| Engine Swaps Discussion of engine swaps. |
#421 |
Drives: 2015 FRS - FFR GTM
Well as I retired after 43 years in IT last month so its time to pick this one back up. With a little luck it may start before its 5th anniversary.
![]() Wanted to get your opinion. Bought a new clutch some time ago and it's been sitting in its box all that time. With the humidity levels and salt air here it's rusted up a bit. I'm trying to determine is its too far gone. First two are Pressure plate. Next fly wheel then clutch. Any saving these?? Worst case $400ish for new.
2015 FR-S - One Day I'll Finish The Swap |
| The Following User Says Thank You to gtpvette For This Useful Post: | Mike_ZN6 (05-21-2022) |
#422 |
Drives: 2016 Toyota 86
I wouldn't put that clutch in my car...
| The Following User Says Thank You to Mike_ZN6 For This Useful Post: | Opie (06-21-2025) |
#423 | |
#424 |
Going to use it I think. Hit it all with a wire brush and then some 320 for good measure. The flywheel and pressure plate are still discolored some, but the surface is smooth to the touch. The last two show the groves and I really don't feel anything other than those. Had to order new flywheel bolts as I had the wrong ones.
Need to freshen up the engine compartment, bleed the clutch MC, attach everything to engine in preparation to dropping in.
| The Following 5 Users Say Thank You to gtpvette For This Useful Post: | Capt Spaulding (05-23-2022), rBobby (05-25-2022), SuperTom (06-21-2025), Ultramaroon (05-22-2022), villainous_frx (05-22-2022) |
#425 |
Drives: 2017 Subaru Legacy
How far is the project now? What do you have left to do to 100% finish it? Where are you based?
| The Following User Says Thank You to ZB28 For This Useful Post: | SuperTom (06-21-2025) |
#426 |
Full Throttle!
Drives: 17 CBSP Limited PP
Just read this one start to finish over the last couple days. What a rollercoaster!
Are you able/willing to provide an update?
#427 | ||
Frankly there isn't much left to do as best as I remember. I'll post up once I get restarted, As it sits.
| The Following 4 Users Say Thank You to gtpvette For This Useful Post: |
| Should I have just got a new motor? | SoundsOfTheUniverse | Issues | Warranty | Recalls / TSB | 12 | 07-31-2017 08:51 PM |
| Seized motor!! What STX mods should I do while I have the motor out?? | BlaineWasHere | Tracking / Autocross / HPDE / Drifting | 27 | 12-11-2014 03:39 PM |
| K2 Motor? | Ronin Sascha | Engine, Exhaust, Transmission | 8 | 08-16-2014 07:51 PM |
| Does every motor say #1 | sosick | Engine, Exhaust, Transmission | 21 | 05-05-2014 10:28 AM |
| MOTOR UNION | David | Southern California | 0 | 06-22-2013 02:32 PM |
