#5013 |
Default User Title
I received the wiring diagram from edelbrock. Posting here in case it’s useful for anyone.
#5014 |
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
Very Nice! Good move on getting away from the the D-Box as well, it was the reason my first engine blew. Won't be buying anything from Delicious again.
#5015 | |
Drives: 2017 Toyota 86
https://www.ft86club.com/forums/show...postcount=4505 Today I installed the remote MAP box (I know, like 3 years late...) and routed the gen 2 bypass valve vacuum actuator to the middle port on the SC nose. Feels a bit peppier in low-mid RPMs, but is that because the bypass valve is mostly closed whenever I'm on the pedal? |
#5016 | |
Drives: 13 FRS AT, Edelbrock SC, Tomei EL
Just made the changes yesterday. If last nights test flight was any indication, the ECU likes the slightly lower IAT readings and is allowing more timing advancement. Then again, it could've been the cooler air... or my fertile imagination.
The best thing about the future is that it comes one day (and curve) at a time.
#5017 | |
Drives: 2017 WR Blue PP
Thumbing through this thread I found this post. Going to reopen some old wounds maybe. During the height of covid I received that s/c from Summit. The box looked as though it had been thrown from a helicopter after a disappointing interrogation.I saw that damage and promptly returned it for an exchange which appeared to be the last SC anywhere in the country at the time. I can't believe turned around and sold it "as is". Shaqin, did you get that resolved? What became of the supercharger from Hell? |
#5018 |
Full Throttle!
Drives: 17 CBSP Limited PP
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 10:09 PM |
