Old 10-12-2025, 03:29 AM   #15
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Originally Posted by GrandSport View Post
This can really jack with aftermarket dashes and such. So if you're running an AIM dash, it can cause problems.
Also, AIM dashes don't play well with the factory ECU (and confirmed by AIM) so there's that too.
I guess I’m missing something here… I been running an aim mxs strada dash for almost a year in my daily / track car without a single issue.
autoracer86 is offline   Reply With Quote
The Following User Says Thank You to autoracer86 For This Useful Post:
RedReplicant (10-14-2025)
Old 10-12-2025, 05:38 PM   #16
smoltz
Drives: 01 911 Turbo, 03 G500
What is the specific problem you were seeing here?
Unless you do the full pedal dance, the SC is never really off. And if it thinks there is inside wheel lift, it absolutely will grab the brakes.
It sent me into 2 or 3x 360s across the middle of a track on a high G/high speed turn in the middle of a race that scared the shit out of me. I thought for sure I was about get T-boned but luckily everyone avoided me. It was absolutely mental.
I moved to Motec the next day.
Agreed -- if you track your car and you're turning off the nannies, use the pedal dance, esp if you have a non-Kouki.
smoltz is offline   Reply With Quote
Old 11-03-2025, 10:11 PM   #17
djcos35
Drives: Small and handle well
Update... It works! Did it for probably less than $30... might be less than $25. All I used was
- HK1582 for $15.95 plus shipping
- 2 pole rocker switch from O'Reilly's
- rocker switch mount
- Add a fuse tap kit
- wire and connectors
Wired it in just like my other one and have a rocker switch as a "valet" switch under the dash in case my son or someone borrows my car. It won't stop them from pushing the button by the stick shift but it at least won't turn off all the time automatically.
I might do another one of these in my wife's Honda passport to turn off the autostart.
djcos35 is offline   Reply With Quote
Old 11-05-2025, 06:59 AM   #18
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
AIM MXP caused limp mode some times. About 20% of the time.
The Solo2 DL was fine.
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car.
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1999 NB Spec Miata: 1.8 w/ all the goodies.
2022 CT5 Blackwing: Stock.
GrandSport is offline   Reply With Quote
The Following User Says Thank You to GrandSport For This Useful Post:
smoltz (11-06-2025)
Help on Launch control disable speed to control wheel spin during launching j.boy Software Tuning 8 02-01-2016 04:58 AM
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely Sigh-on-Rice DIY (Do-It-Yourself) Guides 58 03-02-2015 01:48 PM
Traction Control memory module installed banzairx7 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 30 06-17-2014 11:13 AM
Why does my BRZ have LESS traction with traction control on??? BRZnut BRZ First-Gen (2012+) — General Topics 19 12-16-2013 03:28 PM
Innovate Motorsports FR-S/BRZ traction control state modifier module... mines13 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 09-13-2013 01:06 PM
