Old 05-23-2025, 12:53 PM   #113
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Well I finally got myself a big brake kit. The dust shield in the stock front caliper have been shot for awhile now and I have noticed a bit of brake fade if I stay out past 5 laps.Also I have seen temps near 460F from my AP racing temp stickers on the caliper.
Hopefully I won't have any heat issues and just more overall confidence under braking.
The kit I went with is from Godspeed They use a Brembo off a Renault Megane mk3 and a Godspeed 2 piece directional 330mm x 28mm rotor. I went for G hook and bolted. Bolt as I didn't want to deal with any rattling. For pads I am using OEM brembo for the street(only 50 bucks!) and CL brakes RC6s for track. Same as I did for the stock caliper
Price was great much cheaper than anyone else at only 1000 pounds. I think the next cheapest option I was looking at was 1800.
Godspeed recommends about 300 street miles before trying to do any hard stops like you would to bed in pads. Since I am still in the brake in phase I don't have too much to say but so far so good! No strange noises yay It's a really nice OEM plus feel around town with the added bonus of looking super cool
autoracer86 is offline   Reply With Quote
The Following 6 Users Say Thank You to autoracer86 For This Useful Post:
Code Monkey (05-24-2025), DocWalt (05-29-2025), KMA KiCKz (05-26-2025), RT-BRZ (05-23-2025), RToyo86 (07-29-2025), SuperTom (07-30-2025)
Old 06-22-2025, 05:25 AM   #114
autoracer86
Drives: Toyota GT86
So bit of an update. The stock wheels no longer fit with the BBK so it forced my hand to get ARP extended studs and 10mm spacers. I wanted these mods anyway so no big deal
Also wanted to review the Godspeed Brembo BBK now that I had time to live with it and just finished my 2nd track day with them.
Street:
Well they look cool and the pedal feel is a lot better than stock. The top of the pedal travel isn’t really different but the middle is a lot firmer and overall just feels nicer. Pads are also really cheap. I got Brembo pads from autodoc.ie from 49.70 shipped!
I went with the bolted 2 piece rotor option as a floating setups have the potential to rattle. Happy to say noise wise it's the same as stock including the occasional low speed squeak unfortunately. Maybe better pads would help with this but it's really not bad and worth it for all the other benefits.
Track:
Nothing but positive takeaways here. My main focus was higher thermal capacity and these calipers are running half as hot when comparing temp stickers mounted on the caliper.
In all honesty the stock setup with good pads and fluid is capable enough. I had loads of track days on me but when I started getting faster I did start to get a bit of fade and the overall feel of the pedal was just not great even before they got super hot.
So now I have a better feeling pedal and brakes that run much cooler. Not to mention swapping brake pads is super easy. And as someone who pads swaps it's a huge benefit.
In terms of stopping power they sure feel stronger. I didn’t think there would be much upgrade to the stopping power but my track data does back up what I am feeling.
With the Brembos I was seeing peak G loads of -1.02g registered from an accelerometer and GPS Aim system. Stock calipers were best of -0.93 from the accelerometer and -0.96 GPS.
Stock caliper was on 3 day old Potenza races vs 9 with the Brembos.
TLDR:
Very happy with the upgrade great pedal feel easy pad swaps and runs cool
The Following User Says Thank You to autoracer86 For This Useful Post:
DocWalt (06-23-2025)
Old 06-22-2025, 06:19 AM   #115
autoracer86
Drives: Toyota GT86
Well on the 10th track day with my Potenza race tires they have corded Good thing I have a set of A052s ready to go
Even after 9 track days I still managed to set a new personal best of a 2:03.3 That makes 3 2:03.x lap times with this current setup. All done on different days at Mondello Park.
Right front
The Following 2 Users Say Thank You to autoracer86 For This Useful Post:
DocWalt (06-23-2025), Stonehorsw (07-28-2025)
Old 06-22-2025, 06:25 AM   #116
autoracer86
Drives: Toyota GT86
So... What's next well I booked another day with division88 to have new control arms installed, JR anti dive kit along with a new inner/outer tie rod on the left to match the new one on the right.
New alignment and just overall check of the car to get everything ready for my up coming UK track days. I will be going back to Outlon and Donington along with trying my first timed event. A javelin Sprint at Anglesey.
Old 07-27-2025, 04:40 AM   #117
autoracer86
Drives: Toyota GT86
Back at Division 88 to replace my worn out control arms plus a new alignment, corner balance, Jackson Racing anti dive kit and new tires(Yokohama A052). I also had them move the rear shock outward to increase the rear wheel rate. Everything is now all perfect for Donington And Oulton Park track days on the 12th-14th.
These new control arms make a massive difference. Even on my road tyres the car feel super direct the steering wheel is heavier as well in a good way
Those worn out bushings were messing with toe under load causing the inner tire wear I was seeing, Not to mention the car would pull a lot on the street. Pulling is now gone and everything feels to be working as it should. One might say the suspension is now connected :P
Alignment specs
Front Camber -4.2
Front Toe 0
Rear Camber -2.52
Rear Toe IN 0.10 total
Ride Height
Front 351mm
Rear 353mm
The Following 5 Users Say Thank You to autoracer86 For This Useful Post:
Code Monkey (07-29-2025), DocWalt (07-27-2025), new2subaru (07-27-2025), Stonehorsw (07-28-2025), SuperTom (07-30-2025)
Old 07-27-2025, 06:25 AM   #118
new2subaru
Weight Weenie
Drives: 15 FR-S
Alignment specs
Front Camber -4.2
Front Toe 0
Rear Camber -2.52
Ride Height
Front 351mm
Rear 353mm
Looks good. Nice setup for your own alignments. What rims and tires are you running?
The Following 2 Users Say Thank You to new2subaru For This Useful Post:
autoracer86 (07-27-2025), SuperTom (07-30-2025)
Old 07-27-2025, 06:54 AM   #119
autoracer86
Drives: Toyota GT86
Thanks it's always nice finding race shops that will also work on road cars lol
Braid fullrace A 17x8 ET35 Yokohama A052 225/45/17
Old 07-27-2025, 09:08 PM   #120
new2subaru
Weight Weenie
Drives: 15 FR-S
Ah, I thought you bought all that equipment. It's cool to see a race shop doing it the old school way. Nice wheels!
The Following User Says Thank You to new2subaru For This Useful Post:
autoracer86 (07-28-2025)
Old 07-29-2025, 09:39 PM   #121
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
What brand control arms are those?
I'm getting the same tire wear and have thought I might be a result of deflection in the control arm.. seeing your tire wear being similar to mine narrows that down. That Jackson racing piece looks tempting. Maybe something to consider next season.
Old 07-30-2025, 03:29 AM   #122
autoracer86
Drives: Toyota GT86
They are hardrace. It’s the oem style replacement optionwith hardened rubber
RToyo86 (07-30-2025)
Old 07-31-2025, 08:42 AM   #123
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ / 13 BRZ
If the deflection is coming from the arm itself, PCI has a reinforcement piece for that. I would suggest to start with a OEM like arm with better connections, I think Megan racing makes something with pillow balls.
Stonehorsw is offline   Reply With Quote
The Following User Says Thank You to Stonehorsw For This Useful Post:
autoracer86 (07-31-2025)
Old 07-31-2025, 11:06 AM   #124
autoracer86
Drives: Toyota GT86
Hardrace sell the arms I have in a few configs one of them has pillowball instead of bushings. I think @SuperTom has those
Old 07-31-2025, 11:36 AM   #125
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
I have the Megan ones. Mainly went with them because they had the longer Balljoint for the BRZ aluminum knuckles I converted too
SuperTom is offline   Reply With Quote
The Following 2 Users Say Thank You to SuperTom For This Useful Post:
autoracer86 (07-31-2025), Stonehorsw (07-31-2025)
Old 07-31-2025, 12:56 PM   #126
autoracer86
Drives: Toyota GT86
Yup also available from hardrace. I am not sure they are same company but there stuff looks near identical haha.
The ones you posted are even the same color blue I was close to ordering the ones with the longer balljoint for some better RCA but they were unable to tell me how much of a difference there was and my car is only slightly lowered so I didn't really need it.
I can't see you going wrong with any of the OEM style arms from Megan or Hardrace. Hard to beat the price too mine were 380shipped for the pair
SuperTom (08-01-2025)
Scratchy Noise and Peddle vibration Sovereign Issues | Warranty | Recalls / TSB 7 07-19-2022 05:36 PM
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
JC's hot lava/burnt orange 2014 GT86 build thread GT86NZID Member's Car Journals 11 08-25-2016 10:41 PM
Superpenguin's "Not Another Build Thread!" Build Thread superpenguin Member's Car Journals 7 06-17-2015 04:00 PM
Orange you glad you checked this thread?!? BlaineWasHere FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 23 04-09-2013 05:02 PM
