Old 08-11-2025, 10:35 PM   #1
twistednoble
twistednoble's Avatar
Drives: 2015 BRZ Limited
Getting Sloppy With Age
15 that's crossed the 120k mile mark and still trending steadily upwards.
Over the last 10k I've noticed that the driveline lash is starting to get worse and I'm getting more NVH than I used to have. I put the poly subframe toppers and diff inserts in way back when it only had 40k and now it almost feels like it's back to the stock levels of slop. I've also got gear whine that's getting transmitted to the cabin now too, right around 83 mph it starts to howl pretty good. Previously it was quietish aside from reverse being a bit noise. I also will sometimes get a strange loud resonance when decelerating in 3rd or 2nd.
Anyone else have well traveled cars and have an idea of what suspension parts like to wear out on these cars that can cause those kinds of issues?
What's the lifetime on the engine and trans mounts?
twistednoble is offline   Reply With Quote
Old 08-12-2025, 05:23 PM   #2
For what it's worth my '13 had over 230K miles on it when I traded it in and all these parts were still going strong, no issues. It was an AT though.
twistednoble (08-13-2025)
Old 04-16-2026, 11:53 PM   #3
twistednoble
Imported TRD mounts from Japan and installed them. Fixed about 80% of it but I've got another 20% somewhere. The trans mount appeared to be the worst, no obvious tearing but I could deflect it pretty significantly with just my hands. I suspect the carrier is getting sloppy but that might have to wait for a while. Maybe a JXB carrier is in the future but I've got other issues.
While laying on my back I could see that the forward bushing on the right LCA is tearing. Control arms are in the future I guess, the ball joint has 140k on it otherwise I'd probably consider an energy suspension kit.
I've also got some 24 BRZ cast off struts to put on as well. It was cheaper than one new strut and topper from the dealer so I'm coming out ahead. If I was a bit smarter I might have considered Bilsteins but I purchased faster than I researched. I've got some good stress cracking going on with the strut toppers; they made it 140k so I figure they don't owe me anything.
It's started feeling terrible when going around curves so I figure I should toss some parts and see where it gets me. Does not feel planted at all in fast curves with the summer tires on. I do wonder if the poly sway bar bushings may have worn out (over 100k on them), the original endlinks probably aren't helping either.
Old 04-20-2026, 12:29 PM   #4
Teseo
Drives: frs
Shifter bushing?
Old 04-21-2026, 12:23 PM   #5
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
You made me want to find that thread that talked about refreshing the suspension at 100k that CGS and a bunch of people chimed in on but I can't find it. So... second best links:
https://www.ft86club.com/forums/showthread.php?t=142230
https://www.ft86club.com/forums/show....php?p=3353424
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
The Following User Says Thank You to Wally86 For This Useful Post:
smackrel (04-22-2026)
My 'Sloppy Stage 2' 4.8 swap FRS Chickeneatman Engine Swaps 3 08-17-2020 09:36 AM
KW coilover boxing sloppy? Ranran Suspension | Chassis | Brakes -- Sponsored by 949 Racing 36 02-17-2020 09:34 AM
Lug nuts have a sloppy fit in 19mm socket. pcguru2000 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 05-31-2018 01:13 PM
Shifter is obnoxiously sloppy Takumidesh Engine, Exhaust, Transmission 14 04-25-2017 02:58 PM
Sloppy throttle pedal allowe Engine, Exhaust, Transmission 23 11-02-2016 02:11 PM
