Old 03-15-2024, 12:39 PM   #197
2.2Lude
2.2Lude's Avatar
Originally Posted by GrandSport View Post
Is there a way to turn everything but ABS off automatically on startup?
Trac-Box and some switches - https://www.geraldjustprojects.com/p...gt86-trac-box/
2.2Lude is offline   Reply With Quote
Old 08-31-2024, 07:26 AM   #198
Eaton PSI
Drives: 2013 86
XXXXCA070 module fitted to my 2013 86. Works great, easy mod. Got a used module off ebay. My car is supercharged so track mode is definitely more fun than stock!
Eaton PSI is offline   Reply With Quote
Old 09-27-2024, 08:39 PM   #199
Enigmeerkat
Enigmeerkat
Enigmeerkat's Avatar
Drives: 2015 Toyota 86 GTS
Apologies if restating a previously asked question, but I may have found someone to buy this part from. They are selling the whole ABS unit, which appears to have this attached. Does this sound correct?? They won't split this component off, and I don't want to end up paying for thewrong thing accidentally. Ty!
2015 Toyota 86 GTS
- Ecutek w/ Flex Fuel, Xtreme Stage 1 Organic Clutch
- PSR UEL Header, Invidia R400 Catback
- Whiteline Swaybars, 18" ROH Blue Evo R
Enigmeerkat is offline   Reply With Quote
Old 09-30-2024, 01:21 PM   #200
norcalpb
norcalpb's Avatar
Yes it seems like most of us bought the whole unit, then removed the module once it arrived.
Old 10-05-2024, 04:41 AM   #201
Enigmeerkat
Enigmeerkat
Thanks for the help & the advice! Just performed the swap, seems to be working brilliantly as intended. It threw a bunch of codes/lights despite me disconnecting the battery, but as stated the lights disappeared after a very short distance. Have cleared the codes, hopefully they don't return.
2015 Toyota 86 GTS
Old 11-30-2024, 02:37 PM   #202
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
So I have a MiG vsc eliminator.
It doesn’t seem to be playing well with my aim mxp dash.
Had anyone seen this before?
I can’t pull the MiG because I don’t have an ebrake. Any other options? Preferably that can be implementer by Thursday?
update: It was the AIM dash, not the MiG.
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car.
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1999 NB Spec Miata: 1.8 w/ all the goodies.
2022 CT5 Blackwing: Stock.
GrandSport is offline   Reply With Quote
Old 02-18-2025, 01:32 PM   #203
GrandSport
GrandSport's Avatar
Reviving an old thread again:
From a hardware perspective, is there any benefit to upgrading a 2014 ABS module to a later one? I am running a motec, so i'm not worried about the software side of things. I can program any year ABS program I want.
Thanks in advance.
Old 03-06-2025, 05:56 PM   #204
Project_1796
Drives: Scion FRS 10 series
Thanks in advance.
The benefits I felt when upgrading to a 2017 and up abs module was the VSC and traction control in sport mode was more relaxed than the older one and you can be more aggressive around corners before any intervention.
Project_1796 is offline   Reply With Quote
Old 03-06-2025, 09:42 PM   #205
Enigmeerkat
Enigmeerkat
Thanks in advance.
Absolutely. I did this a few months back and the difference is amazing. The earlier VSC settings are way too restrictive.
2015 Toyota 86 GTS
Old 04-19-2025, 09:59 AM   #206
XCRACER
Drives: Future FT86
If anyone needs an ABS pump for MT 86, I have mine listed on Ebay. Used on 2015 FRS for 2 years, plug and play. This forum page led me to this solution for the Track Mode on the car and it really made a difference. https://www.ebay.com/itm/146530215691
XCRACER is offline   Reply With Quote
Old 06-23-2025, 06:25 PM   #207
smoltz
Drives: 01 911 Turbo, 03 G500
Is there any improvement in ABS performance with the new module?
On my car (track only) I use pedal dance (via GJP Trac Box) exclusively, but if there is an improvement to be had in ABS performance then this would be worthwhile.
smoltz is offline   Reply With Quote
Review of "Track Mode" on the MY17+ cars trippinbillies40 Tracking / Autocross / HPDE / Drifting 85 02-22-2021 09:27 PM
FS: Nameless muffled track pipe 2013-2016 Dave-ROR Engine, Exhaust, Bolt-Ons 4 05-20-2020 11:27 PM
Track mode vs. VSC sport alex87f Scion FR-S / Toyota 86 GT86 General Forum 9 10-30-2018 10:47 PM
2017 Track mode on older model Bobster Engine, Exhaust, Transmission 17 12-03-2017 10:34 PM
