Drives: 2014 DGM BRZ
Track Prep - Brake pads for my turbo 2017 PP BRZ Brembo's?
Good day all.
prepping for my first FATT at Summit Point this weekend. my brother advised i look at a set of fresh pads particularly the Porterfield R4's but i'm seeing a number variations. quick facts: 2017PP BRZ with a Ptuning turbo kit with a GTX2867, low boost-330WHP on E85. this will be my first track day with this new setup, and more of a shake down than anything. looking for good bite-in with little to no fade, streetable pad, but not afraid of some dust or a bit of noise. any advice would be greatly appreciated. thank you. |
#2 |
Drives: '23 BRZ
CSG pads are fantastic, but bring $$$... GREAT bite and very consistent, cold/hot. IMO very streetable. Some noise and dust, but not nearly as bad as most. And they last a LONG time. I get 1.5x to 2x the track life out of them vs. others (Carbotech, ProjectMu, Winmax, etc). Recommend contacting them to get a specific compound recommendation for your wants/needs.
| The Following 2 Users Say Thank You to ZDan For This Useful Post: | BlaqkHavok (10-29-2025), smackrel (10-29-2025) |
#3 | |
Full Throttle!
Drives: 17 CBSP Limited PP
| The Following User Says Thank You to smackrel For This Useful Post: | BlaqkHavok (10-29-2025) |
#4 |
Endless MX72-Plus are another awesome choice for a streetable track pad. I'm using them right now on my BRZ without Brembos. Quiet and waaay less dusty than the Porterfield R4-S street pads I was running previously. Feel really really good on the street and they're very capable on track.
- Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | BlaqkHavok (10-29-2025) |
#5 | |
Thank you for the reply! |
| The Following User Says Thank You to BlaqkHavok For This Useful Post: | ZDan (10-29-2025) |
#6 | |
#7 |
Well we have them in stock, and aren't located too far from you so it would be quick shipping. Just FYI.
- Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | BlaqkHavok (10-31-2025) |
#8 | |
A lot of race teams that transition to a CSG setup are often shocked that they're suddenly either going faster and/or having longer service intervals for what they thought was "just a consumable component". An analagy could be made that fuel is "just a consumable" as well, and you already know the difference between running regular and premium fuel; the extra cost for premium is WELL worth it. MX72+ is also in stock if that's what you want, but I wouldn't recommend that as a "one size fits all" for your type of setup. They'll be fine on the street but a little bit noisy for a street pad on PP Brembos. |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | BlaqkHavok (10-31-2025), ZDan (11-04-2025) |
#9 |
Drives: 2017 BRZ PP, 2004 WRX
Two things:
First and foremost, make sure that when you show up to your first track day and/or you're doing maintenance ahead of time, don't be changing things like brake fluid and pads the night before or morning of the event. Give it a day or two so you can go drive the car around and make sure everything is good. I had a buddy show up and forget to put his master cylinder cap back on tight. Either came out during his first session or on the way to the track. He borrowed mine to do complete the day. Second, some feed back "bite" and feel. I used to really like pads that had crazy initial bite. I ranked pads based on that feeling when you first engaged them and that was about it. Now I like more progressive pads. I don't love pads that bite like crazy at first and change their feel as you press harder. I'd rather have a pad that engages more linearly based on you input.
| The Following 2 Users Say Thank You to cmiovino For This Useful Post: | BlaqkHavok (10-31-2025), Racecomp Engineering (10-31-2025) |
#10 |
I actually currently work in the greater DC area now, an our office is in Crofton MD, so not too far from ya. once i get to recover from this weekend and look at compiling the winter list of things to do to prep for next season, i'll have to stop by and see about those daily pads. thank you!
#11 | |
point 2. the fact is i just don't have as much funds as i would need to finish this project as when i started.. , and high dollar consumables that a newb like me would not see the efficacious results, especially when not competing, makes it hard to say that its a smart move at the moment... but sounds like its definatly the way to go when i improve the driver mod! point 3. since I'm planning on next season being my first actual racing season, i was intending on swapping pads as part of my pre-event prep, and having a set of daily street pads.. thank you for the feedback on the noise. |
#12 | |
To your second point, i 100% agree. bite-in is but only one variable that i need to consider when looking at how the brakes behave during a track session. but being aware of, and experiencing it for real are two different things unfortunately, and i definitely need to get slot of seat time over the next season to figure out exactly what i want/need. thank you for the advice! |
| "" S O L D ""Ferodo DS2500 Brake Pads for rear OEM, stock, non-Brembo brake calipers | Lemikson | Brakes, Suspension, Chassis | 0 | 12-01-2024 09:16 PM |
| FS: CSG C2 Brembo Pads, OEM Brembo Tie Bars, Swift 8" 2.5" ID Springs | RedReplicant | Brakes, Suspension, Chassis | 0 | 05-10-2024 03:03 PM |
| Project Mu 999 pads for Brembo brakes or brembo BBK. Still sealed in the box. $200 | Jstyle | Brakes, Suspension, Chassis | 3 | 06-13-2022 12:23 PM |
| 2017 BRZ OEM Brembo brake pads -- SOLD | Code Monkey | Brakes, Suspension, Chassis | 21 | 07-17-2018 07:43 AM |
| planned first track prep: Hawk pads/rotors | snuff58 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 11-02-2015 09:55 AM |
