Old 08-05-2012, 04:16 PM   #1
Asterisked Accolade
Pedals over Paddles.
Asterisked Accolade's Avatar
Drives: Celica GT-S | 89 Supra | 07' Accent
Question about Plasti-Dipping.
I've been trying it out today. In photos i've seen, the result is very smooth-- but mine are turning out a bit porous. Am i doing something wrong?
The can says to wait 30minutes between coats and i've only been waiting 15-20. That's all i've really diverged from the directions.
2002 Celica GT-S Track Car | 1989 Supra Track Car | 2007 Hyundai Accent AutoX | 2003 Cadillac CTS Daily
Asterisked Accolade is offline   Reply With Quote
Old 08-05-2012, 04:54 PM   #2
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
why are you not following directions????....
phanguy is offline   Reply With Quote
Old 08-05-2012, 04:56 PM   #3
Asterisked Accolade
The only thing i didn't follow to a tee is the wait-time. Is that making all the difference? I just didn't want to spend 2 hours spraying a few emblems.
Old 08-05-2012, 08:36 PM   #4
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
I dont follow the 3-5 process with 15 mins interval.
I do a massive 1 coat with the spray can close
To the part youre spraying and let it dry and sit overnight.
Always comes out shiny smooth and not feel
Like sand paper
86_ZN6 is offline   Reply With Quote
The Following User Says Thank You to 86_ZN6 For This Useful Post:
Dadhawk (08-05-2012)
Old 08-05-2012, 09:23 PM   #5
Asterisked Accolade
Update:
..porous when looked at up close.
Old 08-05-2012, 09:42 PM   #6
DanVIIIVI
DanVIIIVI's Avatar
Drives: 86GTS 6M
How are you prepping the emblems before spraying them?
What sort of area are you in when spraying/leaving to dry?
DanVIIIVI is offline   Reply With Quote
Old 08-05-2012, 09:45 PM   #7
Asterisked Accolade
I only prepped them by washing them with soap and water. As i've heard, Plasti-Dip doesn't require the usual paint prep. I'm spraying it in my garage. I was out of the sun, no wind, and i did the 12-18'' away spray as the can instructed.
@86 ZN6, do you think i should try a close up smooth coat like you did?
Old 08-05-2012, 10:19 PM   #8
FlipFRS
FlipFRS's Avatar
Drives: Asphalt
shake the can a lot, and just make sure you're not spraying too close or too far.. i'd watch some youtube videos hahah. It really helps :P
FlipFRS is offline   Reply With Quote
Old 08-05-2012, 11:02 PM   #9
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
i dont see why not. haha
plastidip if fully reversible
iv sprayed a lot already and my method always works
Old 08-05-2012, 11:51 PM   #10
Asterisked Accolade
Personally, i think the can was pretty far away; but the can says 12-18'' and that's what i've done. And considering 86_ZN6's advice as well, i may retry with a closer coat instead of multiple distant coats.
As a sidenote, i tried 5 stores before i finally found Plasti-Dip. 'Just thought i'd share.
Old 08-05-2012, 11:53 PM   #11
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
when you do it my way dont even let go of the trigger
just keep spraying until you cover everything up
Old 08-06-2012, 12:06 AM   #12
Asterisked Accolade
Will do. I'll have another go at it tomorrow. Thank you.
Old 08-06-2012, 12:36 AM   #13
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
The can says 12+" because PlastiDip is traditionally used to create grippy surfaces. If you move closer to what you're spraying, you'll get the desired effect. Lay it on a little thicker, too.
cobrabyte is offline   Reply With Quote
Old 08-06-2012, 03:16 AM   #14
TheCzar
TheCzar's Avatar
Drives: 2013 Scion FR-S (Hot Lava)
This!!!! Also when you spray it on make sure the coat has a nice thick shine to it. when i did mine the first time each coat would get bubbles in it then dry porous and if i made it a bit thicker it would dry nice.
Sorry for the huge images. As you can see from mine they are still kind of porous and could be better but they still look pretty good. remember that this stuff is kind of like rubber and it might be better to take the extra time and use actual paint.
TheCzar is offline   Reply With Quote
Plasti Dip Emblems 86_ZN6 Cosmetic Modification (Interior/Exterior/Lighting) 87 11-14-2013 07:28 PM
mpg question jarviz Scion FR-S / Toyota 86 GT86 General Forum 1 07-10-2012 01:40 PM
Question about going FI with an AT mechaghost Engine, Exhaust, Transmission 1 06-28-2012 04:25 PM
Question for BRZ and GT-87 hps? west2k95 Scion FR-S / Toyota 86 GT86 General Forum 276 03-13-2012 10:45 PM
