Old 06-26-2025, 02:47 PM   #169
gt5759
Drives: 2017 BRZ
Originally Posted by smoltz View Post
You doing this yourself? Cagekits? A cage is on my post-season to-do list, trying to figure out options.
Been doing this work for over 20 years now! I do highly recommend cagekits for a kit, best one I have ever seen. Can't go wrong, just make sure your confident in your welding abilities.
gt5759 is offline   Reply With Quote
The Following 2 Users Say Thank You to gt5759 For This Useful Post:
blsfrs (06-26-2025), smoltz (06-26-2025)
Old 06-26-2025, 07:53 PM   #170
smoltz
Drives: 01 911 Turbo, 03 G500
Wow!
smoltz is offline   Reply With Quote
Old 06-26-2025, 09:58 PM   #171
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Sure did, went through all the options before locking down on this one but a lot of people don't realize how important that is for a racing application!
Just out of curiosity, what is the critical speed of your new driveshaft? I know from experience the standard DSS al shaft is just over 100mph.
Old 06-30-2025, 01:01 PM   #172
gt5759
Drives: 2017 BRZ
Not sure what size shaft that would be at 100mph?
This is 3.5" diameter 45" long, 0.125" and at the length that i have its about 10285 rpm for critical speed. At 200 mph it would put shaft speed at 10487 with my gearing and tire size.
Old 06-30-2025, 10:31 PM   #173
blsfrs
blsfrs's Avatar
This was my experience with a DSS al driveshaft.
https://www.ft86club.com/forums/showthread.php?t=148537
Old 07-08-2025, 11:44 AM   #174
gt5759
Drives: 2017 BRZ
That was definitely a long bad deal, appears they didn't do the math correctly. Rather long shaft to make only 3", there is a reason the OE is two piece at that length/size. Minimum should have been 3.5" but really it needs a 4" at that length for anything performance related (don't think it would fit though). They make high quality parts but if the math/design is wrong, it doesn't matter how nice it is!
Speaking of shafts our new one arrived and looks perfect. Should get her all fixed up this weekend and be ready for OIR next week!
The Following User Says Thank You to gt5759 For This Useful Post:
blsfrs (07-08-2025)
Old 07-08-2025, 10:44 PM   #175
blsfrs
blsfrs's Avatar
After a run, it might be interesting to get the temperature of the driveshaft at its closest point to the exhaust. It might give you insight as to why the CF shaft failed.
Old 08-12-2025, 07:12 PM   #176
gt5759
Drives: 2017 BRZ
We did just that this last event, it gets to about 190* on the surface via temp strips. that's hot enough to cycle the resin and cause problems. So i feel we have our answer!
blsfrs (08-13-2025)
Old 08-12-2025, 07:32 PM   #177
gt5759
Drives: 2017 BRZ
Well, OIR did not go as planned. Car was doing fantastic but I ended up getting sick severe dehydration is no joke, ended up going to the ER for severe abdominal pain after getting back home (thought my appendix burst or gallbladder. Point of the story, take care of yourself and be hydrated well before the event - I was not and had been pushing way to hard for weeks and not taking care of myself - something I never had problems with before but I'm not 20 anymore and need to remind myself of this sometimes.
Everything on the car felt so good, its working so well. I just need more seat time. Highly frustrating I couldn't race but it wouldn't have been safe for myself or others.
On to the next!!
The Following 7 Users Say Thank You to gt5759 For This Useful Post:
autoracer86 (08-14-2025), blsfrs (08-13-2025), DocWalt (08-13-2025), RedReplicant (10-31-2025), RT-BRZ (08-12-2025), Stonehorsw (08-21-2025), villainous_frx (08-17-2025)
Old 10-29-2025, 06:32 PM   #178
gt5759
Drives: 2017 BRZ
Last race of the season!
Sadly, we didn't get to run much this year from a variety of things, some car related some not, but we did get the information we needed to make the right improvements over the winter. She feels really good and is heading in the right direction, which is the big thing. Sorry for the lap video being far from the best in not only video quality (exposure and data overlay not working right yet) and drive mod!
Only major change to be made this off season is a larger fuel tank. Which I had to get approved by national to put it behind the driver like the gr86 cup cars do. She's a little thirstier than I figured and only going to get worse the faster we get. Other changes are small - aluminum knuckles from a 22 brz, send the shocks to MCS to re-valve and alignment updates.
Very happy with the car, glad I made the choice to switch over from the miata.
DocWalt (10-29-2025), RedReplicant (10-31-2025)
Old 10-29-2025, 10:30 PM   #179
smoltz
Amazing build, sorry to hear you didn't get to use as much as you hoped this season.
I had emailed national about if the GR86 cup setup was okay as they are now saying that you need a bulkhead which the GR86 cup car doesn't have.
I don't have a GR Cup, but was thinking about doing the seam as the Gr86 cup but I think I am now just going to build a bulkhead where the trunk is and put the fuel behind that.
I see you have a custom dash, is that the HGK one? Or something else?
The Following User Says Thank You to smoltz For This Useful Post:
gt5759 (10-30-2025)
Old 10-30-2025, 12:13 PM   #180
gt5759
Drives: 2017 BRZ
That should work well too, biggest I could fit back there due to the subframe is 14 gallon. A 10 gallon would enough for sprint racing with the FA or K series. This little piggy gets 4 miles to a gallon on E85.
Fiberglass HGK piece. Expensive, but really good looking and very light.
Old 11-03-2025, 02:21 PM   #181
redlined600
redlined600's Avatar
Drives: Fr-s
If you're de-tuning for P:W anyway, why not just run 91oct?
redlined600 is offline   Reply With Quote
The Following User Says Thank You to redlined600 For This Useful Post:
blsfrs (11-05-2025)
Old 11-04-2025, 11:20 AM   #182
Midtenn
Drives: 1995 Mazda Miata
E85 combustion temperatures are lower, which means less heat in the cooling system. So, it is likely to keep the cooling load down.
Midtenn is offline   Reply With Quote
The Following User Says Thank You to Midtenn For This Useful Post:
blsfrs (11-05-2025)
Jensen NASA ST4 race build thin2win Member's Car Journals 18 04-14-2021 01:15 AM
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 08:52 PM
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 10:59 PM
Superpenguin's "Not Another Build Thread!" Build Thread superpenguin Member's Car Journals 7 06-17-2015 05:00 PM
Car 986 Scion FR-S NASA PTD Race Car Build phastafrican Member's Car Journals 70 01-03-2015 10:32 PM
