Old 11-17-2020, 04:07 AM   #99
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
If you want to avoid the trouble of removing the tube from the firewall, you can use a a 5/8" (16mm) ID Vacuum/Cooling Bypass Cap on the plastic sound generator "L" piece.
Admittedly, the fit is a little tight out of the box. The ID is probably a little less than 5/8" in actuality (probably closer to 15.4mm). I had one on there for a couple of years, but the stress was causing the rubber to crack. Additionally, it was a little bit of a fight to remove it.
Just replaced it recently with another (luckily two are in the pack of assorted sizes from O'Reilley's for ~$5 when I bought them years ago [Dorman 02253]) and used a Dremmel to enlarge the ID by a tiny bit (~0.02" or 0.5mm). Combined with some rubber grease, it went on nicely.
Alternatively, you can try to put a plug there. I measured the opening of the plastic L to be approximately 11.3mm in diameter (or ~7/16"). I haven't verified or tried it myself, but it may give you a reference to start with if you prefer that method,.
EndlessAzure is offline   Reply With Quote
Old 08-09-2022, 09:17 AM   #100
PerCompLLC
Drives: 2019 86 TRD SE
Probably one of the easiest, cheapest, and BEST mods I have ever done. Wish I had done it years ago on my FRS. Just did it on my 2019 TRD SE.
PerCompLLC is offline   Reply With Quote
Old 09-29-2022, 12:45 AM   #101
Paiser
Drives: Scion FR-S Monogram (Whiteout)
The sound in the cabin is SOOO much quieter and it’s much much less drony. Really recommended mod! Why? Save your ears!
Paiser is offline   Reply With Quote
Old 09-30-2022, 10:58 AM   #102
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
Technically for street class autocross, I can't change the inlet to the Perrin tube or even simply remove and block off the sound tube. I did however add a stopper at the firewall in the passenger side footwell to keep the piped in sound at bay for now.
I envy you people not having to adhere to strict rulesets.
cmiovino is offline   Reply With Quote
Old 09-30-2022, 11:02 AM   #103
JD001
JD001's Avatar
Drives: Subaru BRZ
I had a CAI installed, left the plumbing for the noise thing in place but had the pipe bunged up.. I just like the plumbing in place as it detracts from the other gubbins in the engine bay..
Old 02-10-2026, 10:54 PM   #104
DJ_JAZZY_DJENT
j@ckoffofalltrades
DJ_JAZZY_DJENT's Avatar
yours didnt throw a code after this?
DJ_JAZZY_DJENT is offline   Reply With Quote
Old 02-10-2026, 11:11 PM   #105
ZC6_STi
ZC6_STi's Avatar
Drives: 2015 Subaru BRZ Series.Blue #709
Doesn't throw a code if you do this simple mod.
ZC6_STi is offline   Reply With Quote
Old 02-11-2026, 10:25 PM   #106
Luns
Drives: 2017 GT86
I keep all my sound generator plumbing in place as CA smog checks can give you a hard time for any of it missing.
I figured instead of capping things off with random pieces, I would use something actually designed to stop noises passing into a tube: ear plugs!
I pulled one of the tubes from the L piece, rolled up three ear plugs together and stuffed them into said L piece, and then put the tube back over them. I also pulled the hose from the piece at the firewall and stuffed three more ear plugs there in the same manner. Probably overkill, but I had plenty of extra earplugs.
Much quieter! And I'll be most impressed if a smog inspector flags it.
Luns is offline   Reply With Quote
Sound Generator to keep or not to keep? FRS86edition#3 Scion FR-S / Toyota 86 GT86 General Forum 73 11-24-2013 01:26 AM
Sound generator delete for $1.06 PineappleFriedRice Engine, Exhaust, Transmission 13 11-10-2013 12:28 PM
Sound Generator Tube Delete Anthony Engine, Exhaust, Transmission 8 09-01-2013 04:25 AM
WTB: OEM snorkle (not sound generator) Laika Engine, Exhaust, Bolt-Ons 2 11-08-2012 11:31 AM
