and routed the gen 2 bypass valve vacuum actuator to the middle port on the SC nose. Feels a bit peppier in low-mid RPMs, but is that because the bypass valve is mostly closed whenever I'm on the pedal?
Mr_Eyo is offline   Reply With Quote
Old 03-03-2026, 11:54 AM   #5016
Brewster
Brewster's Avatar
Drives: 13 FRS AT, Edelbrock SC, Tomei EL
Thanks so much for that, it was useful to build a wiring harness to run 2 T-maps. 1 in the original runner location for Temperature only and the 2nd in the Remote block from BT (located elsewhere) for Pressure, sourced from the back of the SC.
Just made the changes yesterday.
If last nights test flight was any indication, the ECU likes the slightly lower IAT readings and is allowing more timing advancement.
Then again, it could've been the cooler air... or my fertile imagination.
The best thing about the future is that it comes one day (and curve) at a time.
Brewster is offline   Reply With Quote
The Following User Says Thank You to Brewster For This Useful Post:
B T (03-05-2026)
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
