Old 08-05-2012, 09:46 PM   #71
HKS Australia
Australia HKS Distributor
HKS Australia's Avatar
Drives: Fast One
The HKS Supercharger will make 300hp but it has an inlet restrictor to bring the power level back for reliability.
Cheers
HKS Australia
HKS Australia is offline   Reply With Quote
Old 08-06-2012, 12:19 AM   #72
drifter
Drives: truck and old car
Cheers
HKS Australia
can someone explain what this means? thanks
drifter is offline   Reply With Quote
Old 08-06-2012, 12:38 AM   #73
yuli8466
Drives: MX5
what is a inlet restrictor ?
yuli8466 is offline   Reply With Quote
Old 08-06-2012, 12:49 AM   #74
madfast
Drives: 2010 Evo X MR-T
No Don but similar. HKS had no success with the Rotrex so redisigned their own for better reliability.
Cheers
HKS Australia
what exactly did they redesign? its clearly a rotrex based unit...
basically its a way to control boost. you use an intake restrictor to limit max boost, after correctly sizing your pulley. you want to size the sc pulley to make the compressor spin as fast as possible (safely) and then prevent overboosting with the restrictor.
the pulley changes the entire boost curve (essentially moving it left or right)
while the restrictor levels out the boost up top, and keeps the midrange boost. if the engine can take max boost, then by all means dont run a restrictor. otherwise you will overboost...
madfast is offline   Reply With Quote
The Following 3 Users Say Thank You to madfast For This Useful Post:
dabocx (08-06-2012), drifter (08-06-2012), FrX (08-06-2012)
Old 08-06-2012, 02:45 AM   #75
dabocx
dabocx's Avatar
Drives: Scion FRS
Really interested in this, hopefully next year i can pick this up.
Assuming a built motor and addons what could this put down on 93?
dabocx is offline   Reply With Quote
Old 08-06-2012, 03:25 AM   #76
MANDALAY
Drives: MR2
Yes you can add a restrictor which i did before forging my engine. I then removed it.
However now i going to run a Rotrex double the size but i still need to restrict the final PSI if required. Well another way is to add a Wastegate on the cold side.
Thats what im doing and a recirculating BOV for off throttle gear changing.
See having the biggest blower that can fit is the best then you dictate how much you want.
This way you get much more even lower.
Changing Rotrex size basically add another 2.5 psi at 1,500 rpm
MANDALAY is offline   Reply With Quote
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 07:48 PM
Supercharger or Turbo ? #87 Forced Induction 192 01-25-2013 11:20 AM
HKS Supercharger getting closer gtauto AUSTRALIA 166 09-03-2012 08:11 PM
TRD Supercharger anyone?? poormans_LFA Engine, Exhaust, Transmission 48 04-28-2012 12:42 AM
Supercharger for Infiniti G25 Lottta Other Vehicles & General Automotive Discussions 2 02-12-2012 10:10 PM
