Old 07-08-2025, 09:59 PM   #1
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
AC issues on 2013 FRS Base
Naturally, my AC ain't working when it's been hot as heck. I think it's the blend door. The refrigerant was low and I added some to get in the "green" The compressor is running and condensate is dripping from under the car but I get hot air out of the vents.
The blend dial seems to have normal tension when rotated between hot and cold. Back in the fall, I swapped the ECU a couple of times. Is the blend door actuator on that side of the box? Could I have boogered it messing with the ECU?
I've found some posts on fixing the wire behind the dial but I haven't seen any diagrams of the routing of the cables or where the actuator is located.
Any help would be appreciated.
Old 07-09-2025, 06:27 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Take it to a shop that can evacuate the old fill and put it where it's supposed to be before you get to digging more. Sometimes these systems are particular and it's best to have a baseline before going into the craziness
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
blsfrs (07-10-2025), Wally86 (07-29-2025)
Old 07-22-2025, 10:58 PM   #3
blsfrs
blsfrs's Avatar
Well, the ac is working again. What did I do? Nothing. The car sat for 3 weeks while I worked on a couple of other projects and when I drove it again, I had cool air. Today, the air was almost cold. Gremlins again.
Old 07-25-2025, 12:06 PM   #4
norcalpb
norcalpb's Avatar
Just to add my experience...I would top off the AC every once in a while but the system would blow ambient temp air after just a couple days. It wasn't until I had the system fully evacuated, vacuumed, and then recharged did the AC return to it's properly functioning state.
norcalpb is online now   Reply With Quote
The Following 2 Users Say Thank You to norcalpb For This Useful Post:
blsfrs (07-26-2025), Wally86 (07-29-2025)
Old 07-26-2025, 04:42 PM   #5
blsfrs
blsfrs's Avatar
Thanks. Good to know. Thanks also to Dark. It sounds like you both had the same experience. I'll try this before pursuing a possible blend door malfunction.
The Following 2 Users Say Thank You to blsfrs For This Useful Post:
DarkPira7e (07-26-2025), humfrz (07-26-2025)
Old 07-26-2025, 10:01 PM   #6
Two things that I always take my cars into the shop for. One is any AC problems and the second one is everything else.
The Following 3 Users Say Thank You to humfrz For This Useful Post:
blsfrs (07-27-2025), DarkPira7e (07-27-2025), Wally86 (07-29-2025)
Base Timing A vs Base Timing B NoHaveMSG Software Tuning 2 01-08-2018 03:31 PM
FS: 2013 FRS Base Head Unit Dephective Audio/Visual, Electronics, Infotainment, NAV 3 05-05-2014 05:19 PM
Like-New 2013 FRS BASE HeadUnit - $125 shipped obo VuDism Audio/Visual, Electronics, Infotainment, NAV 3 01-10-2014 02:45 AM
Base FR-S Radio bluetooth synchro issueS! Duff_man Electronics | Audio | NAV | Infotainment 3 08-05-2012 04:36 AM
FRS/BRZ vs 2013 Base Mustang GT Tbomb 25 FR-S / BRZ vs.... 280 07-07-2012 06:13 AM
