#253 |
Off to the track!
Drives: '14 Lava 86, '13 WRB BRZ
My stock ones died with the inserts still. Install the STI ones, they're actually not *that* hard to do!
#254 |
Drives: 2018 Subaru BRZ
Looking into these right now. Should cover most of allowable mods for DST.
#255 |
Drives: Toyota GT86
For the positive traction kit you don't want to install the very front bushing. The NVH is supposed to be pretty bad. So just a heads up.
I did a small post about it in my build thread. Oh and sorry if I am thinking of the wrong bushing kit but from the picture it looks the same lol
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
#256 |
Whiteline goodies ordered.
That makes it to the following to-do list: - Steering Rack Bushings - Rear Subframe Bushings - Transmission Mount (STi) - Front Lower Control Arm Bushings - New OEM Front lower control arms - New OEM Tie rods - Engine Mounts (STi) Still on the hunt for the STi LSD mount. I have the whiteline kit, but rather replace the whole thing.
| The Following 2 Users Say Thank You to spcmafia For This Useful Post: | autoracer86 (02-05-2026), DarkPira7e (02-05-2026) |
#257 |
Diff Mounts secured. I “think” I am all done now and I “shouldn’t” order more parts. I definitely “will not” get more things.
| The Following 2 Users Say Thank You to spcmafia For This Useful Post: | DarkPira7e (02-10-2026), Spuds (02-09-2026) |
#258 | |
The Dictater
Drives: '13 Red Scion FRS
But I guess I can put my diff bushings back in the basement now lol. Maybe I'll try them next year...
Also: "Build Thread" |
| The Following User Says Thank You to Spuds For This Useful Post: | spcmafia (02-10-2026) |
#259 | |
| The Following User Says Thank You to spcmafia For This Useful Post: | Spuds (02-10-2026) |
#260 |
Rust bucket enthusiast
Gods I have been working hard to avoid replacing wheel studs and diff mount bushings.... and I have so much time to do them. There are 0 reasons logistically not to do them, but every reason my lazy ass will always remove them from the cart before checkout.
#261 |
The Dictater
If you don't need extended studs, Dorman makes pretty good ones and they are way less expensive.
#262 |
I want to install all the parts. Typically enjoy it, is the working under a car lifted on a gravel driveway that gets me. Im trying to schedule an appointment over a DIY garage in Rhode Island. 25$ an hour for a lift rental plus all tools sounds pretty good.
| The Following User Says Thank You to spcmafia For This Useful Post: | DarkPira7e (02-10-2026) |
#263 |
Honestly Im just looking to get studs that sustain the constant wheel removal and abuse of the track. I hadn’t even thought about how much more abuse the studs will see this season.
#264 | |
The Dictater
) this whole time, been doing AX and swapping tires a bunch for the last 3 years. As long as you hand thread and torque to spec anything will be fine for years and years. And better yet, you can get two sets of basic studs and still come in under the price of a single set of ARP.Edit: less than 3 hours later... Ordered wheel studs. I'm a bad influence on myself.
Also: "Build Thread" Last edited by Spuds; 02-10-2026 at 10:29 PM. |
#265 |
Yeah exactly. I don't like things that take forever on the ground. Doing wheel studs is daunting, I like working on engine bay or interior off of a lift. Otherwise I really need a lift haha
#266 | |
Drives: 2013 Subaru BRZ
