Drives: 2014 Subaru BRZ Limited MTblue
planned first track prep: Hawk pads/rotors
Looking for comments: New '14 BRZ Ltd owner! Planning my prep for first track day. Currently looking at Hawk Quiet Slot rotors (F: HUS732, R: HUS739) and DTC-60 pads on front, DTC-30 on rear. I had been leaning to Carbotech XP8/10. Ran into an experienced driver/instructor who had a lot of experience w/ the CT's and warned me against them and heartily suggested the DTC's. Using stock calipers for now. Will swap out rubber lines. Planning on Motul RBF600. Plan to run slicks.
Drives: FR-S Whiteout
Whats wrong with the carbotechs according to your instructor?
Intent > Content
cowardice is the mother of cruelty. |
| The Following User Says Thank You to solidONE For This Useful Post: | CSG Mike (10-03-2015) |
driving smoother faster
Drives: Sold
Yeah, what's wrong with Carbotech? I've been using Carbotech XP12 with AP Racing Sprint BBK for two seasons now. With Ohlins and Toyo RR slicks...no matter what I throw at them...slicks chirp and the brakes keep working.
| The Following User Says Thank You to dp1 For This Useful Post: | CSG Mike (10-03-2015) |
#4 | |
Different pads have different characteristics, and can require changes in braking habits to utilize the pad. If your instructor was unable to adapt to a brake pad, do you trust him to adapt to your car and/or its specific characteristics? Run the same compound front/rear with the stock setup, and DO NOT run slicks for your first track day. Use whatever street tires you have. If your instructor races, Hawk has an aggressive contingency in place. Is he a paid professional or a volunteer looking to subsidize his own seat time? That'll determine, heavily, how I view his advice. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | DarkSunrise (10-04-2015) |
solidONE: He is a pca club racer. 12 yr on track. currently in spec Miata. He used CT's for quite a bit. Even after carefully following bedding in recommendations, he had rotors w/ some uneven buildup. He had harsh shuddering when starting to brake, but he just got used to that. He had had some chunking off the pads.
CSG Mike: he does not race pro. I've been scouring the forum for tips. I completely read JRitt's brake guide. guess i'm still on the fence, but when you get to talk in person with someone with a lot of track time, you usually listen. I try to listen to all I can. Thanks, all! |
CSG Mike: Oh, yeah, thanks for the tires tip. I was just worried about tearing up my DD tires! So, you 'spect I'll keep 'em in good shape??
UPDATE: My first track day, 2 days ago, went without a hitch! Mid-Ohio Sports Car Course. AutoInterests acclimation program. I will need work on gear shifting and shift timing!
Prep summary: replaced wheel studs and nuts. replaced brakes lines at all wheels w/ braided lines. The bleeding process took a long time, and replaced fluid w/ Motul RBF 600. The bleeding never completely was void of air, but the pedal was solid. Replaced all stock rotors w/ Centric #'s 120.47031(rear) and 120.47021(front). Replaced all brake pads w/ Carbotech XP8's. The bedding process went very well using country roads. Ran the stock Michelin Primacy HP's. |
| Tags |
| brake pads, brake rotors, first track day |
| SOLD..FS:WA-Brand New Raybestos ST 47/ST45 pads+ used rear set (PRICE LOWERED) | glamcem | Brakes, Suspension, Chassis | 7 | 01-11-2016 12:46 PM |
| Hawk Quiet slot rotors and assortment of pads | phastafrican | Brakes, Suspension, Chassis | 12 | 08-21-2015 10:18 AM |
| Hawk Quiet slot rotors and assortment of pads | phastafrican | Tracking / Autocross / HPDE / Drifting | 1 | 05-21-2015 02:40 PM |
| 04 STI Brembos, Hawk pads, 5x100 front rotors | Philly758 | Brakes, Suspension, Chassis | 7 | 12-06-2013 07:55 AM |
