Full Throttle!
Drives: 17 CBSP Limited PP
I read thru the entire How To thread:
https://www.ft86club.com/forums/showthread.php?t=103157 Lots of people saying it was an easy mod, so I ordered the GK Tech springs. https://us.gktech.com/products/gt86-...b3bd9a9f&_ss=c Got under there to swap it out and was unable to even remove the eclip. Lots of peoples saying it was sooooo easy on the how to thread, hell one guy even did on his lunch break at work with no tools.... To them I ask, what am I missing? I had my steering wheel off since I was swapping it out and still couldn't situated in a way that offered me access enough to really manipulate anything in there. I'm considering removing the wheel AND the seat next time I try to help me be a little more comfortable while I contemplate my existence. I'm not huge, 6'2'' 220 mostly legs, but damn if I felt like I was all thumbs under there. I know it sounds like it, but I am not a dumbass. I do almost all my own maintenance and mods. Plz tell me your secrets. Is it laying a certain way? going in arms first? Are all of you double jointed? plz help
#2 |
Drives: 17 Asphalt 86
I would guess your size is working against you. I'm 5'10 and my back is on the SIL when ever I'm doing anything under there. Very cramped. I make old man noises when I need to stand back up again.
If I recall I used pliers to get the clevis pin off, but it's been a solid 7 years since I did that mod. Last edited by RToyo86; 06-06-2025 at 01:27 PM. |
#3 |
I'm much shorter at 5'6" 170llbs but really had no trouble with this. You can try depressing the pedal a little which should take some tension off and make it easier to pull everything off. If space is the limiting factor then removing the driver seat will certainly give you a lot more room to work with. Just be careful with those stupid pre face lift seat mounting bolts.
| The Following User Says Thank You to 2.2Lude For This Useful Post: | smackrel (06-10-2025) |
#4 |
Drives: 2013 86
Is your car left or right side drive? Mine is right side and getting the spring out was brutal. There is no way I would have attempted to refit it. I waited a while to make sure I liked how it drives without it (which I do) then I threw the spring and other parts away.
There is a video in another thread where the guy removes the whole pedal and does the mod on the bench. This might be easier.
2014 GT86, 2.2L big bore, harrop supercharged
| The Following User Says Thank You to Eaton PSI For This Useful Post: | smackrel (06-10-2025) |
#5 | |
Full Throttle!
OT Re you username: One of my many Hondas was a BB6. Man I loved that car! So smooth, but still hauled ass! Still miss it
| The Following User Says Thank You to smackrel For This Useful Post: | 2.2Lude (06-16-2025) |
#6 | |
Full Throttle!
I saw a pic of the RHD pedal assembly and there's no way I would have even attempted that lol I reread the thread and someone mentioned bumping the EClip while in place. Ill try that next time and if that doesn't work I will consider removing the assembly. Thanks to both you for your responses and suggestions!
#7 |
Drives: 2013 86
If you do this mod, take it for a drive with no spring before you fit the GK Tech spring. The spring is totally unnecessary and you may find you're happy without it.
| The Following 2 Users Say Thank You to Eaton PSI For This Useful Post: | blsfrs (06-14-2025), Ohio Enthusiast (06-14-2025) |
#8 |
Drives: 2013 frs base
I've been springless for years.
#9 |
Drives: 2017 BRZ PP, 2004 WRX
Also if you do this mod, put a towel down all over the carpet and as far back and up as you can. Might even want to order a new $5 pin just in case. Mine went flying when I popped it out, even with a small towel down and got lodged behind the carpet somewhere. Went looking for it to no avail. Put another pin-type thing in there temporarily until the new correct part one came in a few days later.
Personally, I liked the MTEC spring I was installing rather than springless. Mine was also a 2017.
| The Following User Says Thank You to cmiovino For This Useful Post: | smackrel (06-17-2025) |
| How To: Free Clutch Spring Removal in 15 Minutes - A must do for manual trans! | VerusEric | DIY (Do-It-Yourself) Guides | 242 | 05-21-2025 08:05 AM |
| Clutch return spring removal | MikeyBRZ | Engine, Exhaust, Transmission | 186 | 09-16-2020 12:40 PM |
| How To: Clutch Spring Removal in 15 Minutes | eric6 | DIY (Do-It-Yourself) Guides | 165 | 02-14-2017 11:44 PM |
| Clutch spring removal | Sandy | AUSTRALIA | 4 | 07-22-2015 10:14 PM |
| Clutch Spring Removal & Throwout Bearing | DemonRawr | Issues | Warranty | Recalls / TSB | 2 | 05-13-2015 08:08 PM |
