Old 11-29-2023, 06:36 PM   #43
Grady
Grady's Avatar
It’s alive! 7 years and it will not die! Mods please kill this thread and put it out of our misery before more bots attack and take over everything.
Old 05-04-2025, 11:23 AM   #44
Tokay444
For the “OEM knows best” crowd. And this isn’t even a highly strung performance application.
Old 05-07-2025, 05:20 PM   #45
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
I watched the above video the other day.
I swapped to a 5w-30 (specifically Pennzoil Ultra Platnium, thanks "The Motor Oil Geek"). I keep going back to the fact that the manual says 5w-30 can be used AND other countries manuals state 5w-30, not 0w-20. It's not that 20 weight oil is terrible, but it's probably the limit of what the would cause reasonable wear, but also result in better fuel mileage. 30 weight likely better protects for the long run and I'd even make a case that 40 weight could even be an option.
My 0w-20 oil analysis with Motul came back just "ok" with 5 parts per million for aluminum with ~2k of street miles and about 15 autocrosses. It's not bad, but not great given the mileage on that sample. I'm testing PUP 5w-30 and redoing the test... with a flush in between and getting two samples of each that are all similar. If PUP can get in the 2-3 parts per million range, I'm cool with that as PUP is available at Walmart vs ordering online for Motul.
There seems to be a lot misinformation online, especially forums and Reddit. I ran the 0w-20 many suggest on here for even street use and trusted the manufacturer, but I do think going to a 30 weight in these cars is the best option. In my older EJ WRX that's rated for 5w-30, I've always run 5w-40 and it's widely known now a 40 weight is basically required for longevity. If it was 2025, they'd be saying put a 20 weight in there from the factory... oof.
cmiovino is offline   Reply With Quote
Old 05-07-2025, 07:03 PM   #46
DAC17
Drives: 2025 BRZ ts
Never mind the name; look at the specs on the back of the container. I believe latest spec is SP+, which in a 0W20 grade will do quite well for a non-track car. Also, the Dexos rating is another good indicator.
2023 WRX Limited
2025 BRZ tS
2024 Equinox EV (for the grandkids..)
DAC17 is offline   Reply With Quote
Old 05-07-2025, 08:23 PM   #47
2.2Lude
2.2Lude's Avatar
Not PUP but PP for reference.
2.2Lude is offline   Reply With Quote
Old 05-07-2025, 09:03 PM   #48
Tokay444
0w40 from day 1. Daily driven hard, and hard tracked. 315,000 trouble free KMS.
There’s a special place in hell for people who buy a sports car and talk about fuel economy.
The Following User Says Thank You to Tokay444 For This Useful Post:
Teseo (05-09-2025)
Old 05-08-2025, 10:58 AM   #49
smackrel
Full Throttle!
Drives: 17 CBSP Limited PP
Are we posting analysis results now?!? Lets go! This is my first drain from after I bought my car.
The question I actually have is that I specifically put that my sample came from a FA20D. I would think that the FA20T would have different expectations.
I also had to look up what the 4U GSE meant lol
smackrel is offline   Reply With Quote
driving, maintenance, oil, performance
High Performance Clutch FR-Shred Engine, Exhaust, Transmission 6 11-09-2015 04:32 PM
all season high performance or winter performance tires? Aloxi NY / NJ / CT / PA 29 03-24-2015 09:23 PM
Does anyone else notice a high pitched squeak while driving ? Frsultramarine15 Scion FR-S / Toyota 86 GT86 General Forum 23 11-25-2014 05:47 AM
Effects of driving at high revs daily fidelacchius BRZ First-Gen (2012+) — General Topics 30 08-22-2014 09:35 PM
