#337 |
Drives: 01 911 Turbo, 03 G500
I guess I should keep this going... :-)
I bought the car from Will, and took delivery at Sebring and did a couple days at the track with Chin. As he mentioned, I had a 2nd gen (GR86) that I used exclusively on track but it was pretty much stock. I thought about gutting, caging, and then some light mods but decided to look for something that was already a dedicated track car. The club I do most of my events with runs a combination HPDE/Time Trial format in the Northeast, going to NHMS, TMSP, Palmer, WGI and a few other tracks in the area. Car has been in hibernation, but got it out this past weekend. First order of business was hitting the reset button on stickers and vinyl... Next up is some maintance and prep for the season, getting some electronics setup in the car and dealing with the exhaust, which the flange broke off the pipe... More to come next time... |
| The Following 6 Users Say Thank You to smoltz For This Useful Post: | autoracer86 (03-26-2025), Code Monkey (03-29-2025), DarkSunrise (04-01-2025), KMA KiCKz (03-30-2025), Opie (04-03-2025), villainous_frx (03-26-2025) |
#338 |
Took the car to Thompson in CT and ran it on some old 245 A052s, pretty happy with how it's running....
| The Following 4 Users Say Thank You to smoltz For This Useful Post: |
#339 |
Looks good from the outside too at Thompson....
| The Following 5 Users Say Thank You to smoltz For This Useful Post: | Code Monkey (05-16-2025), dowroa (05-15-2025), Opie (05-21-2025), RT-BRZ (05-16-2025), Stonehorsw (05-26-2025) |
#340 |
Drives: Toyota GT86
How are you finding the a052 for track ? How many push laps can you get in a session with them ?
Thanks
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
#341 | |
I feel like I get 5-6 hot laps and then they slow down but then next session they have the same pace. Even when they slow down they're still quick. If you want a lapping tire I don't think they're the one. Our time trials are setup in such a way that you have to go out on cold tires and then you have an out lap and three laps to set a time, so the A052 is good because it's quick and lights up quickly and doesn't carry too many penalty points (like an A7 or R7) YMMV |
| The Following User Says Thank You to smoltz For This Useful Post: | autoracer86 (05-17-2025) |
#342 |
Drives: Toyota GT86
That sounds perfect for me then. Thanks !
#343 |
Drives: 2013 frs red
Wills most recent track video was done in a miata. I didn't realize his 86 looked that good
| The Following User Says Thank You to Lantanafrs2 For This Useful Post: | Opie (05-21-2025) |
#344 | |
Drives: 2020 GMC Canyon Denali Diesel
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
| The Following User Says Thank You to Opie For This Useful Post: | smoltz (05-21-2025) |
#345 |
New mod coming up...
| The Following 2 Users Say Thank You to smoltz For This Useful Post: | Code Monkey (07-13-2025), ZC6_STi (07-13-2025) |
#346 |
Many changes to the car over the season and a few more coming. Goal is to have it dialed for next sesaon but in the meanwhile, car did an 11.2 at the glen but the one on video was an 11.8...
| The Following 3 Users Say Thank You to smoltz For This Useful Post: |
#347 |
2013 Subaru BRZ Premium - M/T
Mods: (Updated 10/28/2025) FA24 Engine From a Gen2 Link GT86 Plug and Play ECU Tuned by RTuned/Kinetic AIM MXP Dash w/ Mako Motorsports Mount Mishimoto Performance Aluminum Radiator, MMRAD-BRZ-13 Mishimoto Thermostatic Oil Cooler Kit, MMOC-BRZ-13 Radium Engineering Master Cylinder Brace, 20-0104-01 2 Sets: Enkei RPF1 Wheels, 17"x9", +35, 1 set Gunmetal, 1 set Victory Blue 1 Set: Apex ARC-8 17x9", +42 ARP Extended Lug Studs 949 Racing Lug Nuts RaceComp Engineering Tarmac 2 Clubsport Coilovers, 600# F Springs, 650# R Springs Raceseng CasCam - Caster & Camber Plates (Front) Raceseng 1" Upper Mounts (Rear) Buddy Club Adjustable Rear Lower Control Arms Stock Brake Calipers Spiegler Front & Rear Stainless Steel Brake Lines CSG C1 Front / C11 Rear Pads JDL Auto Design UEL Header JDL Auto Design Over/Front Pipe Combo Stock Gen2 Cat-Back HRi Tuning EcuTek Tune by James Whiteline KDT925 Rear Differential Mount Bushing Kit Whiteline KDT922 Rear Sub Frame Bushing Kit Corner Balance, Alignment and Suspension Setup by Kinetic Motorworks Perrin Intake Tube & Sound Tube Delete Geraldjustprojects.com Trac-Box Stock Sway Bars Cusco LR Axle Heat Shield Super-Pro 12mm Adjustable Front Sway bar Links 160mm #TRC12160 from FTSpeed MeLe Design Firm Battery Box XS Power Li-S680 4.5lb Lightweight Battery from MeLe Design Firm 2015 OEM Underbody Aero Panel Set Kartboy Transmission Mount Insert TrackSpec Motorsports Hood Vents Gutted Interior panels/seats/carpet A/C System Removed JDM A/C Delete Bracket Gen2 Axles Tires: Dry/Damp Set: Yokohama A052 245/40/17 Wet Set: Conti ECS02 245/40/17 Fluids: Castrol EDGE A3/B4 0W-30 Advanced Full Synthetic Motor Oil Redline MT-90, 75W90 Gear Oil (Transmission) Motul Gear 300, 75W90 Gear Oil (Rear Diff) AP Racing Radi-Cal R2 Brake Fluid Subaru Super Coolant Redline CV2 - CV Axle Grease Safety: Autopower Race 4-Point Roll Bar OMP HTE-R Seats OMP 0204 6-Point Blue Pull Up Harness Belts OMP Seat Sliders Race Safety Steel Side Seat Mounts Sparco Suede Steering Wheel NRG Hub Adapter & Quick Release Kit Current Competition Weight: Car, Driver, Ballast, Fuel = 2,925 lbs |
#348 |
Drives: Toyota GT86
That Mako Motorsports Mount looks pretty dope! Was there much issue getting the links plug ecu to work with the stock dash removed ? I saw someone having issues with ABS without the stock cluster
#349 | |
I have seen people report issues with ABS, I have not had any issues and I am running stock ABS. It all works pretty seamlessly for me. The AIM has two canbus inputs so I use 1 for the OEM subaru and 1 for Link. I get chassis data, like whether the headlights are on or the stability or traction is turned on/off, etc. from the Subaru CANBUS. I get all of the data from the Link, like RPM, Lambda, Oil Temp, Coolant Temp, Ethanol Content, etc. from the Link CANBUS. Fuel level and ambient temp are signals directly into the clsuter, so in my case I mapped those out and use analog inputs on the AIM dash. |
| The Following 2 Users Say Thank You to smoltz For This Useful Post: | autoracer86 (10-29-2025), RT-BRZ (10-29-2025) |
#350 | |
Drives: Toyota GT86
![]() Can I ask how you pulled in the headlight/tc data via the oem can bus ? I have my aim display pulling can H/L from the odb2 port and just selected the 86 ecu in aim race studio 3.. Are you building a custom can profile or something ? I would LOVE to see if the TC was on and setup an alarm to remind me/icon cruise control would be cool as well haha Thanks !
| NORGP GT86 just for Track Rebuild | Panamaniac | Member's Car Journals | 25 | 12-06-2019 08:41 AM |
| History of my GS-R.. and rebuild.. my now-current track car. | Dave-ROR | Other Vehicles & General Automotive Discussions | 35 | 12-12-2013 08:02 PM |
| MVP Track Time 2013 Road Atlanta Track Dates | Feffman | Southeast | 7 | 11-05-2013 11:36 AM |
| MVP Track Time 2013 Great Lakes/Midwest Track Dates | Feffman | Great Lakes | 5 | 09-07-2013 01:39 PM |
| FS: 2013 Totalled BRZ FS (~5,000 miles) | eklipz98 | Northern California | 45 | 02-03-2013 01:16 AM |
