#15 | |
I've been running it on my 2022 on stock calipers, and the CP has survived Autoclub Speedway, and quite a few of the NorCal Veterans with the 22 are also using the CP successfully. As always, if on a stickier tire (A052, RT660, r-compounds, slicks), the user will want to be on a race pad, as the CP's friction is better matched to true street tires and low-grip track tires. It'll still work with the stickier tires, but the long pedal won't make for the best heel-toeing. |
#16 |
Drives: 2023 BRZ
Hmmm. OK, maybe I don't understand what "capacity" means. I think of that as a pad's ability to tolerate high heat without significantly affecting performance. Is that correct? If so, you're saying the CSG street compound is a better, more stable compound at extreme temperatures than a DTC-80?
I feel like I'm missing something here. That sounds too good to be true. I know you love the CSG pads, but there is a reason experienced drivers choose to run two different compounds when driving their street car on the track. I must be missing something.
Director of Rocky Mountain 86CUP
#17 | |
The friction is designed to pair with a street tire, so you need to get much deeper into the pedal than with a race pad that has race friction response. |
#18 |
Drives: 2023 BRZ
Ahhh...okay thank you. So the coefficient of friction is stable across a wide temperature range. It just takes more pedal pressure. That sounds similar to a DS2500. Am I barking up the right tree?
#19 | |
To put it in perspective, I've been running the CP on my Turbo BRZ and not having fade issues. I do have to get a bit deeper into the pedal, and the CP isn't a great match when I'm running race compounds, but with SX2 or RS4, it's just-right. The CP is for the user who runs street tires, street drives their car, but want's the capacity to do an occasional track day here and there without having to commit to race pads. Anyone tracking regularly really should be using race pads for optimal pad life/dollar. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Pat (03-11-2022) |
#20 | ||
bruh
Drives: Raven 2015 FRS
I was actually considering one of those. Is the DL's capability to read from the ECU actually that helpful over the normal Solo 2?
<-- why is this an emote |
#21 | |
It gives you nearly as much data as a pro car, for less than 5% of a pro setup price. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | FeRS (03-11-2022) |
#22 |
Off to the track!
Drives: '14 Lava 86, '13 WRB BRZ
Solo2 non-DL is more or less a GPS lap timer, while the DL version is a GPS lap timer as well as a data logger and data output screen (if you'd like, plenty of configurations). Personally, I got a used Solo DL off of ebay for less than 50% the cost of a new Solo2 DL.
| The Following User Says Thank You to villainous_frx For This Useful Post: | FeRS (03-11-2022) |
#23 | |
bruh
#24 | |
The Solo DL has 16mb, vs the 4gb of a Solo 2 DL. (guy who owns 4 Solo DLs) |
#25 |
Track Day Junkie
Drives: 2022 BRZ Limited
CSG Mike said "The CP, while a street pad, has enough capacity to outperform most entry level race pads, such as a Carbotech XP10 or Hawk DTC, when it comes to raw heat tolerance."
CSG SPEC CP PERFORMANCE 0.43 - 0.49 μ (chart shows .42 min/48 μ max) 50 - 700 °C https://www.counterspacegarage.com/p...ds#performance Most Hawk DTC pads exceed 871 °C and friction is higher @ .50 μ and go to .58~.63 μ Hawk HT-10 0.48 - 0.52 μ 49-704 °C Hawk HT-10 Brembo front: $262.79 / CSG CP front: $390 https://www.hawkperformance.com/compounds/motorsports
Try this Jalapeno son! It ain't hot...
BLUE 2022 BRZ, Scargod's Mod's and Track Upgrades Scargo on IWSTI (Journal of STI track car-for sale) Track Day Videos on YouTube |
#26 |
Drives: '22 brz Sport-Tech
Other options. I use the Endless MX72-Plus for street and track and love them. Was advised that the CC-RG makes a bit of noise, but both should be good dual duty and cost isn't bad from RHD Japan or BlackHawk Japan. I'm only on Advan V601 tires currently.
MX72 Plus Material: Ceramic Carbon Metal Applicable Rotor Temperature (℃): 50~750 Friction Coefficient (μ): 0.39 ~ 0.47 CC-Rg Material: Semi Metallic (Ceramic Carbon Metal) Applicable Rotor Temperature (℃): 50 ~ 800 Friction Coefficient (μ): 0.38 ~ 0.45 There's also the pMu HC+. Hear they are a bit dusty though. Material: Super graphite metallic, Applicable Rotor Temperature: 0-800C, Friction Coefficient: 0.43-0.58u |
#27 | |
Drives: Crapcan
#28 |
So the HC+ and CC-RG are pretty similar then. I've been very happy with the MX72-Plus. They don't disintegrate like the DS2500 and only emit a light chirp every now and again on the street. I don't do enough track days to justify dedicated track pads, if so i would run Gloc.
| Not Another Brake Pads Thread 2022 Edition | SlowCarFast | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 03-01-2022 02:19 PM |
| DIY - Changing Your Brake Pads (Race Pads upgrade) | PMok | DIY (Do-It-Yourself) Guides | 53 | 09-03-2021 05:17 PM |
| FS: OEM wheels, HAWK HPS front and rear brake pads, OEM brake pads, TYC colins tails | oppiee | Canada Classifieds | 4 | 10-07-2019 05:27 PM |
| Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! | eauto | Brakes, Suspension, Chassis | 255 | 10-15-2014 01:45 PM |
| Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 10:20 PM |
