| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 2017 Subaru BRZ
Car can't start after parking overnight need help
Hi people. Have a big issue here
17 Stock BRZ, aftermarket intake and OFT Stage 1 map, catback exhaust, never touched engine. HKS Spark plugs changed in 120,000km, now is at 160,000km. Now living in Saskatchewan Car failed to start after parking overnight, can crank, battery full charged doesn’t help. First time happened back in October, pulled engine out and found cylinder flooded by gasoline, cleaned up and drives well. Just happened again, same symptom, car can crank but not starting. Any idea? No error code found either. I’m doubting about sensors or fuel system issue. MAF? MAP? Leaking fuel injector? I attached YouTube video link down here, took some videos including trying start the car, trying flood cleaning mode and reading OBD data through OFT tablet. Many thanks. https://www.youtube.com/playlist?lis...zWSJMvt5oiSMVy
#2 |
Rust bucket enthusiast
If it's cold enough, your old battery on "full charge" really just may not be up to it. Is it the original? Do you have the original battery in it still?
Temp looked to read -18c. I see fuel is full
#3 |
Drives: 2018 BRZ
Nice videos. I would put the battery voltage on the OFT to monitor while it cranks.
Some of the attempts do sound like a weak battery, but that might have been due to you keeping cranking the car without it starting, as a few other attempts sound pretty healthy. I would try booster cables or a booster pack to rule out the battery, other than that I can't help much. |
#4 |
Drives: 2013 frs base
Has you ruled out a spark issue? Spray a little starting fluid into the intake and see what happens.
#5 |
Thank you for all replies, my original battery was done back in 2023, unfortunately the new AGM one was deeply discharged by the shop twice so it dies again after only two years, I bought a new battery today and now my car is back on road!
| The Following User Says Thank You to ok1886 For This Useful Post: | Code Monkey (01-07-2026) |
#6 |
Thank you I bought a new battery to test today and I found the new battery from 2023 is done.
#7 | |
| The Following User Says Thank You to ok1886 For This Useful Post: | Ohio Enthusiast (01-07-2026) |
#8 |
| The Following 2 Users Say Thank You to ok1886 For This Useful Post: | blsfrs (01-07-2026), new2subaru (01-10-2026) |
| Tags |
| can't start, canada |
| saltywetman's overnight parts from japan NA build | saltywetman | Member's Car Journals | 33 | 11-21-2021 01:36 PM |
| Has anyone flipped down their rear seats and slept in their car overnight on a road t | jayhawkcole | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 08-16-2017 04:59 PM |
| How can I keep tires warm while parked outside overnight? | Pat | Tracking / Autocross / HPDE / Drifting | 14 | 04-25-2017 12:09 AM |
| Greddy Intake System / 5 in Stock / Free Overnight Shipping / Order Now!! | rickspecd | Engine, Exhaust, Bolt-Ons | 11 | 07-12-2013 11:50 AM |
| My "First 86" FR-S Almost Stolen Overnight at Dealership | hgamit | Scion FR-S / Toyota 86 GT86 General Forum | 47 | 12-28-2012 12:54 AM |
