Old 09-22-2025, 10:50 PM   #1
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
ECUTEK DESKey not working
Anybody have the ECUTEK DESKey stop working? I've had the kit for 5 years and used it only 6-7 times. Yesterday, I got a message saying the driver was not loaded. I tried different usb ports and even a different computer. ECUTEK has not yet responded to an email.
There are replacement DESKeys for sale from $150 to $200 but I'd rather not spend that much $ if I don't have to.
Recently, my 2013 FRS (FA24 swapped) developed an intermittent misfire but with no cel and it hasn't set a code. I was hoping to do some data logging to help diagnose the problem.
Old 09-23-2025, 12:23 AM   #2
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
What OS are you using? I had no problem using the DESKey on Windows7 but on Windows11, so far I haven't been able to get it to work. I suspect an OS update disabled the driver because it wasn't signed and you need to enable it again.
sly is offline   Reply With Quote
Old 09-23-2025, 09:56 AM   #3
blsfrs
blsfrs's Avatar
I was using Windows 10 on one computer and 11 on the other.
This morning I got a response from ECUTEK to down load a link that is supposed to fix the problem. I'll find out after work if it works.
The Following User Says Thank You to blsfrs For This Useful Post:
Tatsu333 (09-23-2025)
Old 09-23-2025, 03:17 PM   #4
Tatsu333
Drives: 2020 BRZ Sport Tech RS
FWIW, I've had mine running on Windows 11 no problem. Just checked it again right now, and it still works.
Tatsu333 is offline   Reply With Quote
The Following User Says Thank You to Tatsu333 For This Useful Post:
blsfrs (09-24-2025)
Old 09-27-2025, 10:43 AM   #5
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Mine has been working on multiple computers for years. Constantly tumbling around in my center console, being swapped between multiple workstations, etc.
How do you store the key? In a super hot place?
Old 09-28-2025, 11:39 AM   #6
blsfrs
blsfrs's Avatar
The key has almost always been stored inside my home. I've probably used it fewer than a dozen times.
Ecutek wasn't much help. They suggested reloading their program, which didn't work. They said to contact the vendor, Evasive Mtrsports. I called them Friday morning and explained my situation. I'm still waiting for their guy to return my call. I purchased the kit in 2019 so I'm not too hopeful about a solution that I will be happy with.
A local computer company said that, for $155, they would look at it and try to transfer the license to another thumb drive. No guarantee. I've seen replacement licenses for $150-$200.
Is there another way to datalog without Ecutek?
Old 09-28-2025, 12:46 PM   #7
DarkPira7e
DarkPira7e's Avatar
That really sucks. Unfortunately, the only other solutions require paying in general. Tactrix, brz edit, etc unless you have the Bluetooth dongle for ecutek
blsfrs (09-29-2025)
Old 09-29-2025, 02:45 PM   #8
elBarto
elBarto's Avatar
Drives: Toyota GT86
I know recent Windows updates have advanced security options and 1 of them is blocking "known unsafe drivers" . You can try turning those options off and test if it works, I do not recommend keeping them turned off since they really help to keep you safe.
Go to Settings, Windows security, Kernel isolation and turn off those 4 options. Restart and try the key again, maybe a reinstall of the software is needed.
Just a disclaimer, I do not own a ECUtek key, but I had troubles loading drivers thanks to that MS security toggle.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
The Following User Says Thank You to elBarto For This Useful Post:
blsfrs (09-29-2025)
Old 09-29-2025, 09:08 PM   #9
blsfrs
blsfrs's Avatar
A shout out to Evasive Motorsports, where I purchased the Ecutek kit. They are going to ship me a new key at cost.
The Following 2 Users Say Thank You to blsfrs For This Useful Post:
DarkPira7e (09-30-2025), Tatsu333 (10-01-2025)
Old 10-10-2025, 02:34 PM   #10
blsfrs
blsfrs's Avatar
I got the Deskey and after some fiddling, it's working. I initially got a message saying there was an interface problem. That was solved by updating the interface firmware.
I'm still chasing the intermittent misfire without a cel or code. I drove around for an hour but it would not misbehave. I'm going back out after lunch.
DarkPira7e (10-10-2025), Tatsu333 (10-10-2025)
EcuTEK DesKey Replacement Olson1288 Software Tuning 3 05-02-2023 05:57 AM
Tail lights not working, brake lights and turn signals are working Inter Electronics | Audio | NAV | Infotainment 10 09-15-2022 02:50 AM
Flashing back to stock Ecutek, no deskey dongle yzf219 Scion FR-S / Toyota 86 GT86 General Forum 4 09-29-2020 11:42 AM
[GA] Ecutek DesKey (dongle) Kojiap1 Engine, Exhaust, Bolt-Ons 0 03-01-2019 12:09 PM
ecutek deskey problem!! ahk Engine, Exhaust, Transmission 17 03-07-2013 04:54 PM
