Old 03-26-2025, 01:29 AM   #505
tomm.brz
Drives: brz 2017 hksv2
when you start for the first time the engine after a reset, vvt is going to activate 99,9999% of times as you leave the car idling and waiting.. just that
If you reset and car is medium hot , you could waste time trying to activate vvt
Old 03-31-2025, 10:00 AM   #506
kcratos
Drives: minimalist
Originally Posted by tomm.brz View Post
at that mileage i d just have the mechanic open the front cover and change chains and retainers
anyway yes open the OCVs to clean them... i would also change them or at least 2 of them, they aren't expensive though
i've seen some car improve vvt precision swapping them new
With engine stone cold, disconnect battery, clean ocvs, reconnect battery and press 4 times throttle pedal slowly til floored and then release is slowly, with ignition on (2 times start button without clutch)
then crank engine on and leave it idling more than 5 minutes
Clean air filter and maf sensor possibly, it s not very normal for the engine to shut down randomly at crossroads
When you say change at least 2 of them you mean on one passenger side for the p0016 or the bottom ones?
I gatta be honest, I don't understand what you mean by this. This pedal dance you explain "press gas 4 times" what is this for?
kcratos is offline   Reply With Quote
Old 03-31-2025, 12:49 PM   #507
tomm.brz
it helps recalibrating faster the accelerator pedal after a reflash
i said 2 ocv to save money
they re not so expesive but 4 of them is
Old 03-31-2025, 03:05 PM   #508
kcratos
Drives: minimalist
I see, thank you. If I mess up the procedure, Would it calibrate by it self eventually?
Also if I replace only 2 ECVs to save money, I'm replacing the 2 on one side that I have the code right? in my case the passenger side with p0016
Old 03-31-2025, 10:37 PM   #509
tomm.brz
either you change all 4 and delete the dilemma about them, or you take 1 or 2 and then you move them as they are the same in all 4 positions and you look for changes in error codes, i'd like to think some of them work good
Eitherless some people change them all, they aren't so expensive and also it's not a bad move to do
yes the pedal will calibrate eventually, it is just to reduce the wonky response it has initially after a reset/flash
Old 04-06-2025, 08:09 AM   #510
ShadowReaper
Indulgent Tormenter
ShadowReaper's Avatar
Drives: 15' LTD Subaru BRZ DGM
Add another one to the bucket.
OCVs changed, oil change, reflash ecutek. Code persists. I'm going to try some ecutek finessing next.
Instagram: Gabe.it.the.ole.college.try
ShadowReaper is offline   Reply With Quote
Old 04-06-2025, 12:07 PM   #511
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
There is nothing in ecutek that will help. You either need a cam gear or the IPV values reset.
Ultramaroon (04-06-2025)
Old 04-07-2025, 04:09 PM   #512
kcratos
Drives: minimalist
How does it drive though?
Old 04-08-2025, 03:12 PM   #513
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
When was your last oil change?
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 04-09-2025, 12:53 AM   #514
ShadowReaper
Indulgent Tormenter
Car drives fine when the code is cleared, limp mode when the code comes back every second driving cycle.
Old 04-09-2025, 12:55 AM   #515
ShadowReaper
Indulgent Tormenter
Last one was 3 months ago, but I already had the code. I was bad and went 5k without oil change before that.
Old 04-09-2025, 12:58 AM   #516
ShadowReaper
Indulgent Tormenter
What can reset ipv values?
Old 04-10-2025, 06:59 AM   #517
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I have heard that an autel 906bt and up or launch x431 can put ECU in test mode and get the IPV’s to reset.
Old 04-25-2025, 01:10 PM   #518
kcratos
Drives: minimalist
So, I replaced all 4 OCVs , reset code, it came back within an hour of driving around. The idle At supper low rpm takes a second to adjust. so it still shuts off on me at times, like 2% of the time when dropping into neutral or quickly clutching in.
Thinking what to do next.
also with the code showing I cannot shut off traction control.
P0016 fixable without new ECU? Mr.Jay Issues | Warranty | Recalls / TSB 8 02-06-2022 06:15 AM
P0016/P0017 cause AVOturboworld Issues | Warranty | Recalls / TSB 18 04-17-2021 12:09 AM
P0016 Code Shady195 Engine, Exhaust, Transmission 30 02-21-2019 03:31 PM
p0016 need help asap lol Issues | Warranty | Recalls / TSB 25 10-30-2018 04:49 PM
OFT P0016 and TSB question mmmcambelsoup Software Tuning 10 05-24-2017 10:24 AM
