Old 04-02-2025, 04:38 PM   #1
AEBRacing
AEBRacing's Avatar
Drives: Toyota FT86
Exedy Clutch Stg2 or Action Clutch Stg2 for Toyota FT 86 SC Rotrex C30
Hi guys! I am loocking for to replace my OEM clutch due to increasing power on my FT 86 MT 2014 cause by a SC Kraftwerk C 30-94 with small pulley already installed
After read several times diferent topics and clutchs reviews (Exedy, SB, Clutch Masters, ACT, etc) finally I have two options
1. Exedy Stage 2 (OEM FW). 3x pad cerametallic clutch disc
http://www.ebay.com/itm/204446650429
I read this review of the Exedy S2 problem and I ask me if after several years this probles finaly was solved
https://www.ft86club.com/forums/showthread.php?t=75445
2. Action Clutch Stage 2 (OEM FW). 1x pad kevlar clutch disc
http://actionclutch.com/products/sta...u-gse-fa20-rwd
I am loocking a strong clutch to support the new power (315 HP and 250 lb-ft at crank) but avoiding vibration (ligth flyweel or on-off coupling), extrange noises, etc. I am planning not use the car on trackday for now but maybe some times in the near future. It is not my daily drive car
I didn´t see a lot of reference of the Exedy Stg 2 neither Action Clutch Stg2 asociate with BRZ, FRS or FT86,
Do you have any references of these clutches to recommend?
AEBRacing is offline   Reply With Quote
Old 04-02-2025, 05:01 PM   #2
RT-BRZ
RT-BRZ's Avatar
Drives: 2013 Subaru BRZ
I was just in your dilemma with my JDL v2.1 Turbo install.
I read through a lot of stuff and I ended up going with the South Bend Stage 2. Here is the link from Summit Racing (I used my SCCA 10% off coupon): https://www.summitracing.com/parts/SBB-FJK1005-HD-O
I heard too many things about the other brands at the price point I wanted. I know things like the OS Giken from CSG are reputable but my friends locally had nothing but good to say about the South Bend clutch. I have it broken in and the car completed the dyno tune without a hitch and I would agree. It works great.
RT-BRZ is offline   Reply With Quote
Old 04-03-2025, 08:33 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Exedy stage 1 clutch, no question. I loved mine. Was turbo with about 330whp and a ton of mid range torque you won't have to manage with the centrifugal SC.
Look up the reviews for them, super cheap, holds like glue, fits OEM
NoHaveMSG (04-03-2025)
Old 04-04-2025, 09:56 PM   #4
AEBRacing
AEBRacing's Avatar
Drives: Toyota FT86
Thanks, I read about de Exedy Stg1, I undestand it supports more than the specification torque is anuncement by Exedy
Old 04-04-2025, 10:02 PM   #5
AEBRacing
AEBRacing's Avatar
Drives: Toyota FT86
Thanks a lot!!!, are you using the south bend clutch with the OEM flywheel?
Old 04-04-2025, 10:18 PM   #6
RT-BRZ
RT-BRZ's Avatar
Yes. I had a local shop resurface mine. It was like $80 for them to do it and they turned it around in just a few hours.
The Following User Says Thank You to RT-BRZ For This Useful Post:
AEBRacing (04-04-2025)
Old 04-05-2025, 09:59 AM   #7
DarkPira7e
DarkPira7e's Avatar
Far more. It's likely the same disc South bend are using on their stage 2. Exedy makes southbend's clutch discs.
I've owned the stage 3 daily and now have the stage 3 drag
RT-BRZ (04-05-2025)
Old 04-05-2025, 12:38 PM   #8
RT-BRZ
RT-BRZ's Avatar
Thanks for that bit of info. Things are adding up because the throwout bearing and the pilot bearing in my South Bend kit were Exedy parts.
Jackson Racing SC Kit - C30-94 Rotrex Supercharger High Boost Pulley Release CounterSpace Garage Forced Induction 313 03-08-2021 08:39 PM
*SOLD* Jackson Racing C38 Supercharger Kit FOR SALE FRS BRZ Rotrex c30 boost hirollaz Engine, Exhaust, Bolt-Ons 6 03-01-2018 03:32 PM
WTB: Rotrex C30-94 Supercharger unit (blower only) adjusts Want-To-Buy Requests 1 12-10-2017 03:54 AM
FS: Rotrex C30-94 Supercharger / SOLD chuccwagon Engine, Exhaust, Bolt-Ons 1 10-25-2016 09:44 PM
More 86 Twin drift action + Off road action knoxviue FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 16 02-25-2012 08:55 PM
