Old 01-23-2026, 11:17 PM   #253
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
I need someone to convince me that I'm never going to install the sti diff mounts sitting in my garage and that I'll just get poly bushings if the stock ones die (running whiteline inserts right now).
My stock ones died with the inserts still. Install the STI ones, they're actually not *that* hard to do!
villainous_frx is offline   Reply With Quote
The Following 2 Users Say Thank You to villainous_frx For This Useful Post:
RToyo86 (01-24-2026), Spuds (01-24-2026)
Old 01-26-2026, 02:33 PM   #254
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Looking into these right now. Should cover most of allowable mods for DST.
spcmafia is offline   Reply With Quote
Old 01-27-2026, 06:38 AM   #255
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
For the positive traction kit you don't want to install the very front bushing. The NVH is supposed to be pretty bad. So just a heads up.
I did a small post about it in my build thread. Oh and sorry if I am thinking of the wrong bushing kit but from the picture it looks the same lol
autoracer86 is offline   Reply With Quote
Old 02-05-2026, 08:24 AM   #256
spcmafia
spcmafia's Avatar
Whiteline goodies ordered.
That makes it to the following to-do list:
- Steering Rack Bushings
- Rear Subframe Bushings
- Transmission Mount (STi)
- Front Lower Control Arm Bushings
- New OEM Front lower control arms
- New OEM Tie rods
- Engine Mounts (STi)
Still on the hunt for the STi LSD mount. I have the whiteline kit, but rather replace the whole thing.
The Following 2 Users Say Thank You to spcmafia For This Useful Post:
autoracer86 (02-05-2026), DarkPira7e (02-05-2026)
Old 02-09-2026, 07:45 PM   #257
spcmafia
spcmafia's Avatar
Diff Mounts secured. I “think” I am all done now and I “shouldn’t” order more parts. I definitely “will not” get more things.
DarkPira7e (02-10-2026), Spuds (02-09-2026)
Old 02-09-2026, 10:22 PM   #258
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
You definitely shouldn't replace all your wheel studs while you have things apart. I also should definitely not replace all my wheel studs. And neither of us should even think to install extended STI subframe bolts with those inserts...
But I guess I can put my diff bushings back in the basement now lol. Maybe I'll try them next year...
Also: "Build Thread"
The Following User Says Thank You to Spuds For This Useful Post:
spcmafia (02-10-2026)
Old 02-10-2026, 10:48 AM   #259
spcmafia
spcmafia's Avatar
Oh snap. Yes, ARP studs. Here we go again.
The Following User Says Thank You to spcmafia For This Useful Post:
Spuds (02-10-2026)
Old 02-10-2026, 11:22 AM   #260
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Gods I have been working hard to avoid replacing wheel studs and diff mount bushings.... and I have so much time to do them. There are 0 reasons logistically not to do them, but every reason my lazy ass will always remove them from the cart before checkout.
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
spcmafia (02-10-2026), Spuds (02-10-2026)
Old 02-10-2026, 04:57 PM   #261
Spuds
The Dictater
Spuds's Avatar
If you don't need extended studs, Dorman makes pretty good ones and they are way less expensive.
Old 02-10-2026, 05:36 PM   #262
spcmafia
spcmafia's Avatar
I want to install all the parts. Typically enjoy it, is the working under a car lifted on a gravel driveway that gets me. Im trying to schedule an appointment over a DIY garage in Rhode Island. 25$ an hour for a lift rental plus all tools sounds pretty good.
Old 02-10-2026, 05:38 PM   #263
spcmafia
spcmafia's Avatar
Honestly Im just looking to get studs that sustain the constant wheel removal and abuse of the track. I hadn’t even thought about how much more abuse the studs will see this season.
Old 02-10-2026, 07:46 PM   #264
Spuds
The Dictater
Spuds's Avatar
I've been on stock studs (except for two ) this whole time, been doing AX and swapping tires a bunch for the last 3 years. As long as you hand thread and torque to spec anything will be fine for years and years. And better yet, you can get two sets of basic studs and still come in under the price of a single set of ARP.
Edit: less than 3 hours later... Ordered wheel studs. I'm a bad influence on myself.
Old 02-10-2026, 08:02 PM   #265
DarkPira7e
DarkPira7e's Avatar
Yeah exactly. I don't like things that take forever on the ground. Doing wheel studs is daunting, I like working on engine bay or interior off of a lift. Otherwise I really need a lift haha
Old 02-10-2026, 09:39 PM   #266
RT-BRZ
RT-BRZ's Avatar
Drives: 2013 Subaru BRZ
Wheel studs are a piece of cake. You don't need no stinking lift either.
RT-BRZ is offline   Reply With Quote
